IainMackayDall Posted December 5, 2020 Posted December 5, 2020 There's no, if not many, 1/32 production models of a B-29. Has anyone got and links to built models. This URL is a great tour of through the fuselage. https://my.matterport.com/show/?m=Qa3Lu8iPfHW&fbclid=IwAR3bPGgdDVW-Pu0Nx1PvVN-VwXgkTfQofqcNpUab_pSKUJrji-1nhTs__iU 3 1
GazzaS Posted December 5, 2020 Posted December 5, 2020 heh.... thanks for sharing! That would have been useful on the B-29 that I almost completed in 1/48 a few years back. 4
HubertB Posted December 5, 2020 Posted December 5, 2020 For a built model, Tom Probert built a 1/32 ID vac. Probably visible here or on LSP. As for the build and the end result, this is a perfect illustration of the famous sow’s ear and silk purse story Hubert 3 1
ThomasProbert Posted December 5, 2020 Posted December 5, 2020 9 hours ago, HubertB said: For a built model, Tom Probert built a 1/32 ID vac. Probably visible here or on LSP. As for the build and the end result, this is a perfect illustration of the famous sow’s ear and silk purse story Hubert I did indeed build the ID Models kit a few years back and as the entire interior had to be scratch-built I did lots of research - do ask if you have any questions as I became particularly familiar with the internal details of the B-29. There will be a build thread on LSP and Britmodeller somewhere (wasn’t a member we here back then) but I’m not sure if the photos survived the photobucket debacle. Tom 3 1
Administrators Clunkmeister Posted December 8, 2020 Administrators Posted December 8, 2020 Tom, did you do a Superfortress or a Washington when you built it? 2
IainMackayDall Posted January 7, 2021 Author Posted January 7, 2021 (edited) Interesting rippling along the fuselage, I haven't seen many like this one, maybe most WW2 images had almost factory fresh deliveries although its noted that this B-29 has been damaged https://www.worldwarphotos.info/gallery/usa/aircrafts-2-3/b-29/boeing-b-29-superfortress-damaged-tinian/ Edited January 7, 2021 by IainMackayDall added detail on source 1
GazzaS Posted January 7, 2021 Posted January 7, 2021 7 hours ago, IainMackayDall said: Interesting rippling along the fuselage, I haven't seen many like this one, maybe most WW2 images had almost factory fresh deliveries although its noted that this B-29 has been damaged https://www.worldwarphotos.info/gallery/usa/aircrafts-2-3/b-29/boeing-b-29-superfortress-damaged-tinian/ Rippling that bad and being on jack stands.... pretty sure that machine was completely structurally compromised. TBH... Can;t say I've ever noticed any tin-canning on an in-service B-29.
IainMackayDall Posted January 7, 2021 Author Posted January 7, 2021 Could that have been a result of a heavy landing buckling the fuselage? I doubt that AA could do that without pepering the hull with holes, regards Iain
krow113 Posted January 7, 2021 Posted January 7, 2021 Looks as if there is no tail on that plane. Rippling like that may be from ground explosions. 2
