BlrwestSiR Posted December 15, 2022 Author Posted December 15, 2022 (edited) So after getting the lower hull painted, I realized it was the wrong part. I needed to paint the front half of the lower hull to continue assembly. So I got to work on the correct section. Then I could install the assembled inner sections. I then assembled the lower jawbox. The first of the LEDs goes onto this bit. Then it's attached to the lower hull. The front and rear halves can now be joined together. Both mandibles can be added at this point. It's starting to get big. ZM 109 for size reference. Now onto the side panels and upper hull. Edited December 15, 2022 by BlrwestSiR Fix typo 10
CANicoll Posted December 16, 2022 Posted December 16, 2022 5 hours ago, BlrwestSiR said: @CANicoll, there's no interior to the kit. The cockpit and gun tubs are it for internal detail. The "hallway" is more of an optical illusion for the end of the ramp. AHHHH. Ok, got it! Thanks. How is the new job location working out? 3 1
BlrwestSiR Posted December 16, 2022 Author Posted December 16, 2022 Chris, we're still at the store for now. It closes Christmas Eve and then we're spending January packing it up and getting ready to move it for Feb 1. 4
DocRob Posted December 16, 2022 Posted December 16, 2022 The Falcon is looking great, but the ME-109 is no match or have I missed something about it entering hyperspace ? Cheers Rob 1 3
Peterpools Posted December 16, 2022 Posted December 16, 2022 Carl Some mighty good looking progress - just love the weathering you're doing and the Millenium Falcon really is HUGE. Just placing the 109 on top, is a great size comparison. 2 1
BlrwestSiR Posted December 18, 2022 Author Posted December 18, 2022 On 12/16/2022 at 7:16 AM, CANicoll said: That is one HUGE model! The scary part is I don't think it's the smallest Star Wars kit I have. Besides 2 more 1/72 Falcons, I have a Revell 1/2700 Star Destroyer. 3 1
BlrwestSiR Posted December 18, 2022 Author Posted December 18, 2022 On 12/16/2022 at 4:31 AM, DocRob said: The Falcon is looking great, but the ME-109 is no match or have I missed something about it entering hyperspace ? Cheers Rob The 109 entered hyperspace when I used a bit too much force throwing it in frustration 1 4 1
CANicoll Posted December 18, 2022 Posted December 18, 2022 2 minutes ago, BlrwestSiR said: The scary part is I don't think it's the smallest Star Wars kit I have. Besides 2 more 1/72 Falcons, I have a Revell 1/2700 Star Destroyer. Carl, Where do you put these when you are done?? 1 2
BlrwestSiR Posted December 18, 2022 Author Posted December 18, 2022 There's two docking rings on either side of the hull. They're each 16 pieces that need to be assembled. Again, I painted them first. One side completed. Installed into the hull.its just slips in place. No glue required. The Falcon has some battle damage moulded into the hull. I painted the area around it first. I then installed the internal detail piece so it's not a blank hole. Hopefully more tomorrow. 9 1
BlrwestSiR Posted December 18, 2022 Author Posted December 18, 2022 3 minutes ago, CANicoll said: Carl, Where do you put these when you are done?? Chris, that's a good question which I don't have a great answer to. I sort of put them where I can. Case in point, the Bronco Type XXIII I finished a couple years ago sits above our TV. I've got plans for a new display case but can't start on that until the spring when it's warmer. The plan is to build something big enough for the four engine heavies and other oversized models. 7
Peterpools Posted December 18, 2022 Posted December 18, 2022 Carl Super work on the awesome details - they look so good. Not sure if you were kidding about the 109 or that it's headed to the SOD - surely hope not? Negotiating display space hasn't always been easy as we moved a few times over the years. I'm lucky and happy to have a nice area in the house for my display case and the limits of what I can build is limited to making sure the model will fit in it. My studio is for both building and photography and there just isn't any space for an additional display case. At 75, being a realist, just trying to build what's in the stash is a goal and all the kits I've purchased should fit. Looking forward to seeing your new display case for the heavies this spring. 3 1
KevinM Posted December 18, 2022 Posted December 18, 2022 (edited) Well Carl when I built my case it was about $200 Oak and about $400 glass now that's S. of the border to You.I would think for 1/32 heavies you are looking at maybe 24/26" D and still at an angle on there placement inside.The Falcon is coming along Nicely I bought a few months back a 1/72 X-wing(?). Edited January 7, 2023 by KevinM X-wing 3 1
