Hi Guys,
Here's the forward jig 3D printed.
This time in white flexible Polished plastic.
Waaaaaaay better than the plain white flexible it had the read jig printed in.
B6B58082-EC3D-4D0B-8278-9B53D5E0D6C8_zps
3298E0F6-0CD3-452E-9AC0-BD0FBC7CB5CD_zps
Dammit! I suppose I should post some progress too?
Love that printed cradle ;)
Ok ok!
With the Mossie out of the way I started cutting resin.
Since I'm only sharing the cockpit details with you guys and most of it won't be visible through the top canopy I won't bother replacing the MG17's. However I will extend them more to the rear since the gun breaches are missing...
The MG151 gun however is very visible, so I cut out the entire centre resin section with the MG151 breach and replaced it with a fresh more detailed Aires one.
288F4B00-FD06-47F4-AF01-6AA7826A8FE3_zps
Much better.
AIMS looks like it was made of snow, then left in a warm room for an hour.
Incredible details!!! Congartulations!!! You gave me ideas to use a 3D printer for my works!!! Keep going on...  :D  :D  :D  :D
Cheers Nick!
Made a little bit of progress today. Revell has the wing roots moulded to the fuselage. Had to cut them off and fill the holes with green card.
And what a lovely sound to hear overhead when cutting plastic!
C7748450-5747-4749-911A-1D95FF5BCA02_zps
672E90B1-E044-4C5E-B3D7-64CF8B437620_zps
I see you're getting to the root of the problem?
The first time we'll have seen a SPaR for ages here!
Can't wait to see this under some primer, brining it all together. Trust you to be different!  :151_41_44_712.09472830013627761
Noise, how are you going to tackle the complicated fuselage/wingspar screw fittings?
Cees
I was thinking of getting sailboat model pulleys. They seam to have the right shape.
Otherwise I'll just scratch them. Should be do-able..
Ok. This was a head scratcher. I needed to make the round knuckle joints that connect the wings to the fuselage. 4 on each side.
Finally found a 4mm diameter thick tube. Sawed off thin pieces and put them in my Dremel. Sanded out the right contour. Also found a rod with exactly the right diameter that will run through the entire fuselage and will sit back 1mm in each knuckle joint.
D19921DA-D595-4835-86D7-23BF8625FD2F_zps
4228D9A6-EB1B-4511-BDA0-E90B297A4211_zps
B96E3B07-57A1-438B-B802-9FB580370ECA_zps
That is sick.
You are a very sick individual, and you know it!
Better than I ever thought it could be, even with your genius ;)
Very nice solution, well done.
That broodje bal and the excellent company (ahum) today really freed your creatieve juices.
Cees
