Umlaufmotor Posted September 18, 2013 Author Posted September 18, 2013 At the bottom of the compasshousing a 1.3 mm hole is drilled.In this hole a small lead ball is glued. AND IT WORKS! You see, the case is with the right side up.No matter which way I turn the case, the lead ball is down. 1
Umlaufmotor Posted September 18, 2013 Author Posted September 18, 2013 And WNW kindly lent us again a matching decal ..................Thank you to Dave J on this way. I use again HGW parts as an instrument bezel . This time a chemical blackened bezel.With a 0.2 mm drill the brass screws are indicated on the bezel. The bezel is glued with Vallejo still water. 2
Umlaufmotor Posted September 18, 2013 Author Posted September 18, 2013 To mount the compass in the plane, we need a bracket.In these two images, the attachments of the compass can be seen. (Source is Achim Engels beautiful Fokker E.V/D.VIII-built)
Umlaufmotor Posted September 18, 2013 Author Posted September 18, 2013 In the following pictures I'm trying to build these attachments thirty-two times smaller. 2
Umlaufmotor Posted September 18, 2013 Author Posted September 18, 2013 The compass parts are painted with ca. 95% Tamiya semi-gloss black, and 5% Tamiya light gray. All brass bearings were masked with liquid mask....................... Yes I know what you want to say...................totaly crazy. The screws were painted with polish color and then polished. So, that's all for now.................. Servus Bertl 2
DougN Posted September 18, 2013 Posted September 18, 2013 This build is the first one I check each day - thanks for sharing your magic with us Bertl! Doug
Umlaufmotor Posted September 19, 2013 Author Posted September 19, 2013 Thank you Jamme and Doug for your kind words!! My nerves (ruined by this mini-compass) need this assistance. Well, my nerves are ruined about...............äähm........the compass is completed about 98% . The both screws are still missing. With these two screws, the compass is fastened in the fuselage on a wooden board .As you can see, the mini compass is movable in all axes. And all parts are nearly in scale 1/32.That's the good side..................But he does not move in all axes by itself . Presumably, the weight of the lead bullet is too low...............but could be also, that the internal friction of the bearings is too high............... .........that's the bad side............Anyway .................. and I will build never this little scrap plastic thing a second time.... ...............NO......... .............. Servus Bertl [/url] .....................................So, now that's enough with this compass for a long time.................. 1
Jamme Posted September 19, 2013 Posted September 19, 2013 Hello Bertl. I don't find the words for this build. Love every part of it! Congrats, Jamme 1
Grant Posted September 19, 2013 Posted September 19, 2013 Bertl ... you do know you are barking crazy don't you? Not only that you have an amazing camera with an amazing macro lens as well .. you always manage to get really sharp and clear close-ups. Great job on the model and on the camera work too. I love watching you work! Grant 1
Joker Posted September 20, 2013 Posted September 20, 2013 Genius work...super inspiring. Thanks, Pete 1
Wingco57 Posted September 20, 2013 Posted September 20, 2013 Sorry, but only just saw this thread recently. Having read it, it's a great source of many techniques We can all learn from. I know I have. Cees 1
Umlaufmotor Posted September 20, 2013 Author Posted September 20, 2013 Thank you so much for the flowers. I am very glad that you all like this little excursion into the world of this old 1/32 miniature instruments. We want to make a few more days in this world. It would be nice if you would like to accompany me for a while. Our little Fokker V.4 prototype has flown a very good climb performance.To reach an altitude of 5000 meters, he needed just 20 minutes.I think the test pilot has not held the time by take a look at a clock.Likely a barograph was mounted in the cockpit.This barograph, of course, we will also need in our little V.4 As a good foundation, we use the WNW kit part No.:47. In the second picture you can see an old ww1 original barograph.As close as possible to the original - that is our goal. Accompanies me when you have time, - we will start tomorrow. Servus Bertl
Grant Posted September 20, 2013 Posted September 20, 2013 I bet Bertl creates a chart using real paper and ink too ... Anyone want to bet against me (apart from Bertl!). I'm certainly looking forward to seeing this part come together. 1
Administrators JeroenPeters Posted September 21, 2013 Administrators Posted September 21, 2013 That's cool... Bring it on!!
Umlaufmotor Posted September 21, 2013 Author Posted September 21, 2013 Real paper and real ink................. ......................hmmm.............. Servus Bertl 1
Umlaufmotor Posted September 21, 2013 Author Posted September 21, 2013 We are now working on the WNW kit part No. 47 First, the back from the part is filed with a square file. The remaining walls must be very thin. Using a drill and a square file, to worked out the small window. A very small piece of plastic is now glued on the inside near the small window (blue arrow). We need this piece of plastic to holding later the bottom of the drawer.
Umlaufmotor Posted September 21, 2013 Author Posted September 21, 2013 Next, a plastic wall is mounted to the front of the barograph. A side wall is formed from plastic. On the side of the wall, a small piece of plastic will also be glued (blue arrow). These both plastic parts holding the bottom of the drawer in place. Cut the side wall in the correct length. The thing is still NOT glued. We steal again something scrap plastic from a WNW kit and use it to create the bottom of the drawer. In this picture clearly shows how the small plastic parts carry the drawer. ................. that's all for today. Servus Bertl
Grant Posted September 21, 2013 Posted September 21, 2013 "That's all for today" he says!! ALL? That's just amazing work - almost micro-surgery Bertl, can you tell us how you get such good photos - and what sort of camera you're using? They really are great close-ups. G.
Administrators JeroenPeters Posted September 22, 2013 Administrators Posted September 22, 2013 This is utterly enjoyable. And thank you for taking us along step by step. Cheers, Jeroen
Umlaufmotor Posted September 23, 2013 Author Posted September 23, 2013 Thank you, Grant, Jeroen and Jamme. @Grant, I use a Canon Digital IXUS 95 IS. I got about 2.5 years ago this neat little camera for 75.- Euro on Ebay. This camera is very good for macro's. Servus Bertl
Umlaufmotor Posted September 23, 2013 Author Posted September 23, 2013 Oops, - forgot the safety pin on the shoulder harness. I used a piece of very thin Elektric wire. This is annealed over a candle flame. The flame changes the bright color from the copper wire, the thin wire does not need to be painted now. The difference color can be seen clearly. Then I coated the wire with very thin liquid super-glue. One end is inserted through a buckle, then glued and cut to fit. The securing pin is attached to the other end of the wire. A very small detail, -- but which comes good into effect, when the belt hanging out of the cockpit. Servus Bertl 3
Administrators JeroenPeters Posted September 24, 2013 Administrators Posted September 24, 2013 Hi Bertl, I use the same wiring. Really thin and yet strong. You can also find it on small electrical spools. They are easier to work with! Cheers, Jeroen
