GusMac Posted August 2, 2025 Posted August 2, 2025 Wow, they even look a step up from Friuls. Very impressive. The chromed look would be fine if you fancy doing a pimped Magach! 1
belugawhaleman Posted August 2, 2025 Posted August 2, 2025 7 hours ago, BlrwestSiR said: I picked up a set of Magach 6B tracks made by San Xin. They're cast zinc and come with pre-cut brass wires to assemble them. Pretty much no clean up needed. No flash or ejector pins marks, no drilling out the linkage holes. Assembly of both track runs was probably less than 40 minutes. They just went together so easily. Here they are installed on the Magach. I should probably paint or weather them a bit. They look almost chromed. Those tracks look well made, good quality.😀 1
FullArmor Posted August 3, 2025 Posted August 3, 2025 I am building this WOT6 truck. I am using sprues to fabricate painting jig. 5
BlrwestSiR Posted August 3, 2025 Posted August 3, 2025 Great idea on the sprue jig to hold the model. 3
BlrwestSiR Posted August 3, 2025 Posted August 3, 2025 With the tracks on the Magach done, it's given me impetus to continue working on the tank. 5
BlrwestSiR Posted August 6, 2025 Posted August 6, 2025 Assembly is all done. Just some paint touch-ups and decals. 5 1
FullArmor Posted August 6, 2025 Posted August 6, 2025 50 minutes ago, BlrwestSiR said: Assembly is all done. Just some paint touch-ups and decals. Looking good. Please share more weathering pictures soon👍 3
BlrwestSiR Posted August 11, 2025 Posted August 11, 2025 A little 109 love. Started on the squgglies. Excessive paint chipping was unintentional and will need to be fixed. Just as well, after discussions with Martin, Ithr hard wedges on the wing camo will need to be softened a tad. 5
BlrwestSiR Posted August 11, 2025 Posted August 11, 2025 I touched up the paint lifts and finished the mottling. Cowling is just dropped in place, not glued yet. 5
BlrwestSiR Posted August 12, 2025 Posted August 12, 2025 4 hours ago, Martinnfb said: Really nice 👍 Thanks Martin! I wouldn't have gotten this far without your help. 1
BlrwestSiR Posted August 12, 2025 Posted August 12, 2025 Started on the markings. Used some masks that I found for the fuselage and upper wing crosses. Need to see if I have any for the lower wing, otherwise it's decals. 3
BlrwestSiR Posted August 12, 2025 Posted August 12, 2025 Found some underside crosses. A bit old so they were slightly off register which meant I had to align them piece by piece. 6 1
PanzerWomble Posted August 14, 2025 Posted August 14, 2025 Waiting for paint ...Tiffie back up Starting OPR on the underside , gunsmoke , mud thrown up , general grime . It will tone down in 24 hours as the oils properly dry In another note I'm off to the airfield this aircraft was flown from this weekend to meet up with the RAF Harrowbeer Preservation Group. 6
PanzerWomble Posted August 18, 2025 Posted August 18, 2025 Swap and swap again .....just the walkways left to paint ..I love my Silhouette ...& don't tell me the colours are Cattywhompus , I don't trust the instructions 🥷 6
KevinM Posted August 24, 2025 Posted August 24, 2025 I picked this kit up at the IPMS meet for like 10 or 15 bucks the moldings are 1990 and the decals are 2001 the stencils some were giving way.The plane is Lt.Brubaker that William Holden portrayed in the movie "A bridge at Toko-Ri" 7
BlrwestSiR Posted August 31, 2025 Posted August 31, 2025 Last of the decals are on the 109 now. I also touched up the spiral on the spinner. Martin earlier sent me a Revell car door Tiffie for me to kit bash into a bubble top one using the MDC kit. So first step was to engrave the fuselage. 6
BlrwestSiR Posted September 1, 2025 Posted September 1, 2025 The last touches were added to the ZM 109 and time to call it done. With the cowls in place. The fit is pretty good considering they're just placed in position without any magnets or clips to hold them in place. 5
Martinnfb Posted September 1, 2025 Author Posted September 1, 2025 That looks really good Carl. Well done! 1 1
