benjaminsummerfield Posted August 24, 2013 Posted August 24, 2013 SP&R Review: http://scaleplasticandrail.com/kaboom/index.php/all-things-aviation/132-135-scale/132-kit-reviews/1139-132-spitfire-mkvb-trop-from-hobbyboss While ive stalled with my Silverwings Gladiator ive started this to help me get my mojo back! Im Chucking plenty of aftermarket at it, while its not a bad kit, next to a Tamiya Spit its flaws are highlighted so ill fix what i can. The Canopy is the main issue, most Trops had the internal armoured windscreen but Hobbyboss only supply the battle of Britain style external armoured screen (as mentioned in SP&R's review) and im not convinced thats quite right either. Ill be raiding the spares box for a few left over bits from the Tamiya spit too, and sacrificing my Hasegawa Spit Vb for its windscreen and spinner and a few other little bits. First up the Bulkhead the seat bolts too has a moulded on bit for the head Armour to attach to which would stop you threading the seatbelts through so thats gotta go! compare to the PCM part Also the armoured plate behind the seat is an etched part but they only give you the top half!? so i made a new one from plasticard, and used a spare etched armour plate from the Tamiya kit to replace the thick kit part. I think most people are aware that Hobbyboss have repeated Trumpeters mistake with their 1/24th Spit by moulding fabric detail on the tailplane, im in the process of fixing it with an RB scriber and thought id copy the Tamiya spit and add some rivet detail to the top of the engine cowling as well while im at it. Also put the main colour on the Barracuda padded resin seat, cracking bit of casting, highly recommended. Just working on the interior now, ill update soon.
repeater Posted August 25, 2013 Posted August 25, 2013 Watching with interest! Keen to see how you tackle the canopy issues.
benjaminsummerfield Posted September 7, 2013 Author Posted September 7, 2013 Pretty much finished the Interior, in my excitement I started putting it together then realised I hadn't got any pics! Excuse the quality my WIFI is down so these are from my phone. Seatbelts are lead foil and MDC buckles Scratch built headrest from evergreen tubing and lead foil The Barracuda bits are superb and a big improvement over the kit parts, I like my cockpits filthy as you can see. Aiming to get the fuselage together this weekend. 1
benjaminsummerfield Posted October 26, 2013 Author Posted October 26, 2013 Finally some progress with the Spitty! I've been working daft hours with my job but have managed to get some serious bench time in thanks to my Mrs! Not a lot to say about the construction of this kit, great fit, fairly simple if a bit clunky; but it's gone together well it's just been a lack of time to model that stalled it slightly The windscreen is the main thing to tell you about, this kit is a little wide in the hips so using the Hasegawa kits windscreen has meant adding some plasti card. I used scale plans and my completed Tamiya IX to help me, even so there would still be a gap unless I made the fillets oversized so I used Krystal Klear white glue to fill the gap and wiped it smooth with a wet finger. Seems to of worked, although the fillets are lying flatter than they really should be to help close the gap but it's the best compromise I could manage. I also fitted the brass master cannon barrels which are just superb ,even having the hexagonal end used to screw the barrel in place. So as you can see she's now primed and just need a micro mesh before I apply the sky blue undersides, for which I'm using RLM 76. Hopefully update you tomorrow.
Jamme Posted October 26, 2013 Posted October 26, 2013 NIce to see this one back, Benjamin! Cheers, Jamme 1
Wingco57 Posted October 27, 2013 Posted October 27, 2013 Nice windscreen set. Adressing that HobbyBoss windscreen problem at once. Cees 1
rkranias Posted October 27, 2013 Posted October 27, 2013 watching this as I have same kit in my stash. already have the Cuda seat, door, PE IP, HGW belts and stabilizer replaced. Will be awhile before I start, going through a Luftwaffe phase. Build looks really nice. 1
benjaminsummerfield Posted October 28, 2013 Author Posted October 28, 2013 Applied the RAF Sky blue, I used White ensign RLM76 for this as it's apparently a close match. Sky blue was generally used on Vickers built Spitfires and most of the ones sent to Australia had sky blue undersides rather than azure. My particular spitfire seems to of had the under carriage and wheels sprayed in this colour too. 2
benjaminsummerfield Posted November 2, 2013 Author Posted November 2, 2013 I Applied the Dark Earth last night, I've also done some selected areas in Mid stone where I'm going to wear the paint back from the Malta Blue; for which ill be using Ex Dk sea grey. After that I'll be using Miracle masks for the roundels and codes which I'm looking forward too. 1
benjaminsummerfield Posted November 2, 2013 Author Posted November 2, 2013 One question I'd like all your opinions on... This aircraft I'm building ( GN-H of 249 sqn) is always illustrated with a black spinner, admittedly it looks as dark as the prop blades in photos but consider... 1: it left the factory with a sky blue spinner and camouflaged in Dk green/ Dk earth. 2: it had the green over painted in mid stone before delivery to Malta so surely they would of repainted the spinner red for that theatre at the same time? Red often appears very dark in photos where a filter has been used. The fin flash confirms this as the red on it appears very dark. 3: once on Malta it appears to of had the mid stone overpainted with a local blue and the spinner now appears dark. So my question to you is Red spinner? Malta blue spinner or black? !! I would appreciate your input chaps!
Edgar Brooks Posted November 4, 2013 Posted November 4, 2013 In a signal dated 20th February (no year, but presumably 1943) Malta H.Q. said that 229 Squadron's spinners were yellow, and those of 249 were red. Edgar 2
benjaminsummerfield Posted November 4, 2013 Author Posted November 4, 2013 Cheers Edgar mines the first spitfire delivered tho lol
benjaminsummerfield Posted November 5, 2013 Author Posted November 5, 2013 More progress, applied the Ex Dark sea grey, next step is roundels and codes woohoo! 1
rkranias Posted November 5, 2013 Posted November 5, 2013 nice work on the paint, shade and freehand...... 1
benjaminsummerfield Posted November 5, 2013 Author Posted November 5, 2013 Cheers rick just experimenting really, just added black to the mix and go over the lines then dust over a coat of the original colour. Want this one looking worn.
benjaminsummerfield Posted November 6, 2013 Author Posted November 6, 2013 Started painting the roundels today and the codes etc, Mal at miracle masks has done a cracking job on my custom masks. Small bit of peeling when I removed the masks around the codes, hope it doesn't peel when the roundels are done :S 1
benjaminsummerfield Posted November 7, 2013 Author Posted November 7, 2013 Well I knew it would happen wing roundels are fine and the other side is ok.
Dave J Posted November 7, 2013 Posted November 7, 2013 Bugger! I hate it when the paint peels off... It can be depressing! 1
nmayhew Posted November 8, 2013 Posted November 8, 2013 Oops Explain again: what primer and paint are you using?? 1
