Bomber_County Posted April 28, 2024 Posted April 28, 2024 Awaiting to take pictures of P51D and Mosquito and with the Sd.Kfz.7/1 2cm Flakvierling in the paint shop it’s time to start a fresh project. The F18 was purchased off eBay for an 2/3 of RRP so I added a beautiful RedFox IP to it. As I know absolutely nothing about jets there is little point in buying update / backdate AM galore. This is only my second jet……straight into the build, the cockpit OOB isn’t to bad at all for 1/48 but with the RedFox it does make it pop……onwards with a piece of modern machinery….. The AM or kit doesn’t supply harnesses. When I first started out in industry, we used to layout printed circuit board masters with black crepe tape up to scales of 10 to one. I still have some crepe tape that utilised to give an impression of harnesses, I think it works? 12
Peterpools Posted April 28, 2024 Posted April 28, 2024 Phil Nice choice for your second jet and some mighty nice work on the front office - looks good and busy. Yes, your method for doing the belts and harnesses worked exceptional well. One of the biggest differences for me between RedFox and Quinta is Quinta does come with seatbelts. They also make a Light Sets where there are no belts for less, but I always buy the Quinta sets with the seatbelts and have no issues with them and one less AM item to buy. 4
Bomber_County Posted April 29, 2024 Author Posted April 29, 2024 On 4/28/2024 at 9:27 PM, Peterpools said: Phil Nice choice for your second jet and some mighty nice work on the front office - looks good and busy. Yes, your method for doing the belts and harnesses worked exceptional well. One of the biggest differences for me between RedFox and Quinta is Quinta does come with seatbelts. They also make a Light Sets where there are no belts for less, but I always buy the Quinta sets with the seatbelts and have no issues with them and one less AM item to buy. Expand Thanks Peter, it is a different mindset doing jets. I hear what you saying about Quinta but rather support RefFox. 5
CANicoll Posted April 30, 2024 Posted April 30, 2024 VERY nice start and I hear you about doing jets. Very different from the Mustangs/Spitfires/Airacobras/etc. I've seen where Kinetic is making some nice kits. Your belts look terrific - I especially like that there is some texture to them, not just flat. The IP is AMAZING, esp for 1/48 scale! Had not heard of Red Fox before... 6
Bomber_County Posted May 1, 2024 Author Posted May 1, 2024 On 4/30/2024 at 1:27 PM, CANicoll said: VERY nice start and I hear you about doing jets. Very different from the Mustangs/Spitfires/Airacobras/etc. I've seen where Kinetic is making some nice kits. Your belts look terrific - I especially like that there is some texture to them, not just flat. The IP is AMAZING, esp for 1/48 scale! Had not heard of Red Fox before... Expand Thanks Chris, I’m really impressed with Kinetic so far, the fit is very good. Apparently this boxing is their previous moulds as the now have their Gold series which by all accounts is even better. Well recommend RedFox, I use them exclusively because of the country they are in. 3
Bomber_County Posted May 1, 2024 Author Posted May 1, 2024 On 5/1/2024 at 2:12 AM, Martinnfb said: Nicey! Will follow with interest. Expand Much appreciated Martin…… 2
Bomber_County Posted May 7, 2024 Author Posted May 7, 2024 A question for all people who know about F18’s, are flaps in the down position when parked up? Do not want to fall foul of the “flaps should be up” fraternity 😃😃
FullArmor Posted May 7, 2024 Posted May 7, 2024 Flaps wing landing, ailerons and trailing edge flaps will gradually go down when HYD pressure lost. Leading edge flaps will not...they remain position which left when shutdown. 3
FullArmor Posted May 7, 2024 Posted May 7, 2024 Also rudders will gradually go outwards when HYD lost.
