Hello all
I wanted to do this one for long time and finally decided to go through with it.
I used excellent 1:32 Dragon kit an I must say I find it a bit more enjoyable to build than Eduard offering. Really had no problem building this one. All parts come together quite nice and I was a bit afraid of nose section since I had no intention to build it with engine. All that was in need was some careful positioning and the whole area fit quite nicely.
I decided to use Model Master Acrylic RLM 79 since it look more yellowish than enamel paint from same manufacture. I thinkit gives more realistic look for early Luftwaffe desert Emils, enamel is much more suited for later 109s. RLM78/80 are MM enamel and decals are from Kagero.
Never built the Dragon kit before but have built a couple of Eduards offerings, E1, E4. They build up rather nice as well but have a couple of things to look out for namely the conopy not being wide enough and the lower wing to fuse join at the rear.
I think your build turned out excellent, and the scheme and colours look cool.
Cheers Bevan
  • 4 weeks later...
Now that's one outstanding E-7 my friend. Congratulations for a well built and beautifully painted bit of history. Love that North African camouflage scheme.
Highest Regards,
Gregory Jouette
Great job  :thumbsup2: and I am glad you mentioned the difference in the MM RLM 79 between the enamal and acrylic.  Got a couple
of those desert schemes I want to do and I like the way yours looks.
Cheers,
Jerry  :piliot:
