mark31 Posted August 5, 2022 Posted August 5, 2022 Hello i have akit that im going to redo So i whant to strip it compleet. But there are resin parts on the plastic with ca gleu. Is there a easy way to get them off without screwing all up? Thanks Mark
JohnB Posted August 5, 2022 Posted August 5, 2022 3 hours ago, mark31 said: Hello i have akit that im going to redo So i whant to strip it compleet. But there are resin parts on the plastic with ca gleu. Is there a easy way to get them off without screwing all up? Thanks Mark Get some CA adhesive debonder Mark. 2
mark31 Posted August 5, 2022 Author Posted August 5, 2022 1 hour ago, JohnB said: Get some CA adhesive debonder Mark. Will do 2
BlrwestSiR Posted August 9, 2022 Posted August 9, 2022 Mark, I use this which is the same stuff John mentioned. 1 2
HubertB Posted August 9, 2022 Posted August 9, 2022 Just be careful and test before. The best CA debonder is acetone, but it loves plastic as well, although its fast evaporation can help mitigate the potential damage. Btw, I have read, but never tried yet, that acetic acid (as in good old vinegar) was a debonder for eppxy glue. Hubert 2
ScottsGT Posted August 16, 2022 Posted August 16, 2022 Freeze the parts and tap lightly and pull them apart. Never tried it but I’ve heard freezing CA glue joints makes it brittle. 1
Maker666 Posted January 8, 2024 Posted January 8, 2024 Well, you have a big problem in front of you, I've been there many times myself. I have tried several brands of products to remove cyanoacrylate, and in the end, I have stayed with this ciano glue debonder that I've been using lately, and I'm doing very well.
