Tamiya F4U-1 Corsair 'Marines Dream' WIP.
Guest DannyVM
Guest DannyVM
Hi Danny looks great. Which panel line washes are you using? I've been using the Ammo ones on my F15 and I'm very impresssed.
Thank's mate,
i use my own mixture for the panel wash, in this case i se a sludge wash. That's 5 part's tap water, 2 part's acrylic Burnt Umber paint and 3 part's dish was soap.
Looking Very Nice!!!
Thank's Jonathan  :)
It's looking brilliant Danny, but too hot to do anything here, will start on owl now that parts have turned up. Cheers. Oz
Thank's Mark  :) well here it's drooling wheater, cold, rainy and dark, the opposite from where you live.
Greetz
Danny
Guest DannyVM
Excellent result. Are you planning on doing more weathering?
Cheers Bevan
Thank's Bevan,
yes i do, chipping, a post shade and some filters to simulate the coral dust are needed to obtain a more realistic result.
Greetz
Danny
Guest DannyVM
Well guy's, i did some more work on the Birdcage Corsair today. I glued some thing's prior to the flat clear coat.
During this work, i realized that this model is really getting bighelp.gif .........but at the same time, it's a impressive modelcoolio.gif so i'm not complaining.smile.png
Ok, landing gear is glued onto the model, wheel still dry-fitted because they need some pigments for wheatering. Also the engine is glued onto the model. Everything got a wash and wheel bay doors are also glued.
Time to give you guy's some pictures
Next photo's are with the engine installed.
and with upper engine cowl
Greetz
Danny
Guest DannyVM
Well, the Birdcage Corsair may be finished, still i need to make a base so, time to start one.
Typical, for Pacific airfields are the palm trees. They are very obvious and they where all around the airfields,so i find it appropriate to place a few on the base. One problem, i never made my own trees so, it was time to learn some skills regarding terrain modeling.
I always try to achieve a nice result without the need of special skills, so my goal was to make some palm trees with simple techniques, still with a nice result. At the end, all went very smooth and so i decided to place over here a little workshop, so all of you guy's could profit with this technique for making your own trees if necessary.
First, the materials needed for this work:
The vegetation, for this i bought some false plants from a local shop for 5€ a piece. These will be used for the palm leaves.
Also some iron garden wire, paper tape, epoxy putty, kitchen paper, Mr. Hobby 500 surfacer and wood glue.
For the garden wire, i used 12 pieces each about 40 cm in lenght and 1 piece about 55 cm.
I hold these 13 pieces together and at the bottom i bent them in an angle of 90°. After this is done, i taped at the bottom the wires together.
I take now the longest piece of wire, and start to turn it around the trunk of the tree. This piece of wire will determine the length of the palm tree. At the upper of the trunk i again taped the wires together.
Next, i take a piece of kitchen paper and i cut it into strips. Width isn't important. I also thinned some PVA glue.
I turn each piece of strip around the trunk, and dip it with the thinned PVA glue until i'm at the upper part of the tree.
Time to take some epoxy putty. I use it to make the characteristic appearance of a palm tree at the bottom and top of the trunk
Time to use the Mr. Hobby 500 surfacer, with a brush i will give the trunk a nice coat.
A palm tree without coconut's isn't a palm tree, so i needed to make a few. Again, for this i used epoxy putty. Coconuts are all different sizes, and they are not round, so i had some artistic freedominnocent.gif
Next, painting of the palm tree trunk. I studied some photo's of palm trees and it was obvious that the trunk of a palm tree have a rather light sandy color. This in with some brown wash and a light filter color gave the trunk a realistic appearance.
The coconuts where hanged into the tree.
They all needed also a color, so again some reference was needed. When hanging in a palm tree, coconuts aren't brown, but green, so in this order i painted them.
And finally, we are coming to the final stage of making a palm tree, the leaves. Like i said before, i use for this some false plants, i cutted the leaves and then i cut them into eye shape. After that i cut diagonal with a hobby knife and so i get the palm tree leaves.
And finally, my first step of making a palm tree is coming to an end. I'm rather pleased of the result, for a first timerhmmm.gif
Hope you guy's like them.
Greetz
Danny
Guest DannyVM
Very effective Danny. The artificial plant leaves look great once shaped like palm leaves.
Thank's mate for the nice comment. :thumbsup2:  :thumbsup2:
Greetz
Danny
Nice coconuts Danny :) . I really like your method and will keep it in mind for a future Beach-Project.
Just took a reference shot in the garden and what's left to say you nailed it.
For me there is no time for modelling today, because I have to cut the real palm :lol: .
Excellent detail obtained in the cockpit painting, landing gear wells, here we will walk on the table watching the new developments, I really liked the finish of the model and those very interesting and great palms the work obtained in them very realistic.
