Wingco57 Posted October 20, 2013 Posted October 20, 2013 Mk 21 (type 356)[edit] By early 1942, it was evident that Spitfires powered by the new two-stage supercharged Griffon 61 engine would need a much stronger airframe and wings. The proposed new design was designated the Mk 21. At first the Mk 21 displayed poor flight qualities that damaged the otherwise excellent Spitfire reputation. The wings were completely redesigned with a new structure and using thicker-gauge light alloy skinning. The new wing was torsionally 47% stiffer, allowing an increased theoretical aileron reversal speed of 825 mph (1,328 km/h). The ailerons were 5% larger, and were no longer of the Frise balanced type, instead being attached by continuous piano-hinges. They were extended by eight inches, meaning that with a straighter trailing edge, the wings were not the same elliptical shape as in previous Spitfires.[42] The Mk 21 armament was standardised as four 20mm Hispano II cannon with 150 rpg and no machine guns. The Griffon engine drove an 11 ft (3.35 m) diameter five-bladed propeller, some 7 inches (17.8 cm) larger than that fitted to the Mk XIV. To ensure sufficient ground clearance for the new propeller, the undercarriage legs were lengthened by 4.5". The undercarriage legs also had a 7.75 inch (19.7 cm) wider track to help improve ground handling. The designers then devised a system of levers to shorten the undercarriage legs by about eight inches as they retracted, because the longer legs did not have enough space in which to retract. These same levers extended the legs as they came down. The larger diameter four spoke mainwheels were strengthened to cope with the greater weights; post-war these were replaced by wider, reinforced three spoke wheels to allow Spitfires to operate from hard concrete or asphalt runways. When retracted the wheels were now fully enclosed by triangular doors which were hinged to the outer edge of the wheelwells.[42] In other respects, the first production Mk 21s used the same basic airframe as the Mk XIV. The first true Mk 21 prototype, PP139 first flew in July 1943, with the first production aircraft LA187 flying on 15 March 1944. However the modifications over the Mk XIV made the Mk 21 sensitive to trim changes. LA201's poor flight control qualities, during trials in late 1944 and early 1945, led to a damning report from the Air Fighting Development Unit: "...it must be emphasised that although the Spitfire 21 is not a dangerous aircraft to fly, pilots must be warned...in its present state it is not likely to prove a satisfactory fighter. No further attempts should be made to perpetuate the Spitfire family."[43] Supermarine were seriously concerned because Castle Bromwich had been converted to produce Mk 21s, and more were coming off the production lines daily. Jeffrey Quill commented that "The AFDU were quite right to criticise the handling of the Mark 21...Where they went terribly wrong was to recommend that all further development of the Spitfire family should cease. They were quite unqualified to make such a judgement and later events would prove them totally wrong."[43] Spitfire F Mk 21 of 91 Squadron. After intensive test flying the most serious problems were solved by changing the gearing to the trim tabs and other subtle control modifications, such that the Mk 21 was cleared for instrument flying and low level flight during trials in March 1945. An AFDU report on LA215 issued that month noted that the Spitfire 21 was now much easier to fly; General Handling The modifications carried out to this aircraft have resulted in an improvement of the general handling characteristics at all heights...Conclusions The critical trimming characteristics reported on the production Spitfire 21 have been largely eliminated by the modifications carried out to this aircraft. Its handling qualities have benefitted to a corresponding extent and it is now considered suitable both for instrument flying and low flying. It is considered that the modifications to the Spitfire 21 make it a satisfactory combat aircraft for the average pilot.