rkranias Posted December 5, 2016 Posted December 5, 2016 any suggestions for paint color or mix for Hinomaru on 1:32 IJN aircraft?  would like to stay with lacquer based paints, Gunze, Mr. Paint. Tamiya will work as well (since it mixes with lacquer thinners)  thanks - Rick
Administrators Fran Posted December 5, 2016 Administrators Posted December 5, 2016 Weel Rick, in another modelling life, (before WnW) I has some interessed in IJN!   I folow closely the J-aircraft.com forum, that I think that is iwthout updates since 2009... There you will find seen info about it! - http://www.j-aircraft.com/faq/hinomaru_red.htm  The hinomuru colour could be a FS31328 ,or the XF-7 or Gunze C385, Red (Japanese Navy Markings)... i think that any of those are correct! The Pacific weather do the rest!   Fran 1
Administrators JeroenPeters Posted December 5, 2016 Administrators Posted December 5, 2016 Sorry... haven't the foggiest... 2
Iceman Posted December 6, 2016 Posted December 6, 2016 Tamiya XF-7 or X-7 Red toned down with a little XF-10 Red Brown works well, you can also add a touch of XF-3 Yellow to get more of a deep orange hue. Â Recommend staying away from any tints to the white or buff tones as it tends to give the red a pink hue to it. Â If it looks right to your eye after applied, than it's right. Â Kirk 1
Dennis.E Posted December 7, 2016 Posted December 7, 2016 I would tread carefully here Rick...color is highly subjective, even with actual mix ratios ( Which themselves could proove troublesome as both Nakajima and Misibushi both amended their color ratios as the war waged on through 1943/44 into 45). Once applied color becomes subject to atmospheric and diurnal variations, especially down here in the Pacific regions. Add to that ground and aircrew scampering all over the airframe, the corrosive effect of coral dust and salt water spray and cruel levels of humidity...I would apply whatever you are happy with Sir and let anybody try and negate what you have applied... 2
