elmarriachi Posted December 22, 2016 Posted December 22, 2016 One more amazing kit from Wingnut Wings - this time the Pfalz D.IIIa will be the next World War I airplane on my desk. I have started with the interior as always. All later wooden parts were painted in a light beige first with the airbrush, then oil colors followed next to make the final wooden effect. On the inside of the hull the skewed wooden slats werde each separately painted with a cotton bud then ... [ Now I wish you all a MERRY CHRISTMAS! Cheers Micha 5
Administrators JeroenPeters Posted December 22, 2016 Administrators Posted December 22, 2016 Geez Micha! You're all over the place! Armour, softskin, and planes. Good luck with this amazing kit..
ophthoidoug Posted December 23, 2016 Posted December 23, 2016 Looks like you might have derailed my own Wingnut Pfalz project by posting that giant Dora ... ;-)
elmarriachi Posted January 4, 2017 Author Posted January 4, 2017 The Mercedes D.III engine put together, then added some wiring. After that started with the painting of the engine in black, aluminium and then the details with a fine brush.... A first step of weathering was done with oil colors.... Cheers Micha 2
elmarriachi Posted January 30, 2017 Author Posted January 30, 2017 Hello, the interior was put together and details painted afterwards. The engine was installed, the seatbelts (PE-parts) and some further small stuff. Now follows some decals, wiring and rope .... Cheers Micha 4
Administrators JeroenPeters Posted January 30, 2017 Administrators Posted January 30, 2017 Nice... Don't you just love WnW...
Jorge Márquez Posted February 12, 2017 Posted February 12, 2017 Very interesting, I have always been very respectful of this type of models pending of your
elmarriachi Posted February 20, 2017 Author Posted February 20, 2017 Hello after having finished the interior, added the steering lines (EZ-Line) with super glue. Then both halfs of the hull were glued together around the interior. The seams closed with some putty, cleaning and sanding ..... Now further details follow .... Cheers Micha 1
elmarriachi Posted March 6, 2017 Author Posted March 6, 2017 Hello. I have painted the outside of the Pfalz now. After a grey primer I have sprayed the front area in red, which I have mixed from several red tones from Lifecolor. Once dry I have masked it and sprayed Tamiya blue on the rest. The underside of the fuselage and the wings is neutral grey with a few drops of Aluminium. Next follow the decals, detail painting, the rips of the wings, oil color matt clear coat .... Cheers Micha
elmarriachi Posted March 15, 2017 Author Posted March 15, 2017 Hello, the decals of the airplane of Robert Berthold are done, a layer with clear coat fixed the decals and secure it for the weathering. A layer of black/brown oil color on everything followed, wiped away with a cloath after a few minutes. The rips of the wings were lightened with white pastells, then a layer of matt clear coat followed on everything ... Cheers Micha 3
elmarriachi Posted March 20, 2017 Author Posted March 20, 2017 Hello, after the mounting of the upper wing I have added the pipework between engine and wing, then started the rigging. The turnbuckles are from Gaspatch Models and glued in drilled holes. Once dry I have glued EZ-Line through the turnbuckles, stretched it and glued it in place. Some adjustment of the turnbuckles will follow. Next I will add the landing gear and the propeller ... Cheers Micha 3
GusMac Posted March 20, 2017 Posted March 20, 2017 Looks great. I take my hat off to anyone who can rig these things well. My only attempt ended up in the trash. 1
