tchwrma Posted August 7, 2013 Posted August 7, 2013 Hi, Friends. I'm in with this: The version will be one of the supllied with the box, some like this: I just need to buy some aftermarkets... 3
Daywalker Posted August 7, 2013 Posted August 7, 2013 Great choice Paulo! Looks like we're building the same kit.
tchwrma Posted August 8, 2013 Author Posted August 8, 2013 Thanks, Guys! I only need to purchase some afters, because i ever intended to my kit to look like this one: to do this model like this: 3
tchwrma Posted October 17, 2013 Author Posted October 17, 2013 Hi, friends! Finally today I received the aftermarkets purchased to improve the Dora. I received the 2031 Aires Superset: Plus the Master metal barrels: And the Montex Paint masks: The only iten still on his way is the R&B belts.... I barely could wait until weekend to start the kit... 1
tchwrma Posted November 6, 2013 Author Posted November 6, 2013 Men, I'm really impressed who how much parts to be descarded...Almost 50% of the kit... Here the bag with the parts to be used:And here the discarded parts:Parts to be used:Parts discarded:So, let's go to the work:To begin, I marked the cuts and made them, first with the dremel, then with the files, and finally with a sandpaper.So, I made a carving in the inside of plastic to made the walls thinner. This is to let them so close to the real ones.Then, using the excellent 5 view drawings of Kagero book TopDrawings, I made the riveting of the wings and the inferior part of the fuselage. After concluded, i sanded all smootly with a 600 sandpaper to remove the tips and burrs created by the trumpeter rivet tool in the process. I really need to buy the R&B tool....Then, I cut the elevators to get a better detailing.Oh, I almost forgot, I usually mount the rear of each side on the fuselage before closing the fuselage when the pieces come apart (Hasegawa) to avoid problems on the joint. I usually do well in the splice wings, too. I'm use to first glue the wing top to the fuselage, then after add some reinforcement in the inside and then glue the wing bottom....This leaves the wing's joint smooth and without defects or cracks, and does not allow the wing to separate more from the fuselage.Sorry by the slow pace. is that my job is leaving me little time for the kits. But I'm doing my best. In the next post, the fuselage....
Members Mikester Posted November 6, 2013 Members Posted November 6, 2013 Looking good, Paulo. All those add-ons will keep you busy! 1
repeater Posted November 6, 2013 Posted November 6, 2013 Hi Paulo, great to see that you've made a start on this complex project. Not many of the original parts left! Nice work on the riveting! cheers Tim 1
Administrators JayDee Posted November 6, 2013 Administrators Posted November 6, 2013 Thanks, Guys! I only need to purchase some afters, because i ever intended to my kit to look like this one: to do this model like this: Thats my build 2
tchwrma Posted November 7, 2013 Author Posted November 7, 2013 Looking good, Paulo. All those add-ons will keep you busy! I first need to made some copies of the resin parts to use in other 3 würgers that I have in my stash.... Nice Start, Paulo! Congrats, Jamme Thanks, Jamme! Hi Paulo, great to see that you've made a start on this complex project. Not many of the original parts left! Nice work on the riveting! cheers Tim Thanks! When I started doing the riveting whenever the ruler have slipping or the tool keep sliding. Then the result was a line crooked. Then I started scratching lines with pencil and run the tool at Freehand. this method, although it requires a steady hand and a little patience, allows me to better control the work, and the results have greatly improved. Thats my build Congratulations! It was my inspiration for many years! I hope that I can do my one at least a little like your one...
Administrators JayDee Posted November 7, 2013 Administrators Posted November 7, 2013 Loving your work so far. I hope to see more updates soon!
tchwrma Posted December 16, 2013 Author Posted December 16, 2013 Hi, Friends. After some time copying the giant set to the future, I started to mount the resin parts on the kit. I started with the radio and fuel compartment. Here, some pics: Here some details of the work. To made the rough surface of the fuel tank I coated the part with dissolved putty with a hard brush. Then I painted with 3 tones of black, to add light effects. The belts was panted with titaniun gold and then wheatered with betum. The lower port, in the late time of the war was usually made by wood, so I printed a homemade decal and aplyed over the hatch. Then I added some scrap paint to add a dirty look. I hope that I not exaggerated.... Then the cables and wires: Here the wings with the gear bay and the gun bays alligned. When I was riveting te lower wing I brokened a part of the wing, and I decide to put it in some box or else, to avoid to lost the piece. But now I could not find when I placed the damm part. If I colud not find, I will do it by scratch... Comments and crticism it will be very useful.. 1
JonathanReed Posted December 16, 2013 Posted December 16, 2013 Fantastic work! I learned the hard way to never place anything where i WILL NOT lose it...I always lose it! Pulling up the lawn chair, getting the drink , and now the oh yeah ! Ok keep it coming!
