belugawhaleman Posted July 2, 2020 Posted July 2, 2020 Some pics of my Renault ft build. I've finished the interior and engine bay and closed up the hull. 4 1
belugawhaleman Posted October 2, 2020 Author Posted October 2, 2020 Here's some photos of my Renault ft nearing completion. I used tamiya clear flat lacquer decanted From the can and I had some issues with frosting. Most of the offending frost was removed by gentle Polishing with a damp cloth. I still need to do the tracks and final details to finish the beast. This is first model I will complete in many many years. I used to use testers flat from the spray can with much better results. I'll have to find a solution to the clear flat issue. Anyway, I think it still looks ok. 7
DocRob Posted October 2, 2020 Posted October 2, 2020 Definitely looking more than ok. Can't wait to see it finished. I use Pledge with added Tamiya flat base for flat varnish. works perfect for me and while adjusting the mix, I get all shades of flatness with this combination. More than 35-40% Flat base in the mix will lead to frosting effects though, but 35% is perfectly dull. Cheers Rob 1 2
belugawhaleman Posted October 2, 2020 Author Posted October 2, 2020 Thanks, and thanks for the tip. After these photos, I thinned out my clear flat with tamiya lacquer thinner and applied a wetter coat of clear to some of the problem areas and it worked like a treat! In the future I will try less air pressure, and apply a little wetter. Also I think I'll use my Paasche H airbrush. I used my H for the clear gloss and it worked out ok. Anyway, like I said before this is a first attempt at a model in about 20+ years and it is my re-learning modeling experience 3
Bomber_County Posted October 4, 2020 Posted October 4, 2020 Really nice build, I hear your concerns on coming back to the hobby......congrats 2 1
belugawhaleman Posted October 4, 2020 Author Posted October 4, 2020 Thanks guys. Here are some pics of the tank with tracks on. I didn't quite get these right. I'll try something a little different on my next build. Real ft pictures don't seem to be as rusty! I'll think ill try a dark iron Paint on the surface of the tracks next time. I used tamiya hull red on the inside of the tracks and spaces between the links after which I oversprayed with Vallejo rust. I then dry brushed with tamiya metallic gray the edges of the cleats but this doesn't show well in the pics. The markings are for a Brazilian tank of the 1930s. 4
