10 minutes ago, harv said:
Ok, I have found a couple in my search, but it seems anyone I pick ill have to scratch sensors.  Any ideas gents ?.....harv
Five shots of rum, and contemplate another kit in your stash?
  • Haha 2
Hopefully this will help a bit.
The MLU tail is the left pic. The C tail is on the right.
Both are from Jake Melampy's books on the Vipers. The big changes are the top of the vertical tail.
Actually the kit tail on top is pretty accurate.  But the Polish Para Pac has sensors on the sides and top
Also, according to Gary of GT resin, I need the large mouth intake. Also would have to add the bumpy thing neer the intake....
Posted (edited)
The kit you bought comes with the large mouth intake so you're good to go there.
Edited by BlrwestSiR
Fix typo
Ok, after a lot of confusion over the intake, I spent the morning on the net. Everything I have read about POLISH F16s states they were equipped with P&W 229 ENGINES. This means they had small mouth intakes. Sprue Br. Has both intake and exhaust in stock. I will be ordering them. The Tamiya kit is GE engine and large mouth intakes and different exhaust.still looking for the conformal fuel tanks and extendedpara pack...harv
Harv, have you bought the Tamiya kit yet?   If not, Academy comes with both engines, both intakes and I’m betting the CFT’s will fit on the Academy kit better, since they were made for the Academy kit.
OK, I have a set of the Academy CFT’s and the tail part you need. I’ll pull them out of the stash tomorrow and see how they sit on the Tamiya kit.  I’ll send post some pics up here.  If it works, I still have your address.
I was looking at the stash earlier.  Good Lord I have a problem.
F-16 kits alone:
Academy F-16 SUFA
Academy F-16D ROK
Academy F-16 CG/CJ  - 2 ea.
Tamiya F-16 CJ
Tamiya F-16 Thunderbird
Kangnam F-16XL
Already have built 7 of the old Revell kits and one 2 seater Academy as a SCANG Swamp Fox
  • Haha 3
  • Confused 1
It’s not as if you like F-16’s...........hopefully you do........
  • Haha 3
Harv,
   Just snippped the CFT’s off and opened up my Tamiya kit.  Not worth taking pics since the front and back halves are on different sprue locations.  But just placing the CFT on the back half through the plastic, looks like a perfect fit.  Although, looking at the pic you posted, they do look a little different on the back end.  I’ll let you figure that one out with filler, putty, etc.. or just live with it!
But I have all the parts out and I’ll get them boxed up and on the way Tuesday when the PO opens back up.
I went through all the sprues looking for the drag chute housing sensors on the pic you posted with no luck.  And I thought these SUFA kits had everything in them..... At least this is a start.
Scott thank you so much. Anything you looking for or can I send some cash ?.....harv
I think Scott likes F-16s the way JohnB likes Corsairs...:lol:
  • Haha 3
Actually....Phantoms are my favorite.  I have 13 or 14 in the stash. Mix of Tamiya and Revell.   Built 3 Tamiyas already.
I really need to find time to build.
