BlrwestSiR Posted March 28 Posted March 28 Trumpeter released a 1/12 GT40 a few years ago. This was more recently re-issued under the Magnifier brand which I guess is an offshoot of theirs. To get around playing licencing fees, they called it the US Sports Car. The kit represents the GT40 as raced at LeMans in 1966, when it won the race and also took 2nd and 3rd for good measure. This was the MkII version of the car. Meng has also released a kit of the Mk II GT40 in 1/12 and it's supposed to be fairly nice. No one has done a kit of the 1968 version of the car, a modified MkI that won LeMans in the famous/iconic Gulf Blue and Orange. Even in 1/24, the closest is the Fujimi MkII with an old and possibly rare Thunder Valley Miniatures conversion kit. 2
BlrwestSiR Posted March 28 Author Posted March 28 The kit overall doesn't look bad. There are some issues with the engine around the carb apparently and the spare tire is missing. But it was $90 when I got it so for that money, it's hard to complain. The Meng is around $400 for comparison. The fit looks to be good. One of the biggest changes between the MkI and the MkII is the rear clamshell. The MkII has a pair of scoops on each sides, while the MkI has a single one plus a smaller intake on the sail panel. The MkII has a chunkier appearance as a result. To get closer to a MkI, I used a razor saw to cut off the upper scoop. I then used strip styrene to fill the resultant hole. Compared to the unmodified right side, it easy to see the reduction in the bulk. This won't be a perfect copy of a MkI as there are too many things that would need changing. The engine would have to swapped from a big block 427 to a 305 small block, and there would be even more extensive body work to be done. I'm just happy to get closer to a MkI. 7
Count0 Posted March 28 Posted March 28 1 hour ago, BlrwestSiR said: The Meng is around $400 for comparison. I got mine from Enabler Brothers for about half that. Lightning deals for the win. And, of course I bought the little one two... 1
Count0 Posted March 28 Posted March 28 I never feel bad about unfinished projects when I see your bench. 1 2
KevinM Posted March 28 Posted March 28 21 minutes ago, Count0 said: I never feel bad about unfinished projects when I see your bench. Now that brought out a good laugh Tony. 1
ScottsGT Posted March 29 Posted March 29 4 hours ago, BlrwestSiR said: The kit overall doesn't look bad. There are some issues with the engine around the carb apparently and the spare tire is missing. But it was $90 when I got it so for that money, it's hard to complain. The Meng is around $400 for comparison. The fit looks to be good. One of the biggest changes between the MkI and the MkII is the rear clamshell. The MkII has a pair of scoops on each sides, while the MkI has a single one plus a smaller intake on the sail panel. The MkII has a chunkier appearance as a result. To get closer to a MkI, I used a razor saw to cut off the upper scoop. I then used strip styrene to fill the resultant hole. Compared to the unmodified right side, it easy to see the reduction in the bulk. This won't be a perfect copy of a MkI as there are too many things that would need changing. The engine would have to swapped from a big block 427 to a 305 small block, and there would be even more extensive body work to be done. I'm just happy to get closer to a MkI. 305? They put that pig of a GM motor in the early GT40? Blasphemy! Pretty sure it was a 289. Very early was a 255. Been thinking about getting one of these. 2
BlrwestSiR Posted March 29 Author Posted March 29 18 minutes ago, ScottsGT said: 305? They put that pig of a GM motor in the early GT40? Blasphemy! Pretty sure it was a 289. Very early was a 255. Been thinking about getting one of these. Sorry, should have been 302. The 1965 MkI used a 289 but they went to the 302 for '68 as the 427 got banned. 1
BlrwestSiR Posted March 29 Author Posted March 29 2 hours ago, Count0 said: I got mine from Enabler Brothers for about half that. Lightning deals for the win. And, of course I bought the little one two... Sorry, that's in Canadian Pesos. And for some reason Meng kits here go for more than they do elsewhere. Conversely the Trumpy one works out closer to $60 US. 1
BlrwestSiR Posted March 29 Author Posted March 29 1 hour ago, ScottsGT said: 305? They put that pig of a GM motor in the early GT40? Blasphemy! Pretty sure it was a 289. Very early was a 255. Been thinking about getting one of these. Of course they should have put an LS in it since that's always the answer 2
