Another model flew into the workshop, one of those that are lingering in the cupboard and I still have a lot of it and my wife is whining about how much of it (good stuff) I still have and when I'm going to do it. So I'm getting on with the build, but one that's straight out of the box and how I'm going to make it. Introducing the Curtiss A-8 ‘SHRIKE’ in 1:48 from Czech Model, for me it's a bit of an exotic theme and there will be such themes between Italian and Polish themes. And this is how the box and its contents look like, and there is only one painting and two markings of the machine 80 and 83.
Another interesting choice Kriss. Definitely looks like something someone has put together after a rummage in the spares box.
I agree that this 'Shrike' looks to have been built from whatever they happened to have on hand.
I have this one on my stash so i will be watching closely.
  • 2 months later...
After a long hiatus of my absence I have returned. I managed to do the interiors of both cabs, still in parts and am checking the fit of everything.
Fuselage and all elements to be found in the fuselage ready. In addition to this, the inlet above the engine is cut out, there are cut-outs in the fuselage for six windows, four of which are already inserted. The two upper windows will be inserted when the fuselage is closed, it will be easier for me to make them. In the horizontal stabilisers I drilled a hole for the locating pins and in the fuselage I also drilled one. That would be it, I am now off to paint the interior and exhaust.
The hull closed, the interiors of both crew compartments fitted almost perfectly. There was a bit of sanding. I also added two panes of glass to the top of the fuselage. Now working on the rest of the model.
  • 1 month later...
Chassis on the workshop ready to be closed, pre-sanded, wheel axles and holes drilled for them, and colour applied.
I have been looking through archive photos and modelling forums for inspiration on how to make the stretches. There is a lot of material and I will do the tensioning as I always do. So the mounting eyes are done and are already fixed in the model except for the ones on the wings, there they will be only after the decals are applied.
Only the glazing still needs to be fixed and the primer can be applied, slowly and forward.
Primer laid and without amendments the build came out, now the camouflage colours to be applied remain.
So I have the first camouflage colour applied already, now camouflage and the next colour and slowly the end of the build is approaching.
Curtiss is getting its colours, just the red panel left to go and the decals can be applied.
I was very apprehensive about the decals from the kit due to their age, I didn't know how they would behave during application but it turned out that my fears were completely unnecessary. They reacted very well with the decal liquids. I was most pleased with the superb fit on the underside of the fuselage between the two diagonal stripes and the checkerboard.
The stretches managed to be done and somehow they look good. All that remains is for me to put all the loose parts together and the model will be ready.
