Hi Gus,
That is still open to debate. Perhaps I will try Jeroen's way on his Hurricane by using PET-plastic from packaging. With strip I will
make a ledge for the transparency to fit on to sit flush with the wingsurface. But as Tom says, small updates like this can get the
blocked modelling juices flowing again.
Cees
Cees,
Regarding the cockpit glazing - I have a spare ID Models Lancaster cockpit if it's of any use. It's the new type of plastic that Tigger uses so won't yellow like the old stuff. If you want it, it's yours.
Tom
Fashioning wingtiplightcovers from thick perspex. With a drill a hole is....well...drilled to represent a clear bulb.
The front covers will have a similar set up but with the cavitties filled with red and green paint. Then some serious
hacking is needed to shape the wingtips. First time I used this glue, it works great.
Cees
No pics this time but all four wingtip lights have been made from perspex. Carving and sanding is underway to shap them
to the graceful tips. After that the nacelles will be under investigation.
Cees
Indeed, this Perspex used is very hard and difficult to sand. But using a craft knife you can carve away the big bits and smooth it
with a very coarse file from the toolchest. After polishing it should be fine.
Tom, perhaps the tape is a bit too pronounced but another coat of Mr Surfacer should tone that tone a bit.
I think so too. Perhaps I will run a rivetting tool along the strips before coating them with a final layer of Mr Surfacer to represent the stitches.
Will do some experimenting first (not on the Manchester).
Cees
As mentioned before the Manchester will have a closed fuselage. To attempt building a full interior bombay nearly cost me my motivation. The doors have been joined again for final shaping including glueing a small section back on after the first attempt at removing the doors was too short.
It does Tom. I am quite relieved that I have abandoned that that hurdle.
The Manchester is interesting already with closed doors. As soon as the Lanc will be out I will do that one with the doors open.
Cees
Working on the panellines. With pencil the lines are marked out. When everything is neat and square they will be scribed. The join between the centre section and outer wing was covered with a metal strip. I will represent this with aluminium tape.
Cees
Both upper wings have the panellines now marked out. The A3 cutting mat shows the size. With the curvature of the wings it is
difficult to get the chordwise lines straight. Some Dymo tape will sort that out.