[44 ] Spitfire 21s finally became operational on 91 Squadron in January 1945. 91 Squadron had little opportunity to engage the enemy before the war ended, but scored a rare success on 26 April 1945, when two Spitfire Mk 21s shot up and claimed to have sunk a German midget submarine which they caught on the surface. With the end of the war most orders for the Mk 21 were cancelled and only 120 were completed.[45] In 1946 40 Spitfire 21s were delivered to Shoeburyness; once there their leading edges were removed and destroyed in "lethality" tests. Some aircraft had less than five hours flying time.[46] Mk 22 (type 356)[edit] The Mk 22 was identical to the Mk 21 in all respects except for the cut-back rear fuselage, with the tear-drop canopy, and a more powerful 24 volt electrical system in place of the 12 volt system of all earlier Spitfires. Most of the Mk 22s were built with enlarged tail surfaces, similar to those of the Supermarine Spiteful. A total of 287 Mk 22s were built: 260 at Castle Bromwich and 27 by Supermarine at South Marston.[47] The Mk 22 was used by only one regular RAF unit, 73 Squadron[48] based on Malta. However 12 squadrons of the Royal Auxiliary Air Force used the variant and continued to do so until March 1951. The Mk 22 was also used at Flying refresher schools. In May 1955 the remaining F.22s were declared obsolete for all RAF purposes and many were sold back to Vickers-Armstrongs for refurbishment and were then sold to the Southern Rhodesian, Egyptian and Syrian Air Forces.[48][49] Well, I'm not Edgar, but if the above from Wikipedia is correct, I'd conclude that the Mk.21 used the original horizontal tailplane from the earlier marks with the enlarged mass balances. Edit: I have included the information provided by Erik here for completeness. Cees Here's the start of an attempt to create something that's not available in our scale.The Spitfire 21 was the first version of the Spitfire with a new wing. By combiningThe Revell / Matchbox Spitfire 22/24 ( thanks Dave) wings with a PCM Spitfire XIV fuselage.I started with the most difficult part, the wings.The original Spitfire 22/24 was made by Matchbox in the seventies, i remember buildingIt in 1977 and I was very impressed. However, the detail is now ancient but the wingsCan be used as a base to start from.The wheelbays need work as there isn't any detail. The kit walls were snipped off and sandedsmooth, the detail is represented with Plastic strip. The pics show the current state of progressCees 2
Administrators JeroenPeters Posted October 20, 2013 Administrators Posted October 20, 2013 There he is!! Really ballsy work on a kit that needs A LOT of love and attention. Great work on the wheelbays. I've seen it up close, and say again: great work!
benjaminsummerfield Posted October 20, 2013 Posted October 20, 2013 I did have a PCM XIV for just this very thing, Alleycat did a Seafire FR47 conversion for the matchbox kit which came with corrected gun and wing bulges and some very nice undercarriage doors. I exchanged emails and he said I could just buy the wing parts on their own and then he stopped replying so I shelved the project you might have more luck. I offered the wing up and it's certainly doable if you can get the Matchbox parts up to scratch. If you go on the British Pathe website there is some great footage from the queens coronation of 600 squadron F21's and 22's with highly polished engine cowls and red spinners. Which would make a change from the usual camo. I'll be watching this with interest.
benjaminsummerfield Posted October 20, 2013 Posted October 20, 2013 Here's the footage. http://www.britishpathe.com/video/queen-at-biggin-hill-1
One-Oh-Four Posted October 20, 2013 Posted October 20, 2013 I saw you working on it yesterday, Cees. A project for the brave, I'd say! The wheel well detail looks very good! 1
Guest Kagemusha Posted October 21, 2013 Posted October 21, 2013 Nice start Cees, I'll be following with interest. ps. It was Freightdog who produced the Seafire 46/47 conversion, I emailed about buying just the Spitfire specific parts, but didn't even get a reply though I did buy the complete conversion later.
