4 hours ago, GazzaS said:
Nice work on a very attractive tank.
Thanks. It should look great when I have finished it. 2nd tank that I have put weathering on so should be quite the challenge too.
Hears a small update.
I have sprayed the small wheels that the tracks rest on brown. May try splatter them with some weathering. Also painted the exhaust boxes as well as a couple other parts that are to do with the exhaust. And also sprayed the muzzle brake with the same colour as I mixed it myself. And it looked like a burned colour and it looks good
So just put together a gun and mantlet that I don't intend to use. And fitted it to the turret with some blue tack to see what it looks like. There should be a muzzle brake on the barrel but there is only one in the set and I intend to use it on the gun I actually want to fit to the tank.
  • 10 months later...
right i am back almost a year since i touched this wow. doing the periscopes and front hatches driver and bow gunner i belive
I believe the instructions intend for the hatches to be glues down but I have left them free. The pices are too small for me to make a hinge so I'll just leave them loos for now. I propped them open with some tooth picks
I'll add pictures soon
7 minutes ago, Clunkmeister said:
Nice to see this up and going again
Yeah was talking with my college friends and I just felt like doing it again. Hopefully get it done this time
Just finished 3 or so hours. Just touching up scratched paint and installing the bow gun
Front Before:
Front After:
IMG_20191210_213807021.thumb.jpg.7904ea3f8353b5334871db8f77b1253e.jpgIMG_20191210_213734783.thumb.jpg.759752c5c140795541daca06ed564469.jpg
Rear before:
Rear After:
I will add some more weathering after or close to when the tank is done
Well things just went wrong.
Was painting the two track sections for the front of the tank and I have a lamp with a magnefying glass and it gets hot. I went to get a drink and it moved and the heat melted the parts.
Going to try and get some replacement parts from TAKOM.
I did some more work on the track guards. Cleaning them up attaching the speaker and cover and glueing the handles to the storage boxs and the boxes to the guardsIMG_20191217_175641526.thumb.jpg.0e2975e1c0e6c6ec20f9eba197e485dd.jpgspeaker
IMG_20191217_220316495.thumb.jpg.c46d27dd1ac6cd172c29102e442098e8.jpgshot of the back with the break lights attached was tricky painting them green with the red.
IMG_20191216_201131029.thumb.jpg.0b52518d06c615cc88e4cda358a214f0.jpgIMG_20191216_201117285.thumb.jpg.5581861ef14f82957f584f7e5051ed5a.jpggluing handles to storage boxes
IMG_20191217_141344503.thumb.jpg.a6bd0c50ec98eef4a269c58438c55efb.jpgalso removed some detail from the alternative tank
Painted the wood on the tools. happy with the spadeIMG_20191218_181328009.thumb.jpg.de9bb69d50d02a94463899f7af63ff2e.jpgIMG_20191218_181328009.thumb.jpg.de9bb69d50d02a94463899f7af63ff2e.jpga little hard to see the handle and shaft are wood and the spade head and rest of the handle are aluminum with a green mounting bracket over the spade headIMG_20191218_181351878.thumb.jpg.35ada9d32ba2238e53e69d3b402bcaba.jpg
Touched up the paint again. And glued the Track guards to the tank along with the storage boxes. Then fitted all the tools. They look good. Took some time painting them all nice. Not quite the right colours on a couple but you wouldn't know unless you were a tank nutIMG_20191219_163512897.thumb.jpg.ef507aa2e6caa86c9e238ab8f5ba97e6.jpgcant say how happy I am with that spade. Took alot of patience to get that paint perfect and I don't think I could have done it like that last yearIMG_20191219_171940855.thumb.jpg.b4d689494c6f2014200ab14e7c247f87.jpgIMG_20191219_171952479.thumb.jpg.98f85a7c0da4bcf9cef39c3a660f2cba.jpg
I did fit the exhausts and put some weathering on them. But didn't take photos I'll get some of it done in afew minutes. Yesterday I put the towing cables on and glued the little holders for them down. Also took a look at the travel rest for the gun
Guns travel restraint moves fairly freeley. And everything is done at the back. Glued the fuel tank caps on and what I believe is a breather pipe to stop a vacuum being created inside the fuel tanks. Also putting the head lights together
