Peterpools Posted October 19, 2024 Posted October 19, 2024 John Looking good, nice work on the front office. 2
JohnB Posted October 19, 2024 Author Posted October 19, 2024 Adding the instrument panels was a tedious process, especially the top panel. Thanks to strip styrene and CA everything is installed. I just hope they STAY there.🤪 2
JohnB Posted October 20, 2024 Author Posted October 20, 2024 Finally got the instrument panels and windscreen attached. Attaching the wings is next. Not what I'd call perfect fit!!!🙄 7 2
Spitfire Posted October 21, 2024 Posted October 21, 2024 You are doing a fine job there John, keep up the good work. Cheers Dennis 5
KevinM Posted October 21, 2024 Posted October 21, 2024 14 hours ago, JohnB said: Not what I'd call perfect fit!!!🙄 I see some more styrene in your future.I am sure you will get there John 5
Peterpools Posted October 21, 2024 Posted October 21, 2024 John Nice progress and I'm right with Kev. Not sure if taping the wingtips to each other will both remove the wing fillet gap and increase the dihedral which seems to be too shallow or just strip plastic is the remedy. I guess it all depends how the dihedral actually looks to you, as I'm only guessing from the overhead photo. In any case, my money is riding on you to work right though the issue at hand. 3
JohnB Posted October 21, 2024 Author Posted October 21, 2024 4 hours ago, Spitfire said: You are doing a fine job there John, keep up the good work. Cheers Dennis Thanks Dennis. It has had it's moments! 🤪 2
JohnB Posted October 21, 2024 Author Posted October 21, 2024 2 hours ago, KevinM said: I see some more styrene in your future.I am sure you will get there John I put in some styrene strips last night so this morning I'll trim the excess and see what else is needed. 2
JohnB Posted October 21, 2024 Author Posted October 21, 2024 1 hour ago, Peterpools said: John Nice progress and I'm right with Kev. Not sure if taping the wingtips to each other will both remove the wing fillet gap and increase the dihedral which seems to be too shallow or just strip plastic is the remedy. I guess it all depends how the dihedral actually looks to you, as I'm only guessing from the overhead photo. In any case, my money is riding on you to work right though the issue at hand. I'll go see how well my "adjustments" have helped and post a couple more pics. 🙄 3
JohnB Posted October 21, 2024 Author Posted October 21, 2024 I think the elastic helped with the dihedral. Next I'll trim the strips I put in and do some puttying. 9
Martinnfb Posted October 21, 2024 Posted October 21, 2024 Looking good John. Are you using Hasegawa cowl ring? 2
JohnB Posted October 21, 2024 Author Posted October 21, 2024 After trimming the strip plastic I decided to try to get a bit more dihedral. I'll let it sit for a while then go back and see how it looks now. No Peter, the cowl ring is from the kit. 5 1
JohnB Posted October 21, 2024 Author Posted October 21, 2024 Puttied up and waiting for sanding out. 6
JohnB Posted October 21, 2024 Author Posted October 21, 2024 43 minutes ago, FullArmor said: lots of sanding to do😁 Yes indeed and NOT my favorite thing to do. 🙄 1 3
FullArmor Posted October 21, 2024 Posted October 21, 2024 This somehow reminds me when i bought the cheapest 1/16 scale tank kit and tried to modify it to decent shape😅 1
JohnB Posted October 21, 2024 Author Posted October 21, 2024 1 hour ago, FullArmor said: This somehow reminds me when i bought the cheapest 1/16 scale tank kit and tried to modify it to decent shape😅 LOL One of THOSE builds! 1
JohnB Posted October 21, 2024 Author Posted October 21, 2024 Got the sanding and priming done. Not anywhere near perfect but it'll have to do. 6
Peterpools Posted October 21, 2024 Posted October 21, 2024 John Nice work on the wings, fillet seams and getting the dihedral to look good. Not hard to believe you have the Old Revell FW 190 ready for the paint shop. 1
JohnB Posted October 21, 2024 Author Posted October 21, 2024 11 minutes ago, Peterpools said: John Nice work on the wings, fillet seams and getting the dihedral to look good. Not hard to believe you have the Old Revell FW 190 ready for the paint shop. When I started this build I had no idea what problems with fit there would be. If I'd known it would likely still be on the shelf! LOL It appears at this point it will turn out okay but I'm not counting my chickens just yet! 3
Peterpools Posted October 22, 2024 Posted October 22, 2024 John You are taming the beast and looking good. 2
JohnB Posted October 22, 2024 Author Posted October 22, 2024 1 hour ago, Peterpools said: John You are taming the beast and looking good. Took lots of taming too! LOL 2
