Hey guys
  Here are some pictures of the Cat D8H I'm doing on Unigraphics NX11.  I have access to  UG while my wife is working at home for FCA (Chrysler). So I've been working on the computer instead of my work bench and I'm trying to get everything done before she has to go back to work at the Tech Center. So here they are.
20200914_193516.jpgthis view shows the D8H on a 3 axle Loadking drop nose lowboy trailer being pulled by a lloonngg! Pete 359 heavy haul tractor.
20200914_193536.jpgsame thing from the rear. It still needs a lot of work to get it to be done.
Ron G
Hey all
  Here are some more pictures of the Cat D8H dozer.
20200915_180852.jpgside view of the D8H.
20200915_180947.jpgthis view shows the body details and the blade all in preliminary status.
20200915_180914.jpgthis view shows the rear body details and tracks.
20200915_181040.jpgthis view shows the tracks a little better.
20200915_181014.jpgthis view shows the undercarriage detail in the preliminary stages. Well that's it for now be back with more soon.
Ron G
Hey guys
 I found this model on the internet. It's a Cat D11!...BiiiG... It's a pretty good model, just needed some tweaking here and there. I had to replace the crappie simple tracks that it had. So I  took my D8H tracks and up sized them to fit, now it looks proper. It actually has the engine modeled up in it. But it's just a sheet body not a real solid model, so I'm not sure if I can print it, we'll see. So here are some pictures for you to look at.
20200916_192056.jpgshe is definitely a BIG MOTHER! But it does fit on the 4 axle drop nose lowboy trailer, barely.
20200916_192116.jpgside view of the D11.
20200916_192136.jpgview from the rear.
20200916_192033.jpgthis view shows the D11 next to the D8H, big difference. Now I just need to finish up the D8H. Be back soon with more updates.
Ron G
Hey all
  I've been working on the D8H Cad model some more. I have the D352 engine just about done, still have a few large items to do plus all the plumbing. I have the blade and the blade arms almost complete, still need to do the blade tilt cylinder and the plumbing. Here are some pictures for you to look at.
20200922_165301.jpgfront isometric view.
20200922_165149.jpgrear isometric view.
20200922_165223.jpgthis view shows the grill and all gazillion holes I had to put in.:icon_eek::omg:
20200922_165242.jpgthis view shows the operator area, still have a few controls to add here.
20200922_165204.jpgview of the D352 Cat engine and all tge bolt heads I added ( I lost count:wacko::blink:
20200922_165131.jpgside view of the engine. I still have to make the transmission, fuel injection pump, hydraulic pump, water manifolds, etc., etc.
20200922_165112.jpgview from the other side of the engine with more bolt heads...lol  Well that's it for now be back with more updates soon.
Ron G
Hey all
  Here are some update pictures of the Cat D8H. Jeff you wanted a R.O.P.S. and here it is, it still needs the attachment brackets and hardware. I added the Cat logos and lettering to the sides, front and rear.
20200928_143424.jpgfront isometric view showing the R.O.P.S., blade lift cylinders and tilt cylinder.
20200928_143444.jpgrear isometric view showing the battery box next to the seat and in front of the R.O.P.S.
20200928_143404.jpgtop isometric view.
20200928_143301.jpgside view.
20200928_143321.jpgfront view.
20200928_143154.jpgrear view.
20200928_143343.jpgtop view showing the blade, lift cylinders, tilt cylinder, and attachment mechanism.
20200928_143221.jpgside view of the Cat D352 engine and transmission.
20200928_143239.jpgleft left side isometric view of engine.
20200928_143126.jpgright right side isometric view of engine. I still have several things to add to the engine and I also have to do the rear rippers. Well that's it for now be back with more soon.
Ron G
Hey all
  Well It's finally finished!!!  The Cad model that is, here are the final pictures for you to look at.
20201005_175920.jpgfront isometric view.
20201005_175808.jpgrear isometric view showing the rippers installed. Added wire mesh and roof to the R.O.P.S.
20201005_175640.jpgleft side view showing the entire length of the Dozer.
20201005_175723.jpgfront view showing the front and rear lights added.
20201005_175521.jpgright side view.
20201005_175742.jpgtop view showing the blade and rippers.
20201005_175501.jpgthis view shows the front lights a little better.
20201005_175705.jpgthis view shows the (2) batteries and cables, also the rear lights. Now all I have to do is actually finish the model kit.:rolleyes:;):D
Ron G
Excellent !  (Although, given the size of your truck and trailer, I’d have said the D-11 was more appropriate to fill the flat bed ;))
Hey  Hubert
 Actually the D8H just barely fits on the 3 axle trailer with the rippers on it. I'll post some pictures of it on the trailer tomorrow.
Ron G
  • 2 months later...
Hi guyes
Just found this site and thought I would20201202_192210.thumb.jpg.bed861b3b5e85d71447aadd15ae59bf3.jpg20201213_140735.thumb.jpg.fe9feadc0408e1a47ce1c45eb5e8bd3e.jpg thought I´d show you my version of the AMT D8. I constructed and 3D printed the tracks, cab and lift cylinders myself and a couple of other small additions including track tensioners. Might add some more details later.
On 9/29/2020 at 12:11 AM, CrankyCrafstman said:
Hey all
Ron G
What 3D software are you using? I mostly use Inventor..
Hey Hj]orleifur
  I'm  using Unigraphics NX16, my wife works for FCA (Chrysler)  and is furlowed at home because of the Covid crisis. So ive been using her laptop setup to do my designs. Sad thing is once she goes back to work it's all gone:(
Ron G
14 hours ago, CrankyCrafstman said:
Hey Hj]orleifur
  I'm  using Unigraphics NX11, my wife works for FCA (Chrysler)  and is furlowed at home because of the Covid crisis. So ive been using her laptop setup to do my designs. Sad thing is once she goes back to work it's all gone:(
Ron G
Hey Ron
I guess you could save the parts as .sat, .iges or similar. Then you could open them in any 3D program later on...
