Looking good Jeroen!
Love the subtle weathering.
Well done.
The little silver scratches on the radio in the back are feeling a bit off but since they are covered by the fuselage don't bother cause no one will see eventually. :ph34r:
Except for me cause I know....  ;)
Marcel.
Well done.
Marcel.
Hihihi,
I already removed them!
Thnx Marcel,
The fuselage is closed and the radio sits pretty deep in the rear fuselage, making only the fronts of the radio's visible.
In the meanwhile i finished building the Bristol Mercury engine:
CBC9F6F9-3AEB-414F-811A-900E2534C448_zps
6FA52A2B-81E4-4810-A40A-EB83EC12EF63_zps
48AD8F89-E48C-40F7-BAA9-D72017244B96_zps
This is so cool. How did you find the fuselage lined up? No steps?
Can't wait to see the PZL they release.
Ok. Meeting some resistance. The engine is slightly too big in diameter for the cowling. So I sanded away the connection rim inside the cowling and sanded the entire cowling way thinner all around. And now it fits!
E8ACB206-DDFD-4039-9677-0F6C64B5DB46_zps
What you see here are 5 parts:
5A91DC90-1B9C-45B3-9285-BC2C75EB67EE_zps
And added the second wing too:
48E60CB4-4B2F-4850-BCD1-28A61B13ACF9_zps
So far it's a pretty smooth ride!
Cheers,
Jeroen
That looks great. Real unusual that Silverwings would make a booboo like that with the engine and cowl.
I reckon this will be done in a week.
It reminds me of the Taurus engine i tried to fit in the WnW cowling of the Fokker E.III. It's an easy fix. Just a little work to make it look ok.
Ok, some good news and some set back.
First of all I managed to screw up the shaft. Or shaft the shaft in proper english.
I got some paint on it (the unwanted kind) and dipped it in aceton. This caused the parts to become... rubber!
Mailed Silver Wings and a new one is already on the way!
36ABB318-A619-41B3-999D-B07AF695A29D_zps
But this weekend i did manage to mask and fit the canopy and add the wheels:
DA7CD303-5DEB-4C02-A425-04E623F5F781_zps
But then I noticed an error I made. So be wary of following my lead. The instructions tell you to make the upper cockpit framing all with tubing. 6 tubes going up and one small horizontal one connecting them. Like so:
F12EE524-F212-4681-B449-7503CCE965AC_zps
However, the only tubes you need to make are the two 90 degree vertical ones behind the seat and the two 30 degree ones going back down, making an inverted V.
The other tubes are integral part of the canopy clear part!
So I removed them (while the canopy was glued) and fixed it. Pretty happy with my handiwork:
FDC82E86-CA2D-4E66-907B-415B42E5B7E7_zps
Just so damn good. Silverwings' do some impressive stuff.
Oh, I found the PE fret for your Hawker Hart. I'll send it over.
Noise! You've found it's hart!
Some more small progress.
The Master barrels sets arrived. All squashed and flattened in the mail.
So i looked for a rod with exactly the right diameter to round it out again.
The solution was found in a large paperclip that fitted the bill.
88F905B2-4567-4339-B611-289DC5D527C5_zps
Then i fastened the barrels in a drill bit and sanded the hexagon bold off.
38C57603-B4D1-4CA0-B19D-4284CDEB8B7F_zps
E7E6A2E4-0243-4672-A7A4-10DDE7606F93_zps
Also finished masking the whole canopy, with the opening part both inside and outside.
AD8A40B1-00E8-41C4-85B7-06D926298C7B_zps
