@Mike: yea, doing a crash dio is just fun. You have the freedom to do nearly everithing, especially weathering wich I start to love. In this case I have the luck, that I got pictures from all around the plane, or is that bad?!? :wacko:
@Grant: My first water attempt was with the Faller stuff, then I tought I will give Vallejo a try. Main "problem" with both are the shrinking, I had to reapeat the pit 4-5 times. But hey, my experience is so small and for shure I will use the still water on the ground, when I build the base on the Dio and then I can say more.
Thanks
Arno
Sorry for the confusion, I meant that 66 could be the darker upper color instead of 74, not to mix 66 with the 75. When I read my previous post I realise it could be interpreted like that.
Thanks Anders, after reading your post again, it was clear! So it's for shure my english, sometimes i'm a bit slow and confused  :wacko:  sorry
No that's good that you got pictures of this very subject in different view. I'm starting to look for similar photos and hopefully I'll get lucky ;)
Mike
Start to throw all the bits and parts into the body
And try how it would look on the frame. What you think: this frame is not to small?
Arno
Looking Fantastic.  Many of you may remember the old diorama of the wrecked B-17 that slid off the side of the runway and lost the gear.?  I was little lad and already loved airplanes, but looking at that model and the story, no, stories that it told grabbed me into the great world of modelling!
This one should inspire many more people to come.  So Cool!
I agree with Johnathan! Your craftsmanship is inspiring to say the least Arno as it does inspire me to challenge myself with each build!
You nailed the prop right down to the boot dents!! By the way how did you do the dents??
As I was never really happy with my bended alu on the frame, I made the panel new. It's not perfect, but I think much better. Final result we will see after a little putty and primer.
Arno
  On 9/17/2014 at 7:17 PM, Paulster said:
Nice scratch work. Aluminum foil?
Yea, the thick one for the ofen.
Starting with the base.
First painted black
My dirt mixture from coffee, sand and just dirt. Mixed with water and white glue.
Bought also Brickstones in 1/35, just had to try it smile.gif
And the first cote of RLM 75
  On 9/23/2014 at 10:39 PM, John Irwin said:
Great work.  How did you replicate the torn up ailerons?
Just drill it with my Dremel  :)
Made a little gras
finally we gets some swiss milk chocolat on the path. Lol
The next step will be, a little coloring of the gras and the mud
Arno