Wingco57 Posted October 21, 2013 Author Posted October 21, 2013 I have pasted the information about the Spitfire 21 as discussed earlier in the discussion forum. herein. Cees
Wingco57 Posted October 23, 2013 Author Posted October 23, 2013 Update, I just love this version of the Spitfire, powerrrrrrrr Work on the wheelbays is finished, the grafting on of the wings is next, also how to adapt the PCM radiator fairings, the spitfire XIV arrived today, care of DoogsATX, thanks Matt. Your timing Is perfect. Here is a pic showing the fuselage of the XIV and the 22/24 wings, as you can see there is a significant Gap. Some plasticard should solve that. Cees 1
Administrators JeroenPeters Posted October 23, 2013 Administrators Posted October 23, 2013 That's some gap! Love to see you tackle that with green card! This kit really is / will be a proper: Following with lots of interest! 1
Wingco57 Posted October 23, 2013 Author Posted October 23, 2013 Erik, If I included those two neckbolts it would be a Seafire F45 ( catapult spools). Now to find a way to erase those stitchings, Ohh eh question, is it correct that the wheelbays are natural metal as on the RAF Musem's Example? Edgar? Cees 1
Administrators James H Posted October 23, 2013 Administrators Posted October 23, 2013 I'm sure the late machine at Cosford has a bare metal wheel bay, but I could be wrong.
Dave J Posted October 23, 2013 Posted October 23, 2013 Nice Work Cees! Thats a big gap you have there! Looking forward to seeing how you tackle it!
Wingco57 Posted October 24, 2013 Author Posted October 24, 2013 Let's first see how to transplant the radiator fairings without demolishing the whole thing. I was thinking about using the PCM wing underside centre section because it has the same detail as the fuse (the Revell kit has nothing) and also use the section for the radiator mountings (the Spit's radiators are quite deep and half buried in the wings), but cannot use the flap section as that is completely different. Frankenstein it is. Cees
Edgar Brooks Posted October 24, 2013 Posted October 24, 2013 Ohh eh question, is it correct that the wheelbays are natural metal as on the RAF Musem's Example?Wheel wells were always painted, and those of the RAF Museum's 24 have been repainted (as has the cockpit, which was green, not grey.) This well is on a never-rebuilt 22, which exhibited green paint in the interior and on the insides of the doors; this matches a note on a late drawing, in the RAF Museum's library, which advocates green for interiors instead of silver (possibly due to a shortage of aluminium, for paint, at least, at the end of the war.) Sorry if it ruins your day, but pipes did not cross the wheel well, on any Spitfire; with a maximum clearance of 1 inch, the u/c would never have closed. Edgar
Wingco57 Posted October 24, 2013 Author Posted October 24, 2013 Edgar, Fantastic, so this is similar to the Tempest's wheelbays. I knew museum examples cannot be taken as gospel. Nice pic by the way, very useful. I plan to install the undercarriage door actuators and cilinder last. Thanks very much. By the way which pipes are you referring to? Cees
Edgar Brooks Posted October 24, 2013 Posted October 24, 2013 Sorry (I'm due for an eye-test, and new glasses, so that's my excuse,) mistook the support framing for pipes. Edgar 1
Wingco57 Posted October 24, 2013 Author Posted October 24, 2013 No problem Edgar, you keep me on edge anyway. Thanks for your help. Will Start butchering plastic after doing the dishes. Cees
Wingco57 Posted October 24, 2013 Author Posted October 24, 2013 After the butchering... As Edgar mentioned earlier the Revell radiatorfairing is too small, with PCM's example being much longer And accurate. Instead of grafting the complete wingsection with radiator mountings from the PCM kit, I chickened out. Did not want to weaken the plastic too much, the Revell polystyrene is quite brittle. Instead I cut out The flat area. In here the cut out radiator trunk will be transplanted with the fairings fitted on top. Much easier. After that I hope to use the PCM underside part suitably cut to shape. If that doesn't work The Revell part will be used as a plan B. Already the rear fillets have been cut off from the Revell parts as they do not fit, the PCM part does. Does this make sense? Cees
One-Oh-Four Posted October 24, 2013 Posted October 24, 2013 Ouch, hacking and slashing...Brutal! I love it, I'm really curious how slick and end result you're going to achieve!
Jamme Posted October 25, 2013 Posted October 25, 2013 Typically a true Large Scalpel Modeller's choice !!!! Cheers, Jamme
Grant Posted October 25, 2013 Posted October 25, 2013 Errr, WOW! I think you should invest in a band saw !! It seems no plastic is safe when your around
