KevinM Posted December 6, 2023 Posted December 6, 2023 On 12/2/2023 at 4:09 PM, HubertB said: I have reverted to the old-style manual calipers. That's all I used in the machine shop 35yrs ago and still today it's the only way. 2
KevinM Posted December 6, 2023 Posted December 6, 2023 On 12/4/2023 at 4:49 AM, FullArmor said: One done, two to go. Nice improvements! 1 1
belugawhaleman Posted December 6, 2023 Posted December 6, 2023 On 11/23/2023 at 10:44 PM, FullArmor said: I ordered engine cover grille and alu barrel. Barrel is for trumpeter kit and grille is for henglong rc tank...so further modifications expected 😬 Where did you get your barrel from? 1
FullArmor Posted December 6, 2023 Author Posted December 6, 2023 58 minutes ago, belugawhaleman said: Where did you get your barrel from? https://www.axels-modellbau-shop.de/katalog/en/schumo-kits-34850010-aluminum-gun-barrel-for-trumpeter-t-34-85-1-16.html It was last one. I have not seen it anywhere else. 2
FullArmor Posted December 6, 2023 Author Posted December 6, 2023 1 hour ago, belugawhaleman said: Where did you get your barrel from? Fits nicely. No mods needed. 4
FullArmor Posted December 7, 2023 Author Posted December 7, 2023 Enginetools box was missing L-shape brackets. 4
FullArmor Posted December 7, 2023 Author Posted December 7, 2023 Bigger toolbox latches and hinges made from spare photoetched sheet left from tamiya kits. 4
FullArmor Posted December 9, 2023 Author Posted December 9, 2023 Saw made from scrap tincanmetal. Need to fabricate bracket. 2
FullArmor Posted December 13, 2023 Author Posted December 13, 2023 One drawback of alu barrel in 1/16 is that it tends to be noseheavy. So i added some counteweight. Now it balances nicely. 4
Martinnfb Posted December 13, 2023 Posted December 13, 2023 Nice improvements , joy to follow. Cheers Martin 1
FullArmor Posted December 14, 2023 Author Posted December 14, 2023 Cupola with cast texture and visionslits. CO-driver gun and some hitmarks(perhaps fired from PAK-36). 4
FullArmor Posted December 15, 2023 Author Posted December 15, 2023 26 minutes ago, Martinnfb said: a motivation video Yes. I have watched this 😁. "MINT!" My favourite youtube channel by far. 1
FullArmor Posted December 17, 2023 Author Posted December 17, 2023 First time seeing this beast roughly with all the pieces in place. This will be intimidating hulk of iron😁. Tracks will probably enhance this appearance👍 3
FullArmor Posted December 17, 2023 Author Posted December 17, 2023 Added some weight to this hull. This is 40 mm nut...and still looks too small 😬 2
FullArmor Posted January 6, 2024 Author Posted January 6, 2024 First try to replicate castseam. Is this too extreme? Should i make this thinner? Please comment. 4
Bomber_County Posted January 6, 2024 Posted January 6, 2024 52 minutes ago, FullArmor said: First try to replicate castseam. Is this too extreme? Should i make this thinner? Please comment. I reckon that looks pretty good, scale is right………still can’t get over the lack of detail you get at this scale. This going to look amazing when you have added your magic…… 1 1
FullArmor Posted January 6, 2024 Author Posted January 6, 2024 20 minutes ago, Bomber_County said: I reckon that looks pretty good, scale is right………still can’t get over the lack of detail you get at this scale. This going to look amazing when you have added your magic…… Thank you for your kind words. I altered castseam slightly. Transition from seam to turret was too prominent. I used blunt needle to form edge even more. I will post end result tomorrow 🙂 2
GusMac Posted January 6, 2024 Posted January 6, 2024 Looks good to me as well, certainly matches the photo. 👍 1 1
FullArmor Posted January 7, 2024 Author Posted January 7, 2024 I made some castseams thinner and added missing weldseam to handles. It is no means perfect but i can live with that. It is difficult to find good reference images because there were several factories involved of making these beasts. So castseams vary from factory to factory and also when there were made. End of the war turrets were hastily put together and only essential work steps were completed. Also cracks from turret casting were ignored and send to front. There is fine examples of this on MR Hewes youtube video when they aqua blast turret they find massive crack. So massive than you can see daylight through. 4
Daniel_Roxy Posted January 7, 2024 Posted January 7, 2024 Looking awesome so far. Love the headlights and all the smaller details. Will be following along for this one. 1 1
FullArmor Posted January 21, 2024 Author Posted January 21, 2024 I thought that the track assembly would be easy...just add 35+35 links with pins. I was wrong. Tracks are well detailed and correct style, but riddled with pinmarks. I used mr surfacer 500 to fill up those holes. Then roughen up the surface with wirebrush and brite. Only primerpaint will tell if this succeeded or not. 2
FullArmor Posted January 22, 2024 Author Posted January 22, 2024 Is this correct track tension and ride height? Please comment. 4
