PanzerWomble Posted October 26, 2023 Posted October 26, 2023 No ....not an axe .....for years I've been using these adjustable pliers from Bahco . Official name "BAHCO 8" EXTRA WIDE SLIP JOINT WATER PUMP PLIERS - 8231" There about $30 or there abouts , adjustable, and have removed lot of stuck on screw on lids, paint , superglue etc . Can even be used to tighten up plumbing fittings if. you're out of zone ! 3
dodgem37 Posted October 26, 2023 Posted October 26, 2023 Run it under hot water. I use an InSinkErator. Sincerely, Mark 1
DocRob Posted October 27, 2023 Posted October 27, 2023 23 hours ago, PanzerWomble said: No ....not an axe .....for years I've been using these adjustable pliers from Bahco I've used similar ones, but once I broke a jar of Tamiya grey, which was enormously obstinate. Cheers Rob 1
ScottsGT Posted November 19, 2023 Posted November 19, 2023 I turn the bottle over and smartly smack the top firmly on my bench about 3-4 times. Usually breaks it loose. 2
belugawhaleman Posted November 19, 2023 Posted November 19, 2023 I've tried putting the bottle upside down in warm water.... Then pliers.
BlrwestSiR Posted November 19, 2023 Posted November 19, 2023 Gunze makes a tool specifically for removing stuck paint bottle lids. It works on Mr Color( both acrylic and lacquer), Tamiya and AK bottles. I have it and it has proven very handy. I'll grab a pic when I get home. 1
Maker666 Posted March 20, 2024 Posted March 20, 2024 Cut the bottle, and move the paint to a new one. If you've had the problem once, it will happen again many times. When you change the paint bottle, if it is acrylic, add a few drops of paint revitalizer to recover the paint a little. 1
PeteinLincs Posted March 28, 2024 Posted March 28, 2024 Those pliers are commonly called plumbers pliers or Stilsons. Wind a rubber band around the bottle to aid your grip too.
Spitfire Posted March 28, 2024 Posted March 28, 2024 I have always known them as swan necks, mainly used for plumbing. Cheers Dennis 1