Bomber_County Posted May 7, 2024 Author Posted May 7, 2024 Martin / FullArmour, you guys are brilliant thanks for your help…….👏👏👏👏 4
Jeff Posted May 16, 2024 Posted May 16, 2024 I think I might actually know this pilot, it is possibly a fellow I went to Cadets with WAY back in the day............. wish I could read his name tag.... would be cool if it read Craig Hallowell, sure looks like it could be... he flew in the first Gulf War then retired shortly there after and was on 747's for Cathay Pacific.... sorry for the deviation, Phil, but this could be really cool... Jeff 3
Bomber_County Posted May 18, 2024 Author Posted May 18, 2024 On 5/16/2024 at 4:49 PM, Jeff said: I think I might actually know this pilot, it is possibly a fellow I went to Cadets with WAY back in the day............. wish I could read his name tag.... would be cool if it read Craig Hallowell, sure looks like it could be... he flew in the first Gulf War then retired shortly there after and was on 747's for Cathay Pacific.... sorry for the deviation, Phil, but this could be really cool... Jeff Expand No problem Jeff, always good to have a back story. Couple of observations on Kinetic, the part alignment and fit are very good but instructions not the worst I’ve seen but dry fit a few times. The mould release agent they used needs to be soaked off before you begin. The size of the F18 amazes me, the fuselage in 1/48 is as long as the Mosquito in 1/32……… 4
Bomber_County Posted May 27, 2024 Author Posted May 27, 2024 Enjoying this, not sure where the props go though…….. 7 2
Peterpools Posted May 27, 2024 Posted May 27, 2024 Phil Looking mighty good and the Hornet being twin engine, figuring out where two props go is a lot harder then a single prop. Of course, maybe they would be counter rotating and helping solve finding the location. 😉 2
BlrwestSiR Posted May 27, 2024 Posted May 27, 2024 On 5/18/2024 at 10:01 AM, Bomber_County said: The size of the F18 amazes me, the fuselage in 1/48 is as long as the Mosquito in 1/32……… Expand You should see it in 1/32 Phil. Here's mine standing on its tail tucked behind some other bench warmers which are also 1/32. 6
BlrwestSiR Posted May 27, 2024 Posted May 27, 2024 Oh and the props go in the spares box for when the hair dryers crap out. 2 3
Bomber_County Posted May 28, 2024 Author Posted May 28, 2024 On 5/27/2024 at 7:49 PM, BlrwestSiR said: You should see it in 1/32 Phil. Here's mine standing on its tail tucked behind some other bench warmers which are also 1/32. Expand I think 48th for any and all hairdryers is plenty big enough. I must admit this is my first Kinetic kit and I’m suitably impressed…….I keep biding for their 104 on evil bay, I’ve missed 6 now……. 3
BlrwestSiR Posted May 28, 2024 Posted May 28, 2024 On 5/28/2024 at 12:38 PM, Bomber_County said: I think 48th for any and all hairdryers is plenty big enough. I must admit this is my first Kinetic kit and I’m suitably impressed…….I keep biding for their 104 on evil bay, I’ve missed 6 now……. Expand Check out Lucky Model. They're having a huge sale. Minimum 20% off everything. In case you didn't know, Lucky Model is the parent company for Kinetic. They even have a UK warehouse so that should possibly circumvent any duties. https://www.luckymodel.com/scale.aspx?search=Y&q_brand=KIN&q_category=&q_scale=&q_item_no=&q_word=&q_show_instock_only=Y&q_whse=UK 2
Bomber_County Posted May 28, 2024 Author Posted May 28, 2024 On 5/28/2024 at 7:16 PM, BlrwestSiR said: Check out Lucky Model. They're having a huge sale. Minimum 20% off everything. In case you didn't know, Lucky Model is the parent company for Kinetic. They even have a UK warehouse so that should possibly circumvent any duties. https://www.luckymodel.com/scale.aspx?search=Y&q_brand=KIN&q_category=&q_scale=&q_item_no=&q_word=&q_show_instock_only=Y&q_whse=UK Expand Thanks Carl…I never knew this, the prices are amazing compared with other UK retailers….also I never gave them a thought due importing but with UK warehouse, a win….. 1
Bomber_County Posted June 15, 2024 Author Posted June 15, 2024 Been a couple of weeks since an update, getting to time when I need to break out the CRPlus. u/C and doors etc ready for the booth. As I said before two observations, the release agent has to be completely cleaned off and the instructions could be …….. better. But hats off to Kinetic it goes together very well……..the canopies had part lines down the centres but with care and Tamiya polish they came out well….. 8
