I'm in the market for a 88mm. I'm torn between getting the Dragon kit or waiting for the Trumpeter and Borders kits coming out.
How did you find the Dragon kit going together Brad?
The fit is pretty much perfect, no filler used at all. Along with that, this boxing (number 6523) gives you turned metal barrel, counterweights and top section of the gun. You also get lots and lots of extras as you can do different versions of the weapon and build with the shield on too if you want. I'm almost certain that this boxing would be better than Trumpeters.
