Martinnfb Posted December 25, 2018 Share Posted December 25, 2018 And here is a hint of the size of the cowling exhaust openings . 3 Link to comment Share on other sites More sharing options...
smitty44 Posted December 25, 2018 Share Posted December 25, 2018 If it doesn't work out you can always change the name to F the Trumpeter P-40 build 3 Link to comment Share on other sites More sharing options...
Martinnfb Posted December 25, 2018 Share Posted December 25, 2018 2 dimensional Link to comment Share on other sites More sharing options...
JohnB Posted December 25, 2018 Share Posted December 25, 2018 2 hours ago, Martinnfb said: And once more, well known picture revealing Trumpeters dull edge around the radiator intake opening , Another interesting detail is the absence of the sloped embossed area behind the last exhaust opening. Cheers Martin Those are "L"s, not "F"s. The "L"s didn't have that little indention behind the stacks and were long-tailed. If you have the D&S for the P-40 you can find it there. 3 Link to comment Share on other sites More sharing options...
Martinnfb Posted December 25, 2018 Share Posted December 25, 2018 6 guns + long tail , should be "F" http://www.p40warhawk.com/Variants/P-40L.htm Link to comment Share on other sites More sharing options...
Martinnfb Posted December 25, 2018 Share Posted December 25, 2018 Source: Osprey-Air Vanguard 011 ( for purpose of this build only) P-40E-1 : Wings strengthened to support heavier exterånal loads; enlarged fin on last 500 aircraft P-40F : Packard V-1650-1 Merlin engine P-40F-5 : Fuselage extended 20in. and vertical fin moved aft P-40F-10 : Manually actuated cowl flaps P-40F-15 : Winterized version for cold-weather operation P-40F-20 : Demand-type oxygen system introduced; vent window on left side of windshield P-40K-1 : As E-1, but with Allison V-1710-73 engine; flared exhaust stacks (most K models did not have windshield vent windows) P-40K-5 : rotary valve cooler added P-40K-10 : Fuselage extended 20in. and vertical fin moved aft; some aircraft winterized P-40K-15 : Winterized; emergency hydraulic system eliminated; battery moved forward P-40L-1 : Lightened P-40F with four wing guns; armor and fuel capacity reduced; vent window on left side of windshield P-40L-5 : Rocket fittings added P-40L-10 : Auxiliary fuel pump relocated; armor removed from coolant tank; several warning lights removed in cockpit; sway braces added for belly tank P-40L-15 : Permanent-type carburetor air filter; provision for interior signal light P-40L-20 : New SCR-695 radio; improved relays; incendiary grenade fitting : Wings strengthened to support heavier external loads; enlarged fin on last 500 aircraft 2 1 Link to comment Share on other sites More sharing options...
JohnB Posted December 25, 2018 Share Posted December 25, 2018 I stand corrected. 2 Link to comment Share on other sites More sharing options...
1to1scale Posted December 25, 2018 Author Share Posted December 25, 2018 The L’s got 6 guns after block 1, and most of not all 4 gun were converted to 6. 4 Link to comment Share on other sites More sharing options...
JohnB Posted December 25, 2018 Share Posted December 25, 2018 What about the "ventilation" window on the left of the windscreen? Did all the L's have it? 1 Link to comment Share on other sites More sharing options...
KUROK Posted January 1, 2019 Share Posted January 1, 2019 On 12/25/2018 at 3:11 PM, JohnB said: What about the "ventilation" window on the left of the windscreen? Did all the L's have it? Yes, sir, the Ls all had that extra framing on the left of the windscreen. 2 Link to comment Share on other sites More sharing options...
KUROK Posted January 1, 2019 Share Posted January 1, 2019 Michael Mauritz P-40L on display in Italy. It held up surprisingly well in saltwater. These are not my photos! Please do not repost. 5 Link to comment Share on other sites More sharing options...
Peterpools Posted January 1, 2019 Share Posted January 1, 2019 Kurok Thanks for posting - some serious weathering possibilities. Peter 2 Link to comment Share on other sites More sharing options...
CrankyCrafstman Posted January 8, 2019 Share Posted January 8, 2019 Hey 1to1 Watch out for the Zotz Checkertail decals they are thick and brittle. If you look at my build closely you will see that I had to touch up with paint were they broke off they are bigger then the tail planes and rudder, so they hang over which makes it very difficult to trim them with out wrecking them. 1 Link to comment Share on other sites More sharing options...
1to1scale Posted January 9, 2019 Author Share Posted January 9, 2019 17 hours ago, CrankyCrafstman said: Hey 1to1 Watch out for the Zotz Checkertail decals they are thick and brittle. If you look at my build closely you will see that I had to touch up with paint were they broke off they are bigger then the tail planes and rudder, so they gang over which maks it very difficult to trim up with out wrecking them. Thank you, Ill keep that in mind, Ill probably paint the checkers and insignia anyway, ill just use the small decals. 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted February 3, 2021 Share Posted February 3, 2021 Hi Mark, any progress on this build? Cheers Martin 2 Link to comment Share on other sites More sharing options...
1to1scale Posted February 3, 2021 Author Share Posted February 3, 2021 It’s still in its box on the shelf. There are so many projects.... 3 2 Link to comment Share on other sites More sharing options...
