Just thought I'd keep the group in the loop of what's going on in my life!
Not the most active member, but I do stick bits of plastic together occasionally.
Got diagnosed with Colon cancer in October, going for surgery on the 17th of November, then after initial recovery I hope I'll have some time to spend at the bench! Should be off work minimum for a month, then we'll see what chemo will do.
It's a bummer, because I'll have to stop flying until cleared again, which may take a year, and I was JUST granted Pilot Examiner status... oh well.
My public service message is this: If you can get a colonoscopy, get one! Apparently my cancer started as a polyp that grew into a cancer over several years, although not extremely severe, still bad enough. Colonoscopies can detect and remove the polyps before they turn cancerous. Even if they are a bit undignified... You also get some wicked drugs!
Harald
  • Sad 2
Bummer, Winnie! My dad had colon cancer, too. He had surgery to remove the affected chunk and never had to go on chemo, thankfully, and made a full recovery. Very high rate of success, so I have high hopes for you!! Due to my dad, I started the "scopes" much earlier than usually recommended, and all clear so far!
Tim
I'm  recoveing from surgery, and as far as we know (prior to pathology) we're doing good!
Hurts a bit, but we're off the stronger painkillers (had T3 for a bit), now onto regular Tylenol/Acetaminophen, which is good. also eating normal foods which is even better.
May get to the banch today!
H.
H.
Glad to hear you're recovering well😀
Cheers!
Some benchtime achieved!!
Mostly pain free, but still some occasional bouts of pain. But I can sit at the bench comfortably here and there which is nice!
