Hey guys
 I now have the two side frames about half way done.
20210211_163011.jpgthis view shows the LH side frame from the outside.
20210211_162951.jpgthis view shows the LH side frame from the inside.
20210211_162929.jpgtop view of the LH side frame.
20210211_163032.jpgthis view shows both the LH & RH side frames.
20210211_162852.jpgthis view shows them with the tracks added.
20210211_162833.jpgthis view shows them with the base frame in place. I still have to make the 3 upper rollers and the 8 lower rollers and there mounting brackets for both sides, plus the 2 steps on each side frame, both sides and the main center section that attaches to the 2 side frames and the main base frame together, plus all the bolt heads...:omg::construction::D! well that's it for now be back soon with more updates.
Ron G
Outstanding. The structure for the rear sprocket wheel looks somewhat « flimsy » for such a heavy duty behemoth.
Hey Hubert
 Yeah I know, it's not finished yet, there are more reinforcements to add.
Ron G
Hey guys
  Small update for you all. I have the lower rollers and the upper rollers done for the left hand side of the undercarriage frame.
20210213_143123.jpgI took this photo early in the day before I added the upper rollers.
20210213_143522.jpgthis view shows the lower LH undercarriage frame after I added the rollers and mounting brackets.
20210213_143503.jpgview from the bottom of the undercarriage frame.
20210213_170516.jpgthis view shows the upper rollers and their mounting brackets.
20210213_170407.jpgthis view shows the body base frame sitting on the undercarriage. I put my custom made figure in the picture for perspective. Well that's it for now be back with more updates soon.
Ron G