tchwrma Posted December 16, 2013 Author Posted December 16, 2013 I just discovered that the wurgers had the inner parts painted in RLM02, not RLM66, like I did. Them I'm repainting the parts, using the first coat to add wheatering, in the process. Tonight I will post some new pics.
tchwrma Posted February 4, 2014 Author Posted February 4, 2014 So, I finally went to correct the interior paint...I made some research and I think I found the actual color of the interior of the fuselage. According to some photos I found and confirmed in the book "Official Monogram Painting Guide to German Aircraft 1935 45", the correct color would be a golden fainted as the interior was painted with an electrostatic corrosion protection, which made the finish look like the interior of tin cans.Extracted from the book: Interior areas such as wings and tailplanes were given an electro plated finish which produced a very high quality anticorrosive surface, a golden metalic sheen very similar to that seen inside some processed food · cans. Interior wooden compo nents were painted with a special finish which had an identifying color of pale Yellow-Green 99 when used with one paint formula, and a very pale yellow tinge when used with another paint formula. (GAM 169.) Here, some FW190 colored pictures: So, I repainted the interior :The cockpit:Fuselage glued:The sad thing is that a few of the interior appears after the fuselage was closed.Now I'm trying to make my own belts type "R&B" made with fabric. As soon as I get a good result, I will post pics ...I will made the kit at time....
repeater Posted February 6, 2014 Posted February 6, 2014 Getting closer Paulo.. ! Good luck with making the belts.
Members Mikester Posted February 7, 2014 Members Posted February 7, 2014 Looking good, Paulo, nice to see you making some good progress on this one!
Guest jimmydel Posted February 20, 2014 Posted February 20, 2014 Paulo, great looking work so far. I really love those Flying Circus birds. May I ask a question about the masking? Do they provide masking for the stripes on the underside...or are you going to have to wing it on your own...pardon the pun. Masking those stripes is what causes me some anxiousness about tackling my own build of one of these.
tchwrma Posted February 20, 2014 Author Posted February 20, 2014 Paulo, great looking work so far. I really love those Flying Circus birds. May I ask a question about the masking? Do they provide masking for the stripes on the underside...or are you going to have to wing it on your own...pardon the pun. Masking those stripes is what causes me some anxiousness about tackling my own build of one of these. Thanks for your kind words! About the masking, Montex do not suply any type of masking for the stripes. But I have a lot of choices to do it. -I can use the decals provided with the kit... -I can do as every modeler do and paint the red, mask with tamiya masking tape, and then paint the white... -Or I could paint the entire lower surface with white, then mask the white stripes with a thin masking tape, then paint the red parts... I prefer the last one. Oh, after a long research in all the boxes, pots, drawers, etc. in my workbench, followed by a huge cleaning of the room, I finally found the lost part! The evil plastic part was dragged to the floor down of the sofa by the floor monster. From time to time, we can win a battle against him. Mi wife loved the room after that.... Soon, updates. 1
Guest jimmydel Posted February 21, 2014 Posted February 21, 2014 Ahh...thanks for the reply, sir. I had done some looking into other builds and found that the 3mm Tamiya tape is usually the go to. With the decals from the kit I'd be worried about transparency, and getting them straight....I'm a little obsessive about symmetry. Lol Glad you found the part too...always feel good to slay the carpet monster...if only temporarily.
tchwrma Posted February 21, 2014 Author Posted February 21, 2014 Ahh...thanks for the reply, sir. I had done some looking into other builds and found that the 3mm Tamiya tape is usually the go to. With the decals from the kit I'd be worried about transparency, and getting them straight....I'm a little obsessive about symmetry. Lol Glad you found the part too...always feel good to slay the carpet monster...if only temporarily. The weird thing in this specific case, is that simmetry is not useful. In the book "Doras of the Galland circus", from jerry Crandall, by Eagle Books, he mention that the white stripes of the birds of squadron are not all with the same size and are absolutely not apllied simetrically. The pictures of the doras, show that their stripes are aplied randomicly. I recomend tou you to find some references or pictures of the plane that tou intend to do, to made it historically acurated. I made a extensive research, and if you fell that need some help, just ask. I'm not the expert in Luftwaffe, but if I could not help, the masters of the LSM would do it, for sure. 1
