Peterpools Posted September 20 Share Posted September 20 Carl I'm right with Chris .. shading and details look mighty good. 1 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted September 20 Author Share Posted September 20 Talk about tiny parts. The surfboard has PE wing nuts to hold it in place The commander's cupola has 16 brackets that go around the vision blocks. Unfortunately I've already knocked off and lost one of them. 9 Link to comment Share on other sites More sharing options...
CANicoll Posted September 20 Share Posted September 20 I think you were brave to even try putting them on! 2 1 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted September 20 Author Share Posted September 20 16 minutes ago, CANicoll said: I think you were brave to even try putting them on! I did debate it. My plan was to do one row and if I didn't lose any, the second. That worked out but then I knocked a couple off attaching some other parts. I found one but not the order. 4 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted September 21 Author Share Posted September 21 Link and length tracks. I painted them in Dark Iron. First side is done. A bit fiddly. But I think the second side will go easier knowing how these went together. 10 Link to comment Share on other sites More sharing options...
Peterpools Posted September 22 Share Posted September 22 Carl WOW. progress is awesome and the PE would have driven me crazy. Losing just one piece is an incredible feat and they do look 'oh so good'. 1 1 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted September 24 Author Share Posted September 24 Peter, I'm using a pick up pencil for the really small PE bits. It's like a regular pencil but instead of lead, it has a slightly tacky centre. Just touch the PE but and it'll pick it up. Then position it and the surface tension from the CA is usually enough to unstick the part from the pencil. It helps keep parts from doing the 100cm tweezer long jump. 6 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted September 24 Author Share Posted September 24 (edited) Second set of tracks is done. This one went much easier than the first one. Edited September 25 by BlrwestSiR Fix typo 9 Link to comment Share on other sites More sharing options...
Peterpools Posted September 26 Share Posted September 26 Carl I've been using the pick up pencils for a good while and they help a lot but I find they need a sharp tip to work on the smaller parts or even with CA on the model, the PE won't come off the pencil. Right with you and haven't found anything better. Sure, wish I knew how to do levitation. Second set of tracks look mighty good. 2 1 Link to comment Share on other sites More sharing options...
KevinM Posted September 28 Share Posted September 28 That is coming along Nicely Carl! 2 1 Link to comment Share on other sites More sharing options...
DocRob Posted September 29 Share Posted September 29 Nice progress, Carl, like these late Sheridans, with all the added bits and pieces to make them still usable. I wanted to buy the kit some time ago, but forgot about, until I saw your log. I used wax pencils as well in the past, but never liked them too much. I still prefer tweezers for handling PE, but rarely the very sharp pointed ones. Cheers Rob 3 1 Link to comment Share on other sites More sharing options...
KevinM Posted Thursday at 10:37 PM Share Posted Thursday at 10:37 PM Carl what you got three benches going at once or have you upset momma with the kitchen table? 2 1 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted Friday at 03:09 AM Author Share Posted Friday at 03:09 AM Kevin, I have 2 benches. One is 8 ft long but my sons have taken over half. The other is about 4 ft as well. But there's lots of floor space. Well, there would be if it wasn't full of open model boxes: You can see where my carpet monster likes to sleep when she's not in my lap. 8 Link to comment Share on other sites More sharing options...
Peterpools Posted Friday at 02:15 PM Share Posted Friday at 02:15 PM Carl And I'm willing to bet, you know where everything is without having to look for it. For us seniors, just remembering I we put something down as we're working on it. is a full-time job. 4 Link to comment Share on other sites More sharing options...
BlrwestSiR Posted Friday at 07:07 PM Author Share Posted Friday at 07:07 PM Generally I don't have any trouble finding my tools as I know where I've left them. Of course I've jinxed myself now. The problem is when one of mys sons borrows one and then I have issues finding it. Because they don't know where they've put it either. Which is when I remind them to not touch my stuff!!! 2 3 Link to comment Share on other sites More sharing options...
Peterpools Posted Friday at 11:04 PM Share Posted Friday at 11:04 PM Carl Good luck on that one 😉 1 1 Link to comment Share on other sites More sharing options...
belugawhaleman Posted Friday at 11:12 PM Share Posted Friday at 11:12 PM On 9/24/2024 at 6:36 PM, BlrwestSiR said: Peter, I'm using a pick up pencil for the really small PE bits. It's like a regular pencil but instead of lead, it has a slightly tacky centre. Just touch the PE but and it'll pick it up. Then position it and the surface tension from the CA is usually enough to unstick the part from the pencil. It helps keep parts from doing the 100cm tweezer long jump. I use those wax pencil things as well...bought on Amazon. I find that if you rub a little off the tip before use they stick better. I took me a long time to find a sharpener that worked well on these...it's easy to break the tip off when sharpening. Nice work on the Sheridan! 1 1 Link to comment Share on other sites More sharing options...