CANicoll Posted December 19, 2022 Posted December 19, 2022 23 hours ago, BlrwestSiR said: Chris, that's a good question which I don't have a great answer to. I sort of put them where I can. Case in point, the Bronco Type XXIII I finished a couple years ago sits above our TV. I've got plans for a new display case but can't start on that until the spring when it's warmer. The plan is to build something big enough for the four engine heavies and other oversized models. Definitely let us see what you build for a display case!! Love the build, and I'd be delighted to try my hand at it, but I just cannot afford the kit! 3 1
BlrwestSiR Posted January 4, 2023 Author Posted January 4, 2023 I thought I'd get more done over the Christmas break but even though I was off, we were busy with family stuff. I finally got the cockpit done. This was mostly applying various decals over some well detailed panels. I had to use a lot of decal solvent to get them to conform. I then painted the figures. I decided to use the crew layout from when the Falcon escapes from the Death Star. This puts Leia and Chewbacca up front, Han and Luke in the gunner seats. To fill the rear seat, I added C-3P0. The rear panel of the cockpit door I felt was a bit too deep to cover easily with the decal so I cut that part of the decal out and painted it. I oddly don't have any pics of the finished panel. Whoops. Finally I painted the canopy after masking it off. At this point, I found a clear stand I'd bought for the Fine Molds Falcon. The fit isn't perfect but it does hold the model so I might use it. 3 3
BlrwestSiR Posted January 4, 2023 Author Posted January 4, 2023 (edited) I painted the recessed bays on the upper hull and added them. The cockpit tube was finished and then I attached it to the upper hull. I then finally added the upper hull to the lower assembly. It's really starting to look like the Falcon. I also got the upper jawbox painted. Edited January 5, 2023 by BlrwestSiR Missed text 9 1
Peterpools Posted January 5, 2023 Posted January 5, 2023 Carl Amazing work and the figures - WOW ... surely brings back memories especially of the days before even VCR's that meant numerous trips to the movies to watch Star Wars with my son. The Falcon does look so good on the stand. 1
BlrwestSiR Posted January 5, 2023 Author Posted January 5, 2023 Thanks Peter. The dynamic pose on the stand is what made me decide to use the figures. The kit stand is fairly static and just holds the model level. I only saw the movie a couple times in the theatres. The first was on a school trip. The second was when they re-released it with the two sequels and did a marathon showing of all three back to back. 1
Peterpools Posted January 5, 2023 Posted January 5, 2023 My wife and I took my son to the movies more times then we can remember and when the third episode was released, we sat in the movies and watched all three back to back. Great memories for sure. 2
DocRob Posted January 5, 2023 Posted January 5, 2023 Great work Carl, I like the figure painting as well. Cockpit and the hull sections look good also. Hopefully they sealed the Jagdpanther properly. Cheers Rob 2 1
BlrwestSiR Posted January 5, 2023 Author Posted January 5, 2023 4 hours ago, DocRob said: Great work Carl, I like the figure painting as well. Cockpit and the hull sections look good also. Hopefully they sealed the Jagdpanther properly. Cheers Rob Rob, that's been one of the fun parts of the build: trying to identify the various kit parts they used in building the original filming model. Lots of tank parts and F1 car bits too. 3
BlrwestSiR Posted January 7, 2023 Author Posted January 7, 2023 @DocRob, here's the Jagdpanther hull. This is the engine deck for an M48/M60. An F1 transmission half With the main hull finally done, I started on adding the small details onto the model. These are called greeblies in the SF model world. Looking at the instructions, I realized I was page 30 at this point with another 20 to go. Yeeesh. 7 1
Peterpools Posted January 7, 2023 Posted January 7, 2023 Awesome progress and I had to go back and read Robs comments to figure out what you guys were referring to. Once the lightbulb went off, it's amazing how they incorporated parts from other kits as details on the Falcon. 1 1
BlrwestSiR Posted January 7, 2023 Author Posted January 7, 2023 Peter, if you can find pictures of the ILM workshops from when they were working on the films, they look like hobby shop warehouses. They'd have tens of copies of the same models so they could take parts from them and use them to detail the filming miniatures. Lots of Tamiya kits of tanks, ships, F1 cars you name it. There are guys who made it a mission to identify the various kit parts and find them in real life. Very different from these days where it's all done in a computer. A completely different set of skills. 2
