As I rarely build Japanese subjects this one is a little out of the usual for me. Something a bit different. It looks to be a very easy build and has really nice panel line/rivet detail. It will be OOB except for seat belts which I'll have to dig up from somewhere! LOL :)
Cool John, are you going to do the chipped aluminium / camo look ?
I plan overall IJA green with silver undersides using one of the schemes provided for in the kit. Nothing special, etc. :)
34 minutes ago, Peterpools said:
HI John
Nice choice for your next build and as always, will be on your express train all the way :popcorn:
Should be a easy peasy build Peter. :)
I'm finding this one is as close to a shake and bake as I've ever worked on. LOL :) I have no doubt it will go fast which is okay as I just need something to work on until the FW-190A-8/R2 Sturmbock shows up mid-week. :)
More progress! I have to repeat, this is the closest I've ever come to a shake and bake kit! So far NO putty needed, just sand the join lines and that's it. This would be a great beginners kit!!! LOL 🙄
Hmmmmmm you’re just saying that because you have nearly finished…….looking good…..
LOL Phil! :) Thanks.
1 hour ago, KevinM said:
I have built this one a couple of times John and builds up easy/nice.;)
It has surprised me with how well things fit and the simplicity of the kit. Of course, the real a/c was simple too!:)
Someone over at Cybermodeler is reading my mind! Today they have the Oscar as their featured subject! LOL
John
Incredible speed and progress, even for you. And I'm sure a good deal of the "shake and bake" construction has a lot to do with your building skills:  careful, accurate and prices work.
Looking mighty good.
This one is going much faster than I anticipated when I started it! That's okay though as I want to get it out of the way for the '190A-8/2 kit which is supposed to deliver tomorrow. :)
Well here's a setback! I was in the process of masking off the yellow wing areas before painting the rest of the model. I needed to readjust the masking tape and when I pulled it off THIS happened. I wanted to test other areas to see if it was just a small isolated area but that was not the case. It's likely I can pull off a lot more if I try the rest of the yellow areas. This WON'T DO! It just might send this one to the SOD as the only way I figure I can remove all the yellow after using more tape on it is to try to clean it up with Q tips dipped in thinner which would then lead to screwing up some of the other primed areas. I'll probably give that a try and see how it goes but if it just makes things worse it's off to the SOD.
  • Sad 2
After I posted those photos I decided to pull off as much paint as I could which was quite a bit more. I think the culprit was the Alclad Primer I used which was not a new bottle. I decided to ditch the old bottle of primer and I resprayed the wings with a Testor's MM gloss light gray. It appears to be fairly smooth so I'm going to let it sit over night and see what's what tomorrow. 🙄 ALWAYS SOMETHING.
John
Does the primer lift off the model where there isn't any yellow paint? If not, then the yellow paint reacted with the primer. If it does, then you're 100% correct and the primer is NG.
Why take chances and just strip the primer off the model and start over with a fresh bottle of primer?
Always something hiding around the corner, especially when everything is going too good.
John
What a fantastic recovery - looks terrific and no one would ever know the problems you had to resolve. So no primer now, just MM gloss light gray. I guessing but for your next build, you're going to be priming with a new bottle of Alclad Primer ?
