Wingco57 Posted January 30, 2016 Author Posted January 30, 2016 Photobucket was down for a while, but seems to be working again. The endpieces are ready bar a bit of mr surfacer to fill some seams. The ends need to have a section taken out to fit the fins against. Cees 2
Wingco57 Posted February 1, 2016 Author Posted February 1, 2016 Windows were finally fitted. Some need to be cleaned up an polished but I am very pleased how they look. Cees 1
kkarlsen Posted February 1, 2016 Posted February 1, 2016 Very nice! Sorry, I have to ask, are you going to rivet the whole aircraft?
Wingco57 Posted February 1, 2016 Author Posted February 1, 2016 Thanks, I thought about that but I will probably chicken out from that exercise. I have insufficient information regarding the rivetting lines from the Manchester/Lancaster. Apart from that the rivets on the fuselage are not flush but round headed. The only possible way would be to skin the model with lithoplate or some other material as Peter from Airscale has been doing. Cees 1
GusMac Posted February 1, 2016 Posted February 1, 2016 Hi Cees, the windows look great. I'm amazed you got such a good finish from CD box plastic, I would have thought it was too brittle. Gus
Wingco57 Posted February 2, 2016 Author Posted February 2, 2016 Hi Gus, It is, being careful is the only way to do it. I still have to sand the fuselage and windows to get them flush all over and then polish for a smooth surface. Have done it before, so no problem hopefully.Cees
woody37 Posted February 2, 2016 Posted February 2, 2016 You're making speedy progress Cees, pitty about the tail planes, still thinking about how to remove mine now...doh!
Wingco57 Posted February 3, 2016 Author Posted February 3, 2016 Hi Neil, I have been thinking about those tailplanes. I kept the cut off pieces but think it is too much work so I will model one of the 20 early Manchesters instead. If I were you keep the tailplanes as is, would be a shame if that fine model gets damaged. Cheers Cees
Wingco57 Posted February 3, 2016 Author Posted February 3, 2016 Edit, Thinking again and looking at pics the span screams at me. So While I was still working on the tailplanes I decided to restore them to the original Lancaster configuration using the previously discarded parts. Sorry Neil. Cees 2
woody37 Posted February 6, 2016 Posted February 6, 2016 I'm glad you did that Cees, I've decided to leave mine, but it's painful to know it's wrong! You won't regret the extra work, I think it looks more aesthetic with the wider span too 1
Wingco57 Posted February 6, 2016 Author Posted February 6, 2016 Fully agree Neil. In fact it makes sense having two larger fins instead of three smaller ones. This evening re-engraving some of the panellines is on the agenda after the heavy sanding eradicated some of them. Then using Parket+ to restore clarity to the windows and after that masking them. That will be difficult to make all masks uniform. Pics to follow later. Cees
Wingco57 Posted February 7, 2016 Author Posted February 7, 2016 And very easy when others solve your problems LOL. Thanks George. In fact I was thinking the opposite by making a template similar to the windows I made in clear plastic and use that to put it on tape, cut around it with scissors and stick it on. Uniform masks everytime. Modelling is fun. Yesterday the panellines have been rescribed, only need to make the windows a bit more clear. Getting there slowly. Cees
Wingco57 Posted February 8, 2016 Author Posted February 8, 2016 Indeed George, Unfortunately it didn't work very well. Difficult to get a nice rounded shape at the ends despite having thick plastic card as a template. Will try your option now, so now I will have to empty a beer can. The tailplanes however are now sorted, so they can be sribed. Pics soon. It was a picless weekend. Cees
brahman104 Posted February 9, 2016 Posted February 9, 2016 Incredible work there Cees! Am loving watching this come together Craig 1
Wingco57 Posted February 10, 2016 Author Posted February 10, 2016 Thanks Craig, Still no pics although I laminated some plasticcard to make the central fin. Some more carving and filing to do. No luck yet on masking the windows, can't get them uniform. The only solution would be custom made masks on a plotter cutter. Anyone have any ideas? Cees
Wingco57 Posted February 10, 2016 Author Posted February 10, 2016 A pic, finally! Although Photobucket didn't behave to rotate it. The tailplanes have been rescribed and are ready to make the new elevator hinges. The elevators have the previously discarded pieces glued back on. Never throw anything away in projects such as these. Although I could not find the triangular pieces. A start has been made on rescribing the fins too, At the bottom is the blank for the central fin. This is made from three layers of thick plasticard. This will need some serious hacking and carving. Cheers Cees
Wingco57 Posted February 11, 2016 Author Posted February 11, 2016 Thanks George, That will be a long carving session, pity I do not have a Dremel. But the joy of cut fingers, sore hands and removed vingerprints is irresistible. Cees
Wingco57 Posted February 13, 2016 Author Posted February 13, 2016 Update, I took the central fin blank to the museum where some very coarse files are in the workshop. This made work easier to get the aerofoil created. It was fun to have Jeroen and George dropping by for a LSM get together. While talking I kept filing the fin covering both Jeroen and George in plastic dust. At home I finished off the basic shape. As the central fin was a steel tube construction covered with fabric I still have to add the ribtapes. The photo's show the general layout of the triple tail with 33 foot span and the central fin aerofoil. The elevators still need a bit of plastic transplant. Cheers Cees 1
brahman104 Posted February 14, 2016 Posted February 14, 2016 That is some spectacular filing work Cees.... I couldn't get it that perfect if my life depended on it! A piece like that would be a prime candidate for 3d printing, but what you have done here is better Craig
Wingco57 Posted February 14, 2016 Author Posted February 14, 2016 Thanks Craig, But as I do not have a 3D printer I just go old school. just remove what is not Manchester central fin en hey presto! Having access to very course files does help a lot and saved me hours. Cees
Wouter Posted February 15, 2016 Posted February 15, 2016 Thanks, I thought about that but I will probably chicken out from that exercise. I have insufficient information regarding the rivetting lines from the Manchester/Lancaster. Apart from that the rivets on the fuselage are not flush but round headed. The only possible way would be to skin the model with lithoplate or some other material as Peter from Airscale has been doing. Cees You could use these for rivetting: http://hgwmodels.cz/en/132-scale/320-free-lines-positive-rivets-132-321000.html 1
Wingco57 Posted February 15, 2016 Author Posted February 15, 2016 Did some work on rescribing the tailfins. The rounded one on the leading edges gave a lot of trouble. In the end I made a simple tool with a needle and some plasticcard. It worked although the lines are a bit rough here and there. I think I will mask this and apply some mr surfacer. These skins were screwed onto mahogany shaped ribs on the Lanc and I suspect they were too on the Manc. Cees
F1Boomer99 Posted February 16, 2016 Posted February 16, 2016 It's really fascinating to follow builds like this. Modeling is truly an art form that requires widespread skills. Scratch building is fun to watch because of the creativity of the modeler meeting his physical abilities. Long winded way of saying "Wow, that's cool". 1
Wingco57 Posted February 17, 2016 Author Posted February 17, 2016 Thanks F1, but it also sometimes a bit of masochism. Have spent two evenings to restore the elevators. I call them Frankenvators as they have been modified so many times now. If you keep them in front of a light source you can see the sawcuts everywhere. The 3D printed plastic sometimes has a mind of it's own and a glued joint suddenly comes loose. Also undoing the conversion to the earlier 28 foot span of the early Manchester back into the Lancaster 33 foot span has taken a lot of effort, but getting there. Cees
