Administrators JeroenPeters Posted December 10, 2023 Author Administrators Posted December 10, 2023 Mapping out the composition 6 1
Martinnfb Posted December 11, 2023 Posted December 11, 2023 Slowly but surely. The kettenkrad by itself is a pure magic. 1
Administrators JeroenPeters Posted December 11, 2023 Author Administrators Posted December 11, 2023 Printed the final bits. Hatches and the brace for the gun barrel. also adding snow to the corner of the base. IMG_4870.mov 5
Administrators JeroenPeters Posted December 11, 2023 Author Administrators Posted December 11, 2023 Cleaned a few parts up 8
Administrators JeroenPeters Posted December 13, 2023 Author Administrators Posted December 13, 2023 Getting there! Here are some of the 3D drawn and printed hatches. 9
Administrators JeroenPeters Posted December 16, 2023 Author Administrators Posted December 16, 2023 Scratches and patches 10
Administrators JeroenPeters Posted December 17, 2023 Author Administrators Posted December 17, 2023 It’s all about the base 7
Administrators JeroenPeters Posted December 23, 2023 Author Administrators Posted December 23, 2023 More weathering. Still much more to do. Also added the instruments to the side of the cowlings. 9
Bomber_County Posted December 23, 2023 Posted December 23, 2023 46 minutes ago, JeroenPeters said: More weathering. Still much more to do. Also added the instruments to the side of the cowlings. Absolutely sublime……. 3
FullArmor Posted December 24, 2023 Posted December 24, 2023 10 hours ago, JeroenPeters said: More weathering. Still much more to do. Also added the instruments to the side of the cowlings. Good job! It must have been fun. Is there instrument cluster side of the engine!?😮 2
Administrators JeroenPeters Posted December 24, 2023 Author Administrators Posted December 24, 2023 1 hour ago, FullArmor said: Good job! It must have been fun. Is there instrument cluster side of the engine!?😮 Yes, pretty cool huh? Actually there were more planes that had this. 8
Administrators JeroenPeters Posted December 25, 2023 Author Administrators Posted December 25, 2023 3D printed mk103 cannon installed. Including the 3d printed barrel brace. It even hinges. 10 1
KevinM Posted December 26, 2023 Posted December 26, 2023 So when in action the cannon flipped into the belly and the barrel fitted into the ring?am I missing the cover? 1
Administrators JeroenPeters Posted December 26, 2023 Author Administrators Posted December 26, 2023 1 hour ago, KevinM said: So when in action the cannon flipped into the belly and the barrel fitted into the ring?am I missing the cover? No. The gun only flipped out when serviced. The cover i left of. Why? Because the cover was left of in service often. Like on this white K 3
Bomber_County Posted December 27, 2023 Posted December 27, 2023 16 hours ago, JeroenPeters said: No. The gun only flipped out when serviced. The cover i left of. Why? Because the cover was left of in service often. Like on this white K Great detail, just reading up the differences between mk103 and mk108’s as used on the Fw190 A-8 R2. the mk 108 uses 30x90RB mm ammunition. the mk 103 uses 30x184B mm ammunition. So 103 more punch for your money. Toying with idea of adding them on to my Border Fw 190 build……. 1
KevinM Posted December 27, 2023 Posted December 27, 2023 16 hours ago, JeroenPeters said: The gun only flipped out when serviced. Meaning maintenance?In combat it retrieved to the belly.
Administrators JeroenPeters Posted December 27, 2023 Author Administrators Posted December 27, 2023 34 minutes ago, Bomber_County said: Great detail, just reading up the differences between mk103 and mk108’s as used on the Fw190 A-8 R2. the mk 108 uses 30x90RB mm ammunition. the mk 103 uses 30x184B mm ammunition. So 103 more punch for your money. Toying with idea of adding them on to my Border Fw 190 build……. Correct. I have both original complete rounds. The mo108 is pretty easy to find. The mk103 not easy. 5
Administrators JeroenPeters Posted December 28, 2023 Author Administrators Posted December 28, 2023 If you look at reference photos you’ll see the plugs securing the gun in closed position dangling on chords. 4 1
Administrators JeroenPeters Posted December 28, 2023 Author Administrators Posted December 28, 2023 Almost there. Need to attach all the hatches. Add an aerial wire. And some other small bits. Aah, and the gunsight. Note the hinging PE nightmare engine hood on the Kettenkraftrad 10
belugawhaleman Posted December 28, 2023 Posted December 28, 2023 Amazing work! Too bad about the base though. 1
Administrators JeroenPeters Posted December 29, 2023 Author Administrators Posted December 29, 2023 10 hours ago, belugawhaleman said: Amazing work! Too bad about the base though. Thnx! Actually i’m not using the damaged base. This is a different one 2
Administrators JeroenPeters Posted December 29, 2023 Author Administrators Posted December 29, 2023 So i fudged up and accidentally threw away the gunsight parts… Guess i’ll have to design and print my own now… 1
Administrators JeroenPeters Posted December 30, 2023 Author Administrators Posted December 30, 2023 First steps of the gunsight. Inside this arrangement I will place a Quickboost Revi 12 gunsight. On the side I will add two thin wires that go through the small holes of the louvres. 5
Wouter Posted December 31, 2023 Posted December 31, 2023 18 hours ago, JeroenPeters said: First steps of the gunsight. Inside this arrangement I will place a Quickboost Revi 12 gunsight. On the side I will add two thin wires that go through the small holes of the louvres. You did that on purpose! Just to play with your new 3D printer😄 4
