harv Posted November 14, 2022 Posted November 14, 2022 Good luck with "life" buddy. Sorry for your loss. On the modeling part, your work always excites me....harv 3
Peterpools Posted November 14, 2022 Author Posted November 14, 2022 Thanks Harv Much appreciated - just seems the older we get; life has a way of tossing more curveballs our way. 2 1
harv Posted November 14, 2022 Posted November 14, 2022 I have 4 Dr appointments next 2 weeks. All for VA disability...harv 2 1
BlrwestSiR Posted November 14, 2022 Posted November 14, 2022 Sorry about your loss Peter. Getting old sometimes sucks. Nice progress on the P-40. From what I understand, you can build the engine completely separate from the plane so you could display beside the completed model and still have the cowls buttoned up. Carl 2 1
Peterpools Posted November 14, 2022 Author Posted November 14, 2022 24 minutes ago, harv said: I have 4 Dr appointments next 2 weeks. All for VA disability...harv I know the feeling ... my calendar is full of doctor appointments for my wife and myself - oh what fun getting old is. Good luck with your doctor appointments. 1 1
Peterpools Posted November 14, 2022 Author Posted November 14, 2022 Thanks Carl .. absolutely true and down the road, I might just go that route. Just feels good to have the mojo back and to be able to sit and work at the bench again 3
GazzaS Posted November 14, 2022 Posted November 14, 2022 Nice to see Progress Peter. The cockpit looks excellent and I am glad to see that the nose pieces came together sweetly. Will you be sanding away the Mr. Surfacer, or using the cotton bud method to strip the excess away? I'm sorry for your loss and medical issues. I hope things clear up for the both of you. Anyway... Mostly I'm glad you're back. 4
Peterpools Posted November 14, 2022 Author Posted November 14, 2022 Thanks Gaz, so very much appreciated. I plan on mostly using the cotton bud method as I've already wet sanded the offending panel fit were needed. See how it goes. 4
DocRob Posted November 15, 2022 Posted November 15, 2022 It's so very good to have you back here Peter. I like Carl's idea of presenting the engine along the P-40. Progress looking great. I wonder if the internal detail would be sufficient for a cutaway model, at least for the engine cockpit and radio section. I would be tempted to do a partially cutaway project for a change. Cheers Rob 4
Peterpools Posted November 15, 2022 Author Posted November 15, 2022 Thanks Rob, feels good to be back and at the bench again as well. I will build the engine as a separate model down the road as Carl is 100% correct. As far all the time I spent adding the fuselage details, it would make a good cutaway project. But for GWH to lavish that much time and expense, which ultimately the buyer pays for just doesn't make sense. So few builders would do a cutaway built and the biggest reason I added all the parts was to show what was included in the kit and no real way to see it after the fuselage has been closed up. Seems as if GWH went to lunch with ZM and talked about what internal details should be included in an expensive kit. 4
Peterpools Posted November 16, 2022 Author Posted November 16, 2022 CLOSING UP THE FUSELAGE Pin washes are done, all the remaining decals, placards, seatbelts, super small PE parts have been added and some light dry brushing as well. I used a good balance of the detail parts from GWH, Eduard and Quinta and the effect does look quite good. As I have already discovered and seems to continue: part placement and orientation is an issue as the instructions are not clear and nor specific enough. Directional locating arrows quite often just go in the general direction or even indicate wrong location. I’ve been very careful with locating parts, removed paint from all the mating surfaces and there still are fit issues. I decided to use pin washes in the fuselage interior just because I added all the detail parts as extra insurance in case something more can be seen then I assumed earlier. Unfortunately, so little actually can be seen. With the fuselage buttoned up, I thought now would be a good time to test fit the nose assemble and the fit has some issues I’ll need to resolve. The nose assembly taped on and there are some fit issues that need to be resolved The seat is finished and resting in place on the wing, as it's not attached to the cockpit bulkheads at all. 13 1
Peterpools Posted November 16, 2022 Author Posted November 16, 2022 Thanks Harv, much appreciated. getting there slowly but surely. 3
Jbert27 Posted November 16, 2022 Posted November 16, 2022 Great work! Nice details and vey clean build. 4
BlrwestSiR Posted November 17, 2022 Posted November 17, 2022 Looks excellent there Peter. For a simple paint on the rear section, it looks well done to me. All these recent kits with too many unseen/unnecessary parts can be a bit of a drain. Carl 4
Martinnfb Posted November 17, 2022 Posted November 17, 2022 talking about Robert Smith I found some colour pictures too. And I have to tell you guys, he is not exactly aging well Ok, seriously , here are some less scary shots 2 2 3
BlrwestSiR Posted November 17, 2022 Posted November 17, 2022 (edited) "It's Robert Smith of the Cure!!!" I had a classmate who would scream that everytime a Cure video came on. Edited November 17, 2022 by BlrwestSiR Fix typo 4
GazzaS Posted November 17, 2022 Posted November 17, 2022 Peter, the cockpit shots look so good! Really inspiring! 2
DocRob Posted November 17, 2022 Posted November 17, 2022 Great work on the cockpit Peter, your painting style is very crisp. I hope the fit issues will be sorted out without too much fuzz. Cheers Rob 2
Peterpools Posted November 17, 2022 Author Posted November 17, 2022 Jbert Very much appreciated. Still working my way back to spending time at the bench and as with all such kits, the fit issues are starting to creep in. 1
Peterpools Posted November 17, 2022 Author Posted November 17, 2022 Thanks Carl and completely agree 100%.. I did spend more time then I thought I would on the internal, never to be seen details but as long as the kit included them, I just thought I would add then and one thing led to another and a lot of wasted time in my book. I just can't understand why manufactures devote so much of their resources to providing all these details that will never be seen. Personally, a waste of time and money on both sides of the coin. I just saw a 'Telford review' of the upcoming HK A20 and the details look amazing - but the same deal, so much will not be seen once the model is built. 1
Peterpools Posted November 17, 2022 Author Posted November 17, 2022 Martin Thanks for the pics - always welcome and a great inspiration to keep moving forward. 1
Peterpools Posted November 17, 2022 Author Posted November 17, 2022 Thanks Gaz, much appreciated. The kit parts plus the Eduard and Quinta details really do make for a nice front office. 2