DocRob Posted March 29 Posted March 29 First raced one year after the Cobra Coupe in Le Mans. Great project, Carl and the surgery came out nice as well. Cheers Rob 1 1
BlrwestSiR Posted March 29 Author Posted March 29 Here's a better view of the changes to the rear deck. I think it better illustrates the reduction in the bulk of the shoulders. Once the left side sets up a bit more, I'll start on the right side. 6
ScottsGT Posted March 29 Posted March 29 I drive by this place all the time. 15 miles from me. They’re a Superperformance dealer. https://www.downforcemotorsports.com/ Nice days they have a few pulled out in the lot. 2 1
BlrwestSiR Posted March 29 Author Posted March 29 @ScottsGT,Ohhh, that would be a fun place to visit. 2
BlrwestSiR Posted March 29 Author Posted March 29 I finished the cut and shut on the right side. So while that dries, I'm going to start on the chassis. 5
BlrwestSiR Posted April 2 Author Posted April 2 I started working on the engine while the rear clamshell dries. For whatever reason, Trumpeter decided to chrome a number of the sprues. No real rhyme or reason to the ones they picked. It's also that bright chrome and it's thick and heavy so it'll have to go. I used Castrol Super Clean to strip it off. Some kit parts are pre-printed as well. Again, no real order to it. One set are the engine block/transmission assembly. Except they're gold which is so wrong. Nevermind the chrome. The halfshafts also have to be assembled now and get trapped between the transmission case halves. So after some clean-up, chrome stripping and glue, I'm here: Oh did I mention that some parts are ABS? Looks like the (previously) chrome bits are actually ABS and not styrene. I'm glad I have the ABS cement. 4
BlrwestSiR Posted April 3 Author Posted April 3 Finally started with the paint. First up is the transaxle with Dark Iron. 5
DocRob Posted April 3 Posted April 3 That weird chroming and pre printing is strange, shouldn´t be too hard to get it right with such a relatively well known subject. Interesting, that they used ABS, Carl. I didn´t knew, there existed ABS glue from Tamiya. In my recently started Tamiya RC166 build, there is a sprue in the spoked wheel package, which is labeled ABS, maybe, it was easier to produce it with the tiny holes for the spokes this way. Other than that, I never came across ABS parts. Cheers Rob 1
BlrwestSiR Posted April 3 Author Posted April 3 Rob, I think companies use ABS as it's stronger than regular polystyrene. So for the small linkages, hose and stuff it makes sense. Tamiya definitely use it for that reason. On their 1/32 Spitfires, the engine cowl framing is ABS for that reason and I believe they even point it out in the instructions. Of course it does make it a bit harder to glue. Tamiya Extra Thin can work with ABS but you need a clean mating surface and it takes longer to dry. 3
BlrwestSiR Posted April 12 Author Posted April 12 I finally spent some time at the bench and have made some progress. First up, I used some Apoxie Sculpt on the rear clamshell to refine the shape a bit. Hopefully they're reasonably symmetrical. Next up, I got some paint on the engine. I didn't have any Ford engine blue so I mixed something up in the airbrush cup. Looks close enough for me. 7
Count0 Posted April 12 Posted April 12 4 hours ago, BlrwestSiR said: Hopefully they're reasonably symmetrical. I highly doubt the real car was symmetrical. Hand made, and a race car to boot, they probably were going with "close enough". 3
KevinM Posted April 13 Posted April 13 7 hours ago, BlrwestSiR said: Looks close enough for me. Looking good Carl and after seven years in a machine that's Ford blue. 2
BlrwestSiR Posted April 26 Author Posted April 26 It's been silly busy for me lately so I haven't had much bench time. I was working the advance poll for the Canadian federal election on the weekend. 55.5 hours in 4 days. The good news is people came out to vote even though it was the Easter weekend. Election day is this Monday and I'll be working that day too. Anyways, back to the Ford. I gave the rear clamshell a primer coat and that evened out the few remaining flaws. Just needs a light sanding and it'll be good for paint. For curiousity, I dry fit the body parts together to see what it looked like. I'm very happy with it. The rear chassis is also starting to come together. One thing I like is the way that Trumpifier bagged the various hardware. Each individual type of part is bagged and labeled separately. No mixing them up. 7
DocRob Posted April 26 Posted April 26 The rear is looking very smooth Carl, good job on sculpting and sanding. Cheers Rob 1 1
