John
Brilliant progress - amazing as always and looking so good.
Are you planning on having the engine cowling panels on or off and displaying the Merlin?
3 hours ago, Peterpools said:
John
Thanks. No, it will be closed up.
2 hours ago, Peterpools said:
John
Got ya.  I'm pretty sure after my current build, any more Mustang builds for me will be also with the engine cowlings on.
I did one some years back with the cowlings off but I'm too lazy now. 🤪
Painting coming along except I've only got a smidgen of Lt. Gray left. Not enough to finish the model (underside not painted yet). Ordered more from SB but meanwhile I can work on other areas of the model.
5 hours ago, Peterpools said:
John
You and me both
I have a tinlet of Compucolor which is the same FS # as the Mr. Color I was using. I'm seriously considering using that to finish painting the model. They seem to match up okay so we will see after I do a test run. Fingers crossed! :)
Update: It matched perfectly so I was able to go on and finish painting the model. :) I had forgotten that Compucolor takes a long time to dry and stays tacky for at least over night. So now I still can't handle the model to do more to it. 🤪
35 minutes ago, Bomber_County said:
Looking good……….but seriously arrived in the post June 3rd………decals June 11th…………you have to be ………….
Thanks Phil.
43 minutes ago, Peterpools said:
John
Nice steady and perfect progress. Looking mighty good
Thank you Peter. In measuring out the placement of the "FAB" decal under the wing I found two of the already in place rocket stubbs were in the way. No way would the decal sit over them so I had to pop them off and re-paint that area. Now I'll again have to wait for the paint to dry before I can proceed with adding that particular decal but I think I can go on and apply some of the decals in other areas. We will see!
1 hour ago, Peterpools said:
John
As we keep saying more and more; it's always something. 😉
Yep, always something. 🤪
58 minutes ago, Martinnfb said:
Looking really good John.👍
Thank you Martin. :)
Since they give us the decals and tip tanks for a El Salvadore AF a/c I think I'll make use of them and build another model but using a Revell kit. I was told the conversion set was made for the Tamiya kit but I see no reason not to use a Revell kit. We will see if there are any problems. :) (Instead of adding that build on here I'll start another WIP thread.)
11 hours ago, BlrwestSiR said:
Nice progress John. Did you fill the wings in or leave the rivets there?
Thank you Carl. I left it with the rivets showing. Too much work to cover 'em up. I tried it on a earlier build and it just wasn't worth the effort.
8 hours ago, Peterpools said:
John
A second cavalier - looking forward to that build - going to be a beauty as well.
I've been trying to figure out what will be needed for the tail extension. That's the only "problem" I see to doing another Cavalier '51 so we will see. 🙄
