Our new kit the 'E' Type Bomb Trolley with the 12000lb 'Cookie' Blockbuster is now available to go with the HK/WNW Avro Lancaster Kit, it's a resin kit with all the master parts produced by 3D CAD and CNC machining, the research was all done at our local museum and extensive measuring of the Trolley and the 'Cookie' on site.
The link to purchase is :-  http://www.iconicair.com/12000lb/
Graham
Graham
Many thanks for producing that superb bit of craftsmanship.
Can I ask if you are going to produce a 4000lb trolley and one for carrying smaller bombs ?
'My' squadron didnt carry the 12,000lb, not many did, so although it looks terrific I shall wait hopefully for the smaller version.
Have you plans to produce the David Brown ?
David
Hi David, Yes we already do a 4000lb Trolley with Cookie see :-  http://www.iconicair.com/cookie/
In the works is a David Brown Tugmaster and then after that the smaller 'C' Trolley with bombs, also the Trolley with the 8000lb 'Cookie' which is a generic version of our 12000lb but with one stage less and a drum tail. [ this last will be in a couple of weeks or so ]
Graham
  • 4 years later...
  On 6/11/2019 at 8:00 PM, GrahamF@Iconicair said:
Here is a couple of shots of the first Bomb Trolley painted and decals applied.
Graham
Expand
Helo.
Which Lancaster Version droped this 12.000lb cookie? Some sources say the 8000lb was droped from the Lancaster with the deeper bomb bay for the Tallboy but the 12000lb cookie could be only droped from the aircrafts converted for the Grand Slams.
Any help?
