Administrators James H Posted May 31, 2015 Administrators Posted May 31, 2015 Wow! This has built up so quickly and looks so good. Kudos
Wingco57 Posted May 31, 2015 Posted May 31, 2015 Nice save on those barrels, no creases? Never knew damage like that could Be mended. Cees
Administrators JeroenPeters Posted May 31, 2015 Author Administrators Posted May 31, 2015 Nice save on those barrels, no creases? Never knew damage like that could Be mended. Cees It can! Perfectly round now. I moved my attention to the canopy door. These pics show some needed detail. Lever. Hinge. Locks. Lever: Hinge: Locks: And this round thing: Work in progress: And... I got the paint i need for the 3 color camo: Brown: FS20059 >> Gunze H17 Green: FS24077 >> Gunze H36 Beige: FS26360 >> Gunze H332 (This beige is actually light aircraft grey...) 2
Administrators James H Posted May 31, 2015 Administrators Posted May 31, 2015 Looks great. I presume that canopy is dry fitted?
Administrators JeroenPeters Posted May 31, 2015 Author Administrators Posted May 31, 2015 Looks great. I presume that canopy is dry fitted? Y E S !
tomv1987 Posted June 1, 2015 Posted June 1, 2015 Beautiful work Jeroen! Great research pics you are using too--can't wait for paint! That scheme is going to look cool. It is nice to see a large sale Dutch aircraft finally represented--even if it is in resin. I wish someone would produce a Fokker G.I in 1/32! I particularly like early WWII aircraft, and I am glad some manufacturers are getting around to producing these. Tom
rieser Posted June 6, 2015 Posted June 6, 2015 Impressive progress Jeroen. Great stuff. Looking forward to the colourful camo! Cheers, Ralph.
Administrators JeroenPeters Posted June 10, 2015 Author Administrators Posted June 10, 2015 Still no paint! Working on the surface detail. Added the landing light lenses. Used some extra AK acrylic glass to make them pop some more. 3
Administrators James H Posted June 10, 2015 Administrators Posted June 10, 2015 That's looking real good, and you did proper photos (at last)
One-Oh-Four Posted June 10, 2015 Posted June 10, 2015 That Dee-Twentyone is looking better every time I check in! You're doing good!!
Wouter Posted June 12, 2015 Posted June 12, 2015 Looking mighty fine so far Jeroen, can't wait to put mine together seeing this. But I'm in the middle of rebuilding my man cave. I'll get a new dormer (dakkapel in Dutch) this wednesday and after it has been placed I'll need some time to rebuild the room. Moddeling progress is thus on a alltime low again.
Administrators JeroenPeters Posted June 13, 2015 Author Administrators Posted June 13, 2015 Looking mighty fine so far Jeroen, can't wait to put mine together seeing this. But I'm in the middle of rebuilding my man cave. I'll get a new dormer (dakkapel in Dutch) this wednesday and after it has been placed I'll need some time to rebuild the room. Moddeling progress is thus on a alltime low again. Hi Wouter, All that... And finish your Me410! I'm almost ready for paint. Add the landing lights today and re-did some of the rivets that got lost with sanding. As said before I managed to destroy the prop shaft. Sent Simon of Silver Wings a mail, and behold! Here's an all now prop shaft, well packaged in a plastic container. Very happy boy... Need to polish the landing light covers: Added detail to the open door: And the new prop shaft: 2
Administrators JeroenPeters Posted June 13, 2015 Author Administrators Posted June 13, 2015 Oh! And i drilled out the tail wheel and fitted a brass rod in it for strength. 3
Administrators JeroenPeters Posted June 14, 2015 Author Administrators Posted June 14, 2015 It was a good day! Managed to shoot some lead as well as paint! The aluminium parts received some base alclad and hairspray. The cowling already has some chocolate brown and chipping done. 2
Administrators JeroenPeters Posted June 14, 2015 Author Administrators Posted June 14, 2015 Flap-ulous! 1
Administrators JeroenPeters Posted June 17, 2015 Author Administrators Posted June 17, 2015 First i sprayed the whole model a mix of alclad and linen. The more hairspray and came colours. I'm building them up slowly. No rush 4
Wingco57 Posted June 17, 2015 Posted June 17, 2015 Have you got enough Intel on the camouflage pattern and colours yet Jeroen? Cees
Administrators JeroenPeters Posted June 17, 2015 Author Administrators Posted June 17, 2015 Have you got enough Intel on the camouflage pattern and colours yet Jeroen? Cees Hi Cees, I just stacked all the profiles and info i could find and mixed my own light brown.
Administrators JeroenPeters Posted June 17, 2015 Author Administrators Posted June 17, 2015 not going about this in the traditional way. That would be: mask everything, spray in one go. Since I'm using the hairspray technique, I'm doing this piece by piece. The reason for this is that the paint hardens out quick, which makes the chipping technique harder if you have too much time in between. 4
Carvair Posted June 17, 2015 Posted June 17, 2015 Hi Jeroen your brown looks fine to me...interested what you do with the rest of the colors. And the build is looking good so far. Jan
Administrators JeroenPeters Posted June 19, 2015 Author Administrators Posted June 19, 2015 Spraying the camo freehand Jeroen? Cees Actually no. You can see a harder demarcation line on one side. This is where i used soft clay for the edge. The green will complete the scheme. Hopefully this weekend...
