CANicoll Posted January 16, 2023 Author Posted January 16, 2023 Peter, that is for sure! I shied away from some kits that required extensive masking. It seemed like the masking took longer than the build! Chris 1
CANicoll Posted January 17, 2023 Author Posted January 17, 2023 This reminded me of how much I hate masking canopies using tape, but it was not nearly as bad as it could have been. The masks for the canopy fit very well and are of the proper shape. It was just the windscreen that was so far off. Whew!! One of the difficulties in masking is the Voodoo canopies have a yellow ring around the glass (which honestly I have no idea what it is, @Martinnfb?) which gets masked as a step in the overall painting. Fortunately the main canopy masks will still work just fine. The windscreen may not be too hard to hand paint. This picture shows I adhere to the philosophy of 'why use one piece of tape when 10 will do?" This energized me enough to clean up the cockpit painting and install the cockpit. Tried to use my 'Sprue Glue' on some gaps but my mixture is a bit too thin. No worries, lots more sprue to use! Progress!! 7
Peterpools Posted January 18, 2023 Posted January 18, 2023 Chris Canopy masking looks perfect and nice going. I've been masking the Kingfisher canopy using strips of Tamiya tape and the front windscreen part took over two and a half hours! Gee, I just love masking as well. 2
Martinnfb Posted January 18, 2023 Posted January 18, 2023 That ring around the glass, if I understand correctly, would be a canopy seal applied in form a tape. 4 1
Peterpools Posted January 18, 2023 Posted January 18, 2023 Martin, I believe you are correct and tough to do in 48th scale. I'm struggling masking the canopies on my Kingfisher and couldn't imagine masking out the seal.
CANicoll Posted January 26, 2023 Author Posted January 26, 2023 Well, I THINK I have it masked so we will see if not tonight, then tomorrow. I ended up using some of the 1mm Tamiya flexible white tape around the windscreen. Expecting that I would freehand any touch-up needed. The Canopy masks for the outline were short, but that was a super simple fix. I have pics of the latest paint work - got all of the camo sprayed but need to touch up some areas (as usual). What I need is a snow-day week to stay in and get a lot of this done! 1
Administrators Clunkmeister Posted January 26, 2023 Administrators Posted January 26, 2023 There were AM decals out there at onetime to simplify the application of the seal tape on the canopy and windscreen. I’m not sure they’re still out there. 1
CANicoll Posted January 27, 2023 Author Posted January 27, 2023 On 1/26/2023 at 9:39 AM, Clunkmeister said: There were AM decals out there at onetime to simplify the application of the seal tape on the canopy and windscreen. I’m not sure they’re still out there. NOW you tell me after I go through hell and back taping!! I think you just wanted to see me do it.! Kidding, of course! I'm more likely to hand-paint the sealtape as anything. Can't be THAT hard, right? Chris Here are some pics of the camo painting sequence. I'm going to have to go back in and do some fill-work, but also the colors just do not look right to me. I used MRP's Dark Green SEA camo, Green SEA Camo, and SEA Tan. Thoughts are welcomed! Light colors first Then the Green (Work in progress picture! This is when I realized I needed to mask the tape areas of the windscreen and canopy) And the Dark Green The Green looks very splotchy in these pictures so will go back and take a look at that on the plane. I may do another spray to fill-in where needed. Just love that MRP paint, however! So smooth... Chris 7
PanzerWomble Posted January 27, 2023 Posted January 27, 2023 Love these old Century Series jets , to me the Starfighter seems to get all the model makers attention , and the others are largely ignored . The Voodoo was a very handsome beast . 2
CANicoll Posted January 28, 2023 Author Posted January 28, 2023 I agree! Love the look of the Starfighter and always was drawn to the Voodoo. Hopefully we will get some good, updated kits on these subjects. 3
Peterpools Posted January 28, 2023 Posted January 28, 2023 Chris I tend to get the same 'splotchiness at times, especially when using a .2 tip and needle and to redo those areas to smooth out the color. The other way to look at it, it's almost instant weathering as the Voodoo knows where you are headed and just wants to help. 2
CANicoll Posted January 28, 2023 Author Posted January 28, 2023 22 minutes ago, Peterpools said: Chris I tend to get the same 'splotchiness at times, especially when using a .2 tip and needle and to redo those areas to smooth out the color. The other way to look at it, it's almost instant weathering as the Voodoo knows where you are headed and just wants to help. Peter, we are of a like-mind! I was thinking the same thing. 🙂 2
Peterpools Posted January 28, 2023 Posted January 28, 2023 16 minutes ago, CANicoll said: Peter, we are of a like-mind! I was thinking the same thing. 🙂 😉 1
GazzaS Posted January 28, 2023 Posted January 28, 2023 22 hours ago, CANicoll said: NOW you tell me after I go through hell and back taping!! I think you just wanted to see me do it.! Kidding, of course! I'm more likely to hand-paint the sealtape as anything. Can't be THAT hard, right? Chris Here are some pics of the camo painting sequence. I'm going to have to go back in and do some fill-work, but also the colors just do not look right to me. I used MRP's Dark Green SEA camo, Green SEA Camo, and SEA Tan. Thoughts are welcomed! Light colors first Then the Green (Work in progress picture! This is when I realized I needed to mask the tape areas of the windscreen and canopy) And the Dark Green The Green looks very splotchy in these pictures so will go back and take a look at that on the plane. I may do another spray to fill-in where needed. Just love that MRP paint, however! So smooth... Chris Chris, I always make my paint splotchy, usually tinting the base color at least twice. I find if you can keep it from looking too uniform, it helps weather the model. 3
CANicoll Posted January 28, 2023 Author Posted January 28, 2023 Gary, Usually I intend for the paint to be splotchy - varying the undercoat and purposedly varying the topcoat as you do. I should have just not said anything and if asked just say "Yes! I planned it this way!" 1 1
CANicoll Posted January 29, 2023 Author Posted January 29, 2023 In between working on the tail of the Catalina, got some paint on the Voodoo and ready for decals, which I just remembered, I have none! Probably have some stars and bars, but that's it. Will start a search... Landing gear and the weapons bay are together so about time to get those on. Chris 6
Peterpools Posted January 30, 2023 Posted January 30, 2023 Chris Cammo work looks awesome and your painting skills are top of the line. 2
CANicoll Posted January 31, 2023 Author Posted January 31, 2023 Thank Peter! Now if I can only find some decals! 🙂 1 1
Bomber_County Posted February 2, 2023 Posted February 2, 2023 Chris, just catching up, looking great. Never done any of the early jets bar the Phantom. Hmmmm you have piqued my interest. Looking for to the grand reveal……l 1
CANicoll Posted February 4, 2023 Author Posted February 4, 2023 Added a few (incorrect!) decals as I had absolutely nothing that was close to accurate - oh well! But got the plane up on its wheels finally. Have to paint the missles which go underneath. But did run into two build problems. Attaching the wings before inserting the nose gear or the weapons bay was a no no. The nose gear bay did fit, with a bit of sanding and some persuasion. The weapons bay, on the other hand. Nope, not going to fit. So the weapons platform was fitted into the opening (pictures later!) so the result is the platform is fixed, rather than rotating to show the two different missles arming the aircraft. My bad on not following the build order closely enough. Will fit the engines/exhaust after the flat coat. That's it for now! 6
Peterpools Posted February 4, 2023 Posted February 4, 2023 Chris Looking mighty good up on her Nikes! Just love the "B" version and the decals, look just fine to me. Not following the instruction sequence - par for the course for me. 1 1
