Dear modellers,
I´d like to present here our newest 1/32 kit of the Romanian IAR-81C:
For Azur-Frrom company, our foreign partner, we are producing model of the probably most famous Romanian fighter plane, the IAR-81C in 1/32 scale. The model is in five frames of grey plastic and one frame of clear parts, there are also detailed resin parts, photo-etches and two decal sheets containing five different planes of the Romanian air force. The whole model was designed using the 3D technology, the main parts – fuselage halves, wing and the tailplanes - are moulded in short-run type moulds. What distinguishes this model from the short-run production is the remaining parts in two frames. These are moulded in metal moulds in excellent quality. This gives the model a highly detailed interier, engine and undercarriage. The control surfaces, ie the rudder, elevator and the flaps, can be attached in different positions. A slim booklet of sixteen pages, printed in full colour, will be your companion throughout the construction.
Photos 01, 02
IAR-81C fuselage with fine engraved panel lines and fasteners:
01
02
Photos 03, 04
The wing with some overlapping panels and deep and detailed wheel wells:
03
04
Photo 07 shows the frame with control surfaces. On close-up views 05 and 06 you can see realistically sagged fabric on the construction of the ailerons and flaps.
05
06
07
Photo 08 – Overall view of the first shots from metal moulds:
Photo 09 – Cylinders of the two-row radial engine made of four parts:
Photo 10 – Detail of the head rest:
Photo 11 shows mainwheels of the undercarriage, tires with the tread and the brake discs with a relief. On the right the reduction gear casing of the engine is visible and partially also its rear part:
Photo 12 – the second of the metal moulds for the IAR-81C model. Exhaust and carburettor intake on the left, small parts for the cockpit in the middle of the mould and u/c well parts on the right:
Photo 13 – parts of the cockpit:
Another parts of the cockpit are on photo 14, the bulkhead ahead of the instrument panel and the cockpit floor:
Photo 15 shows in detail the instrument panel, separated (as in reality) to three parts. There are decals for the instruments on one of the decal sheets:
Photo 16 - detail of the cockpit floor:
Photo 17 – smaller parts of the u/c covers and the trim control wheel:
Clear parts, the canopy is in two pieces and there are also two clear parts for the gunsight, the sun-screen and reflector glass. We have forgotten one of them and therefore it is injected separately:
The decals and photo-etched parts. There are five different markings. It was prepared with the help of probably the greatest expert on the Romanian AF, Mr. Radu Brinzan:
Resin parts – exhausts, gunsight and two types of carburettor intake. The bigger one is fitted with anti-dust filter with fine mesh on its surface:
Instructions printed on glossy coated paper and stapled to a slim booklet will guide you through the construction:
The model is, as stated above, produced exclusively for our foreign partner. But, thanks to friendly agreement limited ammount will be available also to Czech modellers . The model is just being packed and we will sell it for the first time on 14 June 2014 at Zlinkit model show.
a beautiful aircraft and subject matter Petr.
details look very well done.  this kit will find it way to my bench.  here I go again, some more stash thinning.
thanks for sharing!
This really looks good, Petr! Almost can't believe it's short-run injection moulded! Very fine details on the plastic!
Good work!!
(That promises something for the Tempest!!! kwijl.gif )
