Started work on the MK103 cannon.
As said: I'm replacing the MK101 cannon for the MK103.
This is the 3d drawing I'm working on of the ammo box.
The cannon itself I ordered from MDC. The barrel will be from Master.
First test print. Fudged up the size, so this print should be a few mm’s bigger, but i’m happy with the detail.
Printed the ammo drum in different angles with different settings. Looks like this one passes.
Also working on the MDC resin mk103. A bit of a dog! Lots of bubbles and mis alignment.
The flame damper is from the ho229 ZM kit.
  • Sad 1
The resin quality of the MDC gun keeps annoying me.
Downloaded a Mk103 file for 22 euro's and wil print one myself.
Which software do you use, is it an AutoDesk product?
Hi,
I use Cinema4D. This software is not the best choice for 3d printing (better suits visualisation), but it is a program that I can work with, so it will have to do. Here's another part of the MK103 cannon I'm preparing for printing.
Just bought another brass barrel for this gun. This one has a locating pin at the base which makes it easier to insert into the 3d print
Here’s the printed mk103. Even thought the barrel end came out nice, the master barrel is way nicer so i replaced it.
almost ready for paint!
Finally happy with all the parts. Added eyelits to the mount that fit the eyelits on the mk103. Some black paint as a base.
Discovered I forgot to model and print the ejector chute.
Managed to find one or two lousy photo's that show this part.
Ok. So slowly getting there. I think i reprinted every part 10 times. At least.
The ejector came out perfect in one go though.
final part. The barrel clamp that holds the barrel in place.
Tiny tiny part, so interesting to see whether the printer can do tis. Asking for trouble...
