Guest krow113
Thanks Gus!
Today a little brass for the switch set by Taurus Model|:
Guest krow113
Ya  Uschi decals with pre-shading underneath, they are quite transparent , and some outlineing and dark shading in a red/brown/black wash.
The woodwork is a joy to see coming together.  Any chance you could do a step-by-step photo set for one of the parts?  I'd love to watch over your shoulder, if I may?
That is beautifully done!  I've been doing a ton of woodwork on the Picket Boat, and it's impossible for me to tell the difference in finish/appearance between the wood pieces I'm making and the wood finish you're applying here.  It's utterly convincing.
Thanks for sharing your approach and the work as it develops
Guest krow113
Thanks crazypoet!
Here some detail was destroyed so , cleaning off the rest of the damage and re-creating out of brass|:
Guest krow113
Fuel cart rising:
Neither  the kit or HGW's p/e is  adequate to serve for the throttle assy , so a little of this and a little of that:
I love this!  Making things look "right" both from a distance as well as right up-close is a gift and a talent.  I can put myself into the cockpit you're building and the instuments all seem to be ready for my hands to reach out and use.
Adequate.  Quite adequate.
Guest krow113
The luck of the adequate!
Thanks cpoet!
Just lucky to be able to see how things 'look' and manipulate paint and other mediums to adequately recreate that 'look'.
 Some parts assembled:
Guest krow113
Finishing the oxy tanks and the IP :
Guest krow113
Thanks Micheal!
 I have a set of ComArt thin wash's from Medea if that makes sense. I've used them continuously for years. Can be airbrushed or deployed with a regular brush.
Lots of colors and they are bright and workable.You can go back in and remove , as I did on the IP screw details around the edge , flood then go back in and clean up around the details.
I bought a set at my LHS and have added to it from Medea's catalogue.
Good to know.....thanks for the info. I am always looking for new types of washes and will give these a shot. You are clearly getting great results with them!
Keep up the good and inspirational work!
Cheers from NYC,
Michael
Guest krow113
Some detailing yet to go as the fuse nears assy. Clamped to keep the lower gun tunnel lips flush:
Hate the new look of the forum , funny thing is , I cant remember how it used to be!
Guest krow113
...and the lip did end up flush , I didnt glue the top edge allowing it to move into position without smearing the glue. The small upper edge can have glue wicked in easily now:
Interior bomb racks detailed with manual release mechanisms (handle):
