Kind of an odd question, in German aircraft, did a back seater have same controls as the pilot ? TIA.....harv
In a Trainer yes, and there would be duplicated flight instruments as well.
In a dedicated variant like you're building, probably not. There would be a small array and radios like the back of the He219 / Me262 B etc. I guess it depends on what Z/M has put in the conversion.
But then again, yours is a long range Jobbie, so the Pilot might need to take a kip at some stage...
S
That makes sense . The conversion, the back seat is the same as the front........harv
OK, in that case...
Put a second stick and throttle in (if they're not included), and in the front office add a small circular display within a square to the panel, like this from the Owl conversion for the Fw190 A8/R11.
