JohnB Posted December 15, 2018 Posted December 15, 2018 I have the very nice Grey Matter Seafire conversion and am considering getting started on that. I haven't been able to find any 1/32 Seafire decals though and I wonder if anyone makes any. My preference is a a/c in the BPF with late war markings. All help is appreciated. Thanks!!!! 3
BlrwestSiR Posted December 16, 2018 Posted December 16, 2018 I haven't seen any decals for an FAA Seafire either John. Considering that the old Revell kit was/is the only option OOB, it's sort of understandable. Maybe look at stuff for FAA Corsairs and cobble something together? For roundels, you can get masks from Maketar that would work too. Hope that helps. Carl 2
DocRob Posted December 16, 2018 Posted December 16, 2018 Hi John, found this by accident, hope it might help. Decals: I found two photographs of 887 Squadron Seafire IIIs, which showed that the airplanes used oversized large BPF insignia; this was likely done to insure that their erstwhile USN allies recognized the unfamiliar shape of the Seafire as “friendly.” I was able to source the BPF decals from the Dutch Decals sheet “Dutchies in de FAA”, which were originally meant for the 1/32 Hellcat. The “Royal Navy” and the serial NN212 came from leftover decals for the Fisher Sea Fury, while “S/112" was sourced out of other Fleet Air Arm decal sheets. Source is: https://modelingmadness.com/review/allies/cleaver/gb/tmcsf3.htm Cheers Rob 4
1to1scale Posted December 16, 2018 Posted December 16, 2018 Check out the Fly Sea Hurricane, they probably flew off the same ships, I bet those decals would be similar. But I would just get some masks (Montex K32198) or some custom Maketar. Fly has masks, but pretty basic.. https://www.ebay.com/itm/Fly-1-32-Paint-Mask-M3203-Hawker-Sea-Hurricane-Mk-IIc-for-Kit-32014/232438591456?hash=item361e6b6fe0:g:-YIAAOSwo4pYSopt 4
JohnB Posted December 16, 2018 Author Posted December 16, 2018 Thanks guys. It looks like the Dutchdecals will work so now I'll see if I can find some. Thanks again! 3
Peterpools Posted December 17, 2018 Posted December 17, 2018 John I'm buckled in a will be following and I just have to get the Corsair finished before you blow by me with the Sea Hurrican Peter 1
