JohnB Posted November 16, 2020 Author Posted November 16, 2020 On 11/16/2020 at 3:32 PM, Bill_S said: John, I think you're going the best route. As promised, though, some photos... Expand Thanks Bill. I agree. 5
BlrwestSiR Posted November 16, 2020 Posted November 16, 2020 On 11/14/2020 at 11:57 PM, JohnB said: Can't say as the sheet hasn't arrived yet. Expand I'll check my set when I'm home in a couple hours and see if there's any info. Carl 4
BlrwestSiR Posted November 16, 2020 Posted November 16, 2020 Ok, here what the instructions say: And in Aircraft Pictorial F4U-1 Corsair Vol 2, she's a Goodyear built Corsair IV or FG-1A. I can't find if she should have the standard US pilot harness or the British Sutton one (similar to the Spitfire). My guess is that it should be the Sutton harness which Tamiya includes on the PE fret. 2 1
JohnB Posted November 16, 2020 Author Posted November 16, 2020 Interesting. I'm leaning toward the US seat belts but who knows, it might be the Sutton setup. I sent Dana Bell a message about this so hopefully he will have a answer. 4
BlrwestSiR Posted November 17, 2020 Posted November 17, 2020 John, hopefully you'll from Dana as I'm looking to do a couple FAA Corsairs at some point. Carl 4
Administrators Clunkmeister Posted November 19, 2020 Administrators Posted November 19, 2020 For some reason, John I thought that FAA wingtips ARE included in one of the Tamiya boxings? I'm SO glad you're doing an FAA bird. Other than the beat up Birdcage Corsairs, the FAA Corsair is by far my favorite scheme. One reason I've never finished my first Corsair is that the blue schemes bore the shit out of me. So model On, John. Let's see this one come to life!! 5
Administrators Clunkmeister Posted November 19, 2020 Administrators Posted November 19, 2020 On 11/14/2020 at 4:55 PM, JohnB said: Number 135 Jeff. Expand John, or anyone, I'm curious about the GSB FAA Corsairs. What's with that? Did they just take USMC or USN birds straight from US stock in US colors and simply install their own equipment? I was always under the impression that the FAA Corsairs were built to their own unique spec with, other than the first several Birdcages, had British modifications performed at the factory before they got delivered to the FAA. I learn something new every day, it seems. 4
JohnB Posted November 19, 2020 Author Posted November 19, 2020 I haven't found anything to tell me the FAA Corsairs were modified to British specs (except for the wing tips). As far as I know the Brits added the air scoops and vent on the fuselage but anything else like seat belts I just do not know for sure. I too would like to be better informed as to the mods so I can build a accurate a/c. 3
Spitfire Posted November 20, 2020 Posted November 20, 2020 Found an old thread from HS dated 2008 in which Bruce Archer said the following. Steven, There was a mod center in Conn. All of the FAA Corsairs had British belts, either the Sutton as stated, or the "Q" harness. Not US belts. This is what my research is telling me. Also with the advent of the Corsair IV, the clipped tips were added at the factory, and not the mod center as the rest were. Just another bit to show Corsairs are not as easy as everyone thinks. And the Corsair III was used on ops. Cheers Dennis 4
JohnB Posted November 20, 2020 Author Posted November 20, 2020 On 11/20/2020 at 10:37 AM, Spitfire said: Found an old thread from HS dated 2008 in which Bruce Archer said the following. Steven, There was a mod center in Conn. All of the FAA Corsairs had British belts, either the Sutton as stated, or the "Q" harness. Not US belts. This is what my research is telling me. Also with the advent of the Corsair IV, the clipped tips were added at the factory, and not the mod center as the rest were. Just another bit to show Corsairs are not as easy as everyone thinks. And the Corsair III was used on ops. Cheers Dennis Expand Thanks for that info. Now I'll use the British seat belts. 2
1to1scale Posted November 21, 2020 Posted November 21, 2020 On 11/19/2020 at 11:13 PM, JohnB said: I haven't found anything to tell me the FAA Corsairs were modified to British specs (except for the wing tips). As far as I know the Brits added the air scoops and vent on the fuselage but anything else like seat belts I just do not know for sure. I too would like to be better informed as to the mods so I can build a accurate a/c. Expand I believe the wingtips were just fiberglass fairings? If so, it was probably very easy to swap them even on non-Export birds, I think even the wingtip lights were a production item. 2
