GazzaS Posted February 7, 2020 Posted February 7, 2020 To put if most simply, do the F-K variants all use the same propeller spinner? Are they all shaped the same? 3
BlrwestSiR Posted February 7, 2020 Posted February 7, 2020 The Hasegawa F and G kits have different spinners and props. Comparing the two, I can see a slight shape difference. Here's the F spinner which is on a dedicated sprue: And here it is compared to the G-6 one. The F spinner is on the right. 2 1
BlrwestSiR Posted February 7, 2020 Posted February 7, 2020 One more pic comparing the back plates. Again, the F one is on the right. As far as accuracy, I couldn't tell you which one is more accurate though. Carl 1 1
Wumm Posted February 7, 2020 Posted February 7, 2020 The F spinner was re-done with that kit, and is the more accurate of the two. The shape and size is a better representation; as are the prop openings, which pinch slightly at the base. S 1 1
GazzaS Posted February 7, 2020 Author Posted February 7, 2020 I'm building the F right now.... and the spinner just doesn't look correct to me. Sorry... it's such a minor thing... but it really gnaws on me. 3
Wingco57 Posted February 7, 2020 Posted February 7, 2020 In that case you should be able to point out the "inaccuracy"? If it is just a feeling, ignore it then, perhaps it's based on earlier reviews. When the Hasegawa kit was first released the spinner was the weak point. If they have retooled it with the F, then what's the problem? And there is always the aftermarket. 2
GazzaS Posted February 7, 2020 Author Posted February 7, 2020 1 minute ago, Wingco57 said: In that case you should be able to point out the "inaccuracy"? If it is just a feeling, ignore it then, perhaps it's based on earlier reviews. When the Hasegawa kit was first released the spinner was the weak point. If they have retooled it with the F, then what's the problem? And there is always the aftermarket. Unfortunately parabola's and other advanced math are beyond me.... but I can't say that this: Looks like this: Obviously, such pieces were made on and English wheel, or with a metal shaping power hammer. so there may have been variations. 2
