This is a kit I have been working on for two weeks now. It's the forthcoming HK Models Gloster Meteor Mk 4.
Almost ready for the high speed silver coat. I will finish this in a Dutch livery. This is the first jet I am working on for many years. I really enjoy it.
Cees
James,
Apart from the seat cushion and seatbelts everything is sprayed tarblack and anthracite with some
Drybrushing. Only the gunsight left before the canopy will be fitted.
Want to finish this soon.
Cees
Update time
Spending more building than posting updates. This kit is really fun.
And big, the unavoidable beercan photo is included.
Cockpit with Eduard belts. I replaced the plastic reflector glass with a
Piece of clear acetate.
Speed is what I need.
Cees
That's coming on real well. Goes to show what a great fit things are generally.
So far the trailing edges of the wings need some sanding te get them flat. No problem really.
Everything fits beautifully.
Cees
Short picless update
The undercart has been assembled. Bit tricky as the wheels are difficult to mask as the structure
alsmost completely surrounds it. Canopy has been masked too. Only the intakes to do and then it's
airbrush time.
Cees
Longish picloaded update
I want this build to be a quick one. This build is almost completely out of the box. Apart from the
Intakes that is. Fisher has an intake correction set out as Ben Summerfield is using on his build.
I wanted to do an experiment using beercan aluminium. Well Grolsch didn't work as the inside
Colour was green. Back to good old Heineken, after emptying the contents in the old fashion way
( hic). The interior colour was what I was looking for. Sometimes sacrifices have to be made...
First I made a paper template, after that the can aluminium was cut to the same dimension.
Making use of the existing curve. Using Rosie the Rivetter tool I added a representation of rivets.
With tape I kept the shape. I am very pleased with the result, the aluminium gives just the right
Sheen when the whole lot is cemented in place. Great stuff this aluminium. Never used it before
But I certainly will more often in the future.
The undercart has been assembled as well, with some tricky masking. Hope it works.
Cees
Guest Kagemusha
Great work, what is this Heineken and where do you buy it?
Well it's just a worldfamous beer distiller haha. But you could use
any can as long as it's natural aluminium insided (Coca Cola?).
Really pleased how the intakes turned out, they really give a authentic
sheen when looking inside with a glimpse of the rivetting lines.
Cees
Ridiculously short update:
Canopy has been sprayed black, undercart sprayed steel. Next aluminium coat (probably over the weekend)
Next update will have pics hopefully.
Cees
Well, next update hopefully shows a miraculous recovery. The plan was to spray the fuselage
Aluminium. It turned out in places the coat was too thick and parts of the delicate details were
Flooded or there were runs all over. All I could do was to strip off the paint. It looks a Meteoric mess right now.
Have to sand back some spots still.
Hope tomorrow will be better. Not all modellers on LSM are great airbrushwielders, I confess LOL
Mantra: practice practice ohm ohm
Cees
Ben, are you psychic? It actually worked out in the end, the fuselage and innerwings are now sprayed.
The nacelles and outer wings follow later due to the size of the Meteor. The Dutch Decal Meteor set
Also arrived today. Watch this space.
Cees
Cees
Must be all those positive vibes I'm sending your way.
