Peterpools Posted June 2, 2023 Posted June 2, 2023 Kev For me, the killer and downfall has been trying to get the gear installed and it was a total failure. I've been taking notes on your build and it has helped with a lot of my questions and screwups. Any pics will be of great help, as I can always run them through photoshop. 2
KevinM Posted June 2, 2023 Author Posted June 2, 2023 Roger that Peter.I found some more info about the Tempest undercarriage viva Mr.Edgar Brooks:Before its restoration, I saw the RAF Museum's Tempest, when it was at Cardington, and the wells were green, legs and door interiors were silver. Edgar 4
Peterpools Posted June 2, 2023 Posted June 2, 2023 Kev Always new info coming - just seems at times it is overpowering. 2
KevinM Posted June 3, 2023 Author Posted June 3, 2023 I am finished with the other outside project came out quite nice if I say the Wife was a big help on this one she's good at demolition.I had my seatbelts arrive today with some other goodies and with do drops for the IP tonight for the glass tomorrow is mine day all day expect some movement! 2
Peterpools Posted June 3, 2023 Posted June 3, 2023 Kev Enjoy and good luck, I'm an early riser as you but for photography. There is normally only four hours a day for the beautiful light: an hour before and after sunrise and the hour before and after sunset. Of course, you can photography any time of the day but it's not the same. During the day, I like to shoot B&W film, as shape and form is the key and of course, not color. 2
KevinM Posted June 3, 2023 Author Posted June 3, 2023 On 6/3/2023 at 12:23 PM, Peterpools said: Enjoy and good luck, I'm an early riser as you but for photography. Expand Peter those are special times of the day the Lord blessed me with a beautiful sunrise waist high in water but no fish today forgot a 10:35 HT means Full Moon should of been fishing a few days ago. 2
Peterpools Posted June 3, 2023 Posted June 3, 2023 Kev Just being there and enjoying Mother Nature. is a reward unto itself. 2
KevinM Posted June 5, 2023 Author Posted June 5, 2023 My first post tonight is going to be about procedure and Don't Forget the Part!.I was building the nose and having some issues wondering why is was such a PITA getting part H9/H43 and H10/44 to get a good alignment within the nose cavity?I continued to build I built up E2/E3 but did not glue in yet I went an grabbed E1/E18 part of the lower fuse and front wingroot while providing a roof inside the nose...it was about 1/32" off coming out the back of the nose.I had to file E1 and sub-assembly #34 accordingly all because I forgot to install D2 in the nose which would of aided on a positive blocking plate for H9 and H10.Just a heads up it works this is one part of the build you follow the instructions to the T.I got it all worked out just extra work for me. 4
KevinM Posted June 5, 2023 Author Posted June 5, 2023 The copit is complete and let me tell ya building the seatbelts well let's be Nice a chore with Quinta on the scene that skillset was weak.The belts are RB Productions with a little of Tamiya dust applied.The very rear bulkhead while tight it opened the fuse outwards tightened up the fuse/wing seam even more so me likey.I am trying to loosen the bulkhead right behind the seat with the plate it's off to the right maybe 1/32' if that WD40 and Acetone were mixed and lightly applied no luck may just live with it. The nose to fuse is just about as good as it gets she has had her challenges "Yes" but I have kinda enjoyed them abit(I think I am getting like Ernie ).That's all for now guys got to put in a little more work tonight on her. 5
KevinM Posted June 5, 2023 Author Posted June 5, 2023 As to the seat being off I saw the culprit most likely SH had you install the window crank at the back and it's pushing the seat some so tomorrow pull the tub and remove the crank to it's correct position.I have the Eduard kit and looked there instructions already realizing the what the answer would be just for confirmation it goes all the way to the front of the rail.Peter I plan on using the Eduard instructions as a backup to SH on the LG setup. 2
Peterpools Posted June 5, 2023 Posted June 5, 2023 Kev Thanks for the detailed photographs and procedures. The office does look mighty good and hard to believe SH never realized the issue having the window rank in the wrong spot would cause. I have the Quinta set for the Tempest II, which I'm planning to build and nearly the same kit, sometime this year and of course it does solve the seatbelt issue. Right with you on having a fit issue and when figuring out why, realized a part was missed.
KevinM Posted June 9, 2023 Author Posted June 9, 2023 The primer has been applied was very little filler was needed the biggest area was were the lower wing met the fuse underneath a piece of .020" card stock was inserted and sanded.I had a little step between at the wing root R/side figured do more than good going after it. 5
Peterpools Posted June 9, 2023 Posted June 9, 2023 Kev Remarkable progress - primer looks brilliantly smooth as silk
KevinM Posted June 17, 2023 Author Posted June 17, 2023 This one is all enamels MM next up the stripes, 6
DocRob Posted June 18, 2023 Posted June 18, 2023 Looking good Kevin and the stripes will add a nice contrast. Cheers Rob 1 1
KevinM Posted June 21, 2023 Author Posted June 21, 2023 On 6/18/2023 at 8:50 AM, DocRob said: Looking good Kevin and the stripes will add a nice contrast. Cheers Rob Expand On 6/21/2023 at 1:06 AM, GazzaS said: Looks great, Kevin. Expand Thanks Guys the wing stripes have been applied look like the DK Green in application spotty/faded on the white and with the Black I applied a Fl.Black spotty and then applied Nato Black on that spotty looks good to my eyes.I now have to do the Sky green to the tail and the then the stripes do pics when complete. 1
KevinM Posted June 21, 2023 Author Posted June 21, 2023 The stripes are done had the minimum of clean-up.I am getting close to the event of decals but need slobber her with some future first.The WW's are for you Peter. 4 1
KevinM Posted June 22, 2023 Author Posted June 22, 2023 The main decals have been applied stencils remain for another day.I also painted the prop just need to finish the blades. 5 1
DocRob Posted June 22, 2023 Posted June 22, 2023 Wow, beautiful Kevin, I have to rethink my NMF plans for my mark VI, it seems. Cheers Rob 2
KevinM Posted June 22, 2023 Author Posted June 22, 2023 On 6/22/2023 at 7:27 AM, DocRob said: Wow, beautiful Kevin, I have to rethink my NMF plans for my mark VI, it seems. Cheers Rob Expand You know Rob I can't say how much I have enjoyed this build up to this point already thinking what next? 2
Peterpools Posted June 22, 2023 Posted June 22, 2023 Kev Haven't been on the forum in a few days as medical issues for my wife and myself have been front and center and just everything else has been on pause. Absolutely brilliant paint and decal work - so perfectly done. A flawless build to my eyes, and of course, I fully appreciate all the detailed photographs. Seeing Johns paint work and yours done with MM enamels, I only wish there was a vendor here in the states that sold a full range of enamel colors as in the old days; I sorely miss them. I've contacted a number of overseas vendors and none will ship paints to the US. 1 1
Landlubber Mike Posted June 22, 2023 Posted June 22, 2023 Wow Kevin, that looks spectacular! Love the invasion stripes, well done my friend! 1 1
KevinM Posted June 22, 2023 Author Posted June 22, 2023 On 6/22/2023 at 1:31 PM, Peterpools said: Haven't been on the forum in a few days as medical issues for my wife and myself have been front and center and just everything else has been on pause. Expand I figured that Peter saw the info on the P-51 thread methinks.I know the feeling when momma had her knee surgery in March 2022 it was a rough patch for about a month.I think I have this one beat. On 6/22/2023 at 1:32 PM, Landlubber Mike said: Love the invasion stripes, well done my friend! Expand The fuse was a beotch Mike straight and curved at the same time not perfect but I bet in the field it wasn't either. 3
