Quintillius Posted December 20, 2021 Posted December 20, 2021 I am making rail track curves for my model locomotive.The sleepers are 9x9mm and the rails are 4x9mm. All pinewood. The diameter of the curve is 2m. I am able to make the curve, however there is some tension present. Is it possible to spray the wood with water and then dry it using a hair dryer in order to preserve the curve? Or do I need other techniques. Can you guys give me advice.
Bomber_County Posted December 21, 2021 Posted December 21, 2021 I reckon make a jig, soak the wood, clamp the rails in and leave for a week…….drying with just a hairdryer will not be enough IMHO…..
Martinnfb Posted December 21, 2021 Posted December 21, 2021 Steam or hot water works very well. Then drying in microwave . 1
Guest krow113 Posted December 21, 2021 Posted December 21, 2021 So the rails are wood? Your post doesnt make a lot of sense. Steam and soaking are 2 ways of preparing wood to be shaped. A jig to hold the shape a little over curved so it will ease back to where you want it. Lots of ways to do things.
Quintillius Posted December 21, 2021 Author Posted December 21, 2021 Please remember that the whole rail track set is a curve and has a diameter of 2m. There is no way to steam it or... putting it into a microwave. 1
Guest krow113 Posted December 21, 2021 Posted December 21, 2021 41 minutes ago, Quintillius said: Please remember that the whole rail track set is a curve and has a diameter of 2m. There is no way to steam it or... putting it into a microwave. Getting even more vague. Perhaps a pic will help to see what is going on as it is far from clear what you are asking.
Martinnfb Posted December 22, 2021 Posted December 22, 2021 My bad , I missed out on the size. Wet sauna perhaps Just kidding, pictures would really help.
BlrwestSiR Posted December 22, 2021 Posted December 22, 2021 The best way to bend the wooden tracks is to steam it and then bend it around a form/jig until it sets. To do this, you can make a wood steamer using a length of PVC pipe long enough for the tracks to fit inside. Put the tracks inside the pipe. Place one end over a kettle spout and cap the other end. Slowly boil water in the kettle so that the fills the pipe with steam. Carefully remove the track and clamp it into place around your jig/form and leave it there until it cools and sets. This is commonly used for bending wooden strips used in canoe building so there should be some reference videos available on YouTube etc. Hope that helps. Carl 2
Landlubber Mike Posted December 22, 2021 Posted December 22, 2021 I bend wood when building wooden ship models. There are a variety of ways I do it, but it depends on the wood, size, shape, etc. You can: soak in water and pin to a forming jig and let it dry soak and microwave (or soak in hot water) and shape it soak and use a hair dryer use a rolling tool to put a bend into it soak the wood and use a heating element to form the curve Given the size, I'd consider soaking the wood, then clamping it around a forming jig. Let it dry and hopefully it's in the shape you want. When I am trying to shape hull planks, I will soak the plank, then pin it to the hull. The next day it should be dry and in the shape I want. I can't necessary do this with certain dense woods like ebony, but instead found I need to use that heating element tool in the last picture to get a fixed curve in the wood. I'm assuming the pine you're using a wood will be much easier to bend. Just make sure to soak and then bend slowly. Sometimes it might take multiple tries to get it into the shape you want. Sometimes the wood will spring back a bit, so you might need to soak and clamp to a jig with a touch more curve than you want so that when it springs back, it's in the shape you need. 1
Guest krow113 Posted December 22, 2021 Posted December 22, 2021 1 hour ago, Landlubber Mike said: I NEED this roller...
biggtim Posted December 22, 2021 Posted December 22, 2021 1 hour ago, krow113 said: I NEED this roller... You can do that to thin metal, and damp wood veneer, pretty easily with a smooth piece of pipe and a very flat, hard surface. You just lay the sheet goods on the surface and roll the pipe or rod over it while pressing down hard. the more times you do it, the more it curls. I'm cheap, so I make do with what I can find in the garage! 2
Landlubber Mike Posted December 23, 2021 Posted December 23, 2021 20 hours ago, krow113 said: I NEED this roller... It works really well. I use it a lot to pre-form bends for planking wooden hulls, particularly at the bow. Wet the end of the wood, run it through the roller a few times, and you have a nice curve that makes pinning and clamping the plank to the hull a lot easier. It's a bit pricey on the Micromark site, but you can get it for a better deal when they offer sales and discounts.
