Hey all
  Did some more work on the Superliner. I have the engine that came in the MPC Mack DM800 put together. It's a Maxidyne ENDT-865 V8. They were, from what I understand a pretty good engine. Thay were the predecessor to the Mack E9 V8. It has a 5 or 6 speed transmission, I'm not really sure.
20210324_174327.jpgthis view shows the cab & hood along with the sleeper, fuel tanks and the wheels/tires that will go on this build.
20210324_180818.jpgthis view shows a top view of the Mack camelback suspension & Mack drive axles.
20210324_180837.jpgside view of the Camelback suspension.
20210324_174532.jpgthis view shows the Mack ENDT-865 from the MPC DM800 kit. Its about the same size as the E9 so I'm using it for fit purposes.
20210324_174506.jpgtop down view of the ENDT-865.
ENDT865_16f8961e-d4e.pngthis is a picture of the real thing. It's painted in Mack gold. Well that's it for now be back soon.
Ron G
  On 3/24/2021 at 9:53 PM, CrankyCrafstman said:
:(:unworthy::respect:
Hey Jeff do you know if they have shock absorbers on the Camelback suspension? Also do they have them on the front suspension?
Ron G
Expand
Traditionally I would say no on the back, but rather just a trunion, and yes on the front axle for a shock
Hey Jeff
  I found a picture on the internet of a Mack camelback suspension with a shock going from the front axle at an angle rearward to the front mounting bracket. It looked like this.
20210326_202842.jpgthis view shows the front shock and how it attaches to the axle and frame.
20210326_202954.jpgthis view from the top shows a little better how the shock mounts.
Ron G
  On 3/27/2021 at 12:39 AM, CrankyCrafstman said:
Hey Jeff
Ron G
Expand
You are correct, I think for the most part, the older versions didn't have shocks on the drivers, but I have seen a few with, so this could very easily be the right thing to do.... looks really good.....
Hey all
I did some more work on the Mack. I'm detailing the interior of the sleeper. You will be able to see this through the two upper windows.
20210329_171912.jpgthis view shows the close closet I added to drivers side. It has a drawer at the bottom. I also made a complete support for the bed.
20210329_171845.jpgtop view of the bed and closet. There will be a refrigerator and small TV on the opposite side plus miscellaneous stuff to make it look real.
20210329_171824.jpgthis view is looking through the sleeper at the bed and closet.
20210330_184449.jpgthis view shows the whole thing temporarily assembled for pictures.
20210330_184428.jpgthis view shows the Roo bar and grill mounted to the hood.
20210330_184630.jpgfront view of the Roo bar, bumper and grill.
20210330_184808.jpgthis view shows the hood in the open position.
20210331_202021.pngthis is my final version of the mural that is going on the back of the sleeper. Well that's it for now be back with more soon.
Ron G
  On 4/1/2021 at 12:17 PM, CrankyCrafstman said:
Hey all
Ron G
Expand
Beautiful Progress Ron!
Hey guys
 Did some more work on the Superliner II. I started doing all the plumbing, air lines, power steering lines, fuel lines, etc. This is a real pain in the a$$!  It's almost getting to the point I can't see this small detail, even with readers and opti-visor! But I'm plugging along...lol
20210401_182029.jpgthis view shows the rear brake chambers.
8081.jpgthis view shows the diagram I'm using to plumb the Mack.
20210401_182058.jpgthis view shows the front brake chambers.
20210401_182136.jpgthis view shows the air lines running along the frame rails. Little hard to see.:(
20210401_182210.jpgcloser view of the air lines at the rear.
20210401_182243.jpgthis view shows the air lines at the front and the LH primary air tank. I scratch built the rear area of the tank, it came as a open hole in the kit..dahh!
20210401_182308.jpgthis view shows the air lines running along the other frame rail.
20210401_182329.jpgthis view shows some of the scratch built air fittings and lines.
20210401_182349.jpgthis view shows the air lines and the small wire looms I made.
20210401_182424.jpgthis view shows the wire/line looms I made from a piece of 4 wire insulation cut to size.
20210401_182501.jpgthis view shows the front brake chambers and air lines. Also the power steering lines.
20210401_182530.jpgthis view shows the radiator braces I scratch built from plasti rod. Well that's it for now be back with more updates soon.
Ron G
Awesome work Ron.... what kind of 'hose' are you using?  Just make sure all the air lines go along the frame rails and watch for rub points.... the proportioning vales look great too !
Hey Jeff
I think it's from Detail Masters and it's 0.024" diameter which is around 9/16" 1/24 scale. Jeff I have a question that maybe you can answer. Do you know how many air tanks were on a 1985 -1993 Mack Superliner II? I know there is one under each battery box 12" dia. x 19"-22" long. Primary tank on the left secondary tank on the right. My question is where is the supply tank? And what size is ut? If you can help I would be extremely grateful. I'm working on the wiring as we speak. Getting ready to start on the front. Another question, did I plumb the power steering correctly? I think I did it wrong.:wallbash: Thanks
Ron G
  On 4/2/2021 at 10:53 PM, Jeff said:
https://truckmanualshub.com/mack-truck-service-repair-manuals-pdf
Have a look at this , Ron, it may be of some use.... I know the "R" series we had as cement trucks many years ago had the wet tanks under the cab and the dry tanks on the frame rails....
Expand
Thanks Jeff
 Couldn't find anything on there, but I  went ahead and added a third tank to it and started plumbing.
Ron G
Hey guys
 I did some more work on the Superliner II. I added a third air tank (supply tank). I think I have all of the air lines, at least for the rear done. I still need to plumb the front brakes.
20210402_183300.jpgthis view shows the whole thing temporarily together.
20210402_183239.jpgsame view, but with the hood closed. I think I'm going to remake all of the fuel tanks,  these are to small of diameter there like 20", yuckk! Going to make them 25.0" diameter, out of some PVC pipe.
20210402_183214.jpgthis view shows the air lines running from the supply tank to the air dryer then to the air compressor. Also the yellow line is for the rear end air shifters. This will eventually go to the floor and up to the shifter.
20210402_183153.jpgthis view shows the supply tank and lines.
20210402_183050.jpgthis view shows the air dryer and lines.
20210402_183110.jpgthis view shows some of the air lines and primary air tank. You can see the bottom of the  air dryer by the fuel tank.
20210402_183026.jpgthis view shows the secondary air tank and air lines. To the left is the supply tank.
20210402_183131.jpgthis view shows the air shift lines to the two rear axles.
20210402_183944.jpgI also added some bolts to the radiator supports. I also added a line from the power steering reservoir to the power steering pump on the engine. Well that's it for now be back with more updates soon.
Ron G
